Old 03-27-2015, 08:51 PM   #261
Well the snow is on its way out and the days are getting longer, and its getting warmer out. Time to get a little work done on the bus, I ordered 8 new fuel injectors should be here next week, replacing them is at the top of the list, after that hopefully put new flooring in, and just some general up grades. So far only a few trips planned at this time.
Old 04-04-2015, 11:38 AM   #262
well got the new injectors, and now of course its -16c windshields -22c, suppose to be cold all this long weekend. But I did brave the cold yesterday and got the 4 injectors out on the left side of the engine, they are the harder ones to change, still have to put the new ones in, ill wait till it warms up, but I'm hoping to get the other 4 out tomorrow, I want to be able to have the cores ready to ship back on Monday, they hold $1000.00 for them.
Old 04-04-2015, 02:58 PM   #263
Engine: 190hp 5.9 Cummins
I hear your pain.
Only -12 here with blowing rain at 60 kmh.
Next week we are going to have plus 15.
Old 04-04-2015, 03:26 PM   #264
what is this "C" you speak of , it has been between 23*F and 78*F this last 2 weeks, driving us nuts
I know, short drive lol
Old 04-05-2015, 03:08 PM   #265
Old injectors are out and packed in return box, new injectors ready to go in.
Will wait till it warms up to start putting them in.
Old 04-05-2015, 06:30 PM   #266
I'd say "cool", but based on the pics, maybe cool is the wrong word!?! They sure are pretty. Jack
Old 04-05-2015, 07:11 PM   #267
Mmmmmmm....shiney!
Old 04-09-2015, 06:24 PM   #268
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
Originally Posted by bansil View Post
glad trip went good!
Love it and totally agree.
Linda Kay
trans·mog·ri·fy Verb: Transform, esp. in a surprising or magical manner.
Shadoll is offline   Reply With Quote
Old 04-09-2015, 10:30 PM   #269
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Did you drain your oil tubes before the change? Or crank the motor over to get the oil out of the cylinders? Something you gotta do--or else!
Old 04-10-2015, 06:43 AM   #270
I couldn't break loose the oil drain plugs in the heads so I removed the back injectors first, let the oil\fuel drain into the cly, then I pumped out the oil with a pump I rigged up to go down the injector hole. I did this for each injector (. I have the glow plugs out and will crank over the motor to get the rest(if any) oil out, the vac pump did a really good job sucking out all the oil, what I also did was plug in the block heater made the oil nice warm
I should have it finished this weekend , its suppose to be warm and I still have 4 injectors to put in.
Old 04-11-2015, 05:25 PM   #271
Well our injectors are installed and shes running better then ever. I have to change the oil, and get my plate tags(expired) before I can take it for a good run. She runs a lot better then it did, and there's a big difference in power just moving it a bit in my drive way, can't wait to get it out on the high way.
Old 04-11-2015, 06:12 PM   #272
Great news.
Glad they worked out.
Old 06-14-2015, 01:03 PM   #273
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
How much did your new injectors cost? I have a feeling that I will need to do the ones in my 7.3 Ferd this year.
I'm hungry!
You Gotta Let Me Fly
Old 06-14-2015, 06:39 PM   #274
they where $244.00 each, now with the cdn to usa dollar there at $300.00 each, these where brand new Alliant injectors, and there stock size. this includes sending them your old ones as cores.
heres the link Ford PowerStroke 7.3L AD HEUI Injector for 1999-2003 E and F Series, 1 – Diesel Parts Canada. and I got them from Diesel Parts Canada Diesel Parts Canada - Wholesale Injectors, Pumps, Additive & more
Old 06-14-2015, 09:05 PM   #275
Moderator
crazycal's Avatar
I will probably go rebuilt.
I'm hungry!
Old 10-25-2015, 10:11 PM   #276
well the summer went by fast, we only spent 18 nights in our bus, and only put on 5000kms, I didn't do any other work on the bus, other then new injectors, I already winterized it, I left the generator in so I can use it in a power failure. The bus ran like a champ, and everything work well, can't wait to till spring time.
Old 05-01-2016, 10:05 PM   #277
Well we made our first run with the bus this spring, went about 200kms and boondocked for the night, had a small problem with the pressure relief valve on the hot water tank, every thing else was great, feels good to be back in the bus, we have a few trips planned this summer.
Old 05-01-2016, 10:54 PM   #278
turf's Avatar
i also left my hot water pressure relief valve open when i filled the tank this year.
Turfmobile Build Thread
Old 05-02-2016, 09:04 AM   #279
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
Glad the trip was a success! PRV issue, was it leaking?
Old 06-26-2016, 09:27 PM   #280
yes the prv was leaking , just went , steady little stream of water, had to use the hot water by-pass to save my water
Need Help Which bus- leaving in 3 days Bus dad Mechanical and Drivetrains 1 11-20-2013 01:21 AM
2011 NPS Fee Free Days lornaschinske On the Road | Travel, Trips, Camp Sites, Tailgates 0 01-08-2011 09:53 AM
Our First COnversion attempt (from 0-100% in 18 days) MoMomma Skoolie Conversion Projects 9 06-29-2010 12:36 AM
DAYS ARE NUMBERED sportyrick Alternative Fuels | Electric, Propane, Wood & Biofuels 19 01-23-2010 07:03 AM
