Old 10-10-2015, 01:16 PM   #31
OMGIBoughtABus's Avatar
Chassis: Saf-T-Liner
Engine: Cat 3208
Rated Cap: 84 px
Originally Posted by Scooternj View Post
Have you tried using a #2 square bit? That's what holds the panels up in my Amtran. Took me about 45 minutes taking them all down
In the Thomas I have they are all rusty #4 Phillips head screws.
OMGIBoughtABus is offline   Reply With Quote
Old 10-10-2015, 01:58 PM   #32
I had very good luck on the 70 year old Phillips heads that hold everything together on my Shorty using an old fashioned, hand held impact driver and a three pound hammer. Once they were broken free, my Milwaukee drill/driver did the rest. Had to use a cut-off blade on some but not many.
http://www.amazon.com/TEKTON-2910-2-...+driver+manual
Hints...buy several extra bits and do use safety glasses.
Old 10-10-2015, 06:40 PM   #33
Stewzer55's Avatar
Coachwork: Fisher Body
Chassis: GM "B" Platform
Engine: 350 TBI Chevrolet
Rated Cap: 8
I have a feeling that the manual impact could quickly become a favorite tool, the hammer strike could jar the rust loose. Have you tried giving them a little bit of penetrating oil?
Stewzer55 is offline   Reply With Quote
Old 10-10-2015, 06:43 PM   #34
Engine: Cat 3208
Rated Cap: 84 px
That sounds like a good idea, thanks!
Old 10-10-2015, 07:52 PM   #35
Most of my screws had 86 coats of paint and were just lumps...so there was no place for the penetrant to go. Whacking does indeed jar the rust and paint loose.
Old 10-10-2015, 07:58 PM   #36
Engine: Cat 3208
Rated Cap: 84 px
Hmm I might have to try whacking instead of screwing.
Old 10-13-2015, 12:16 PM   #37
Chassis: Thomas
Engine: 3208 CAT
I used #2 square bit on all of my screws, you would probably get better grip with the square bit than with the #4 Phillips bit. that's just my opinion though
Cityratt is offline   Reply With Quote
Old 10-13-2015, 01:11 PM   #38
Chassis: Blue Bird
Engine: ISC 8.3
I've been known to stack adapters to reduce my 1/2" air impact wrench to 3/8, then 1/4, then put on a 1/4" hex socket to hold the screw driver bit..... It's perversely satisfying to hear that air wrench zipping sound while pulling out stubborn screws. Several driver tips have been broken by this gross application of way too much torque but often it gets the job done.
Really should pick up one of those manual impact drivers. I bet the thump along the axis of the screw combined with the simultaneous twisting would be very effective.
A chisel digging into the screw head, tangent to the head so that the blows from the hammer apply force in the "un-screw" direction, works well too. It's a nice fall-back when the heads strip out. Air chisel is nice for this; the vibration helps work things loose.
Old 10-13-2015, 01:53 PM   #39
A torch can also help break nuts, bolts and even sheetmetal screws loose. Oxy, Blow, propane, whatever. But...you do have to keep up with which ones are hot...and which ones are OK to sit on. Ask me how I know.
Old 10-14-2015, 08:41 PM   #40
I also use the "Tango Tool" but I've learned to use an awl to pick some of the paint out of the slots before I use the tool. That way I can use a 1# hammer to work the tool and it doesn't completely flatten my thumb when I miss.
