Old 04-11-2015, 06:25 PM   #271
Well our injectors are installed and shes running better then ever. I have to change the oil, and get my plate tags(expired) before I can take it for a good run. She runs a lot better then it did, and there's a big difference in power just moving it a bit in my drive way, can't wait to get it out on the high way.
Old 04-11-2015, 07:12 PM   #272
Engine: 190hp 5.9 Cummins
Great news.
Glad they worked out.
Old 06-14-2015, 02:03 PM   #273
crazycal's Avatar
How much did your new injectors cost? I have a feeling that I will need to do the ones in my 7.3 Ferd this year.
I'm hungry!
You Gotta Let Me Fly
Old 06-14-2015, 07:39 PM   #274
they where $244.00 each, now with the cdn to usa dollar there at $300.00 each, these where brand new Alliant injectors, and there stock size. this includes sending them your old ones as cores.
heres the link Ford PowerStroke 7.3L AD HEUI Injector for 1999-2003 E and F Series, 1 ‚Äď Diesel Parts Canada. and I got them from Diesel Parts Canada Diesel Parts Canada - Wholesale Injectors, Pumps, Additive & more
Old 06-14-2015, 10:05 PM   #275
crazycal's Avatar
I will probably go rebuilt.
I'm hungry!
Old 10-25-2015, 11:11 PM   #276
well the summer went by fast, we only spent 18 nights in our bus, and only put on 5000kms, I didn't do any other work on the bus, other then new injectors, I already winterized it, I left the generator in so I can use it in a power failure. The bus ran like a champ, and everything work well, can't wait to till spring time.
Old 05-01-2016, 11:05 PM   #277
Well we made our first run with the bus this spring, went about 200kms and boondocked for the night, had a small problem with the pressure relief valve on the hot water tank, every thing else was great, feels good to be back in the bus, we have a few trips planned this summer.
Old 05-01-2016, 11:54 PM   #278
Engine: 5.9 Cummins, Allison 545
i also left my hot water pressure relief valve open when i filled the tank this year.
Turfmobile Build Thread
Old 05-02-2016, 10:04 AM   #279
Docsgsxr's Avatar
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
Glad the trip was a success! PRV issue, was it leaking?
My build thread - viewtopic.php?f=9&t=467197
Old 06-26-2016, 10:27 PM   #280
yes the prv was leaking , just went , steady little stream of water, had to use the hot water by-pass to save my water
Need Help Which bus- leaving in 3 days Bus dad Mechanical and Drivetrains 1 11-20-2013 02:21 AM
2011 NPS Fee Free Days lornaschinske On the Road | Travel, Trips, Camp Sites, Tailgates 0 01-08-2011 10:53 AM
Our First COnversion attempt (from 0-100% in 18 days) MoMomma Skoolie Conversion Projects 9 06-29-2010 01:36 AM
DAYS ARE NUMBERED sportyrick Alternative Fuels | Electric, Propane, Wood Gasification, etc. 19 01-23-2010 08:03 AM
