Old 09-07-2012, 05:48 PM   #11
Re: Skoolie in progress
what did you use to attach the 2x4s inbetween the windows? Screws, thru bolts??
Thanks
collincountycab is offline   Reply With Quote
Old 09-12-2012, 07:24 PM   #12
Chassis: International Schoolmaster
Engine: 7.3L
Rated Cap: 24
We used Carriage bolts through to the outside of the bus. then on the inside, we drilled counter-sink holes into the wood and screwed in nuts until they were flush with the 2x4s. We figured the bolts going through to the outside would give us the most support, as we are eventually going to attach all our furniture to these beams
"The entire world is but a narrow bridge. But the important thing is not to be afraid"
http://www.skoolie.net/forum/viewtopic.php?t=14831
3forward2back is offline   Reply With Quote
Old 09-13-2012, 04:06 AM   #13
One possible issue will be loosening of the bolts from vibrations etc,it can collapse the metal and the expansion and contration of the wood may add to the effect...I love the "factory" paint you guys got with your bus
Old 09-13-2012, 08:50 AM   #14
I have to agree with Bansil...but you can still come back and apply a little Red LockTite to the threads. That will prevent the bolts from vibrating loose and walking out.
Old 09-17-2012, 09:05 PM   #15
Engine: 7.3L
Rated Cap: 24
I'm going to do that for sure. thanks for the advice
Old 09-17-2012, 10:35 PM   #16
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Actually, you want "290" Loctite. Its wicking-made for getting in threads already assembled.
G Bus Progress rjz5400 Skoolie Conversion Projects 136 05-07-2015 04:27 PM
Projet in progress Les_stephs Skoolie Conversion Projects 1 09-15-2014 09:50 PM
Buckeye Tailgater.... IN PROGRESS baadpuppy Short-Bus Conversion Projects 25 09-27-2010 09:26 AM
Greasley in progress.. Stuff Short-Bus Conversion Projects 0 04-08-2010 04:26 PM
Why I haven't been making any progress on my bus. Steve Everything Else | General Skoolie Discussions 2 07-03-2005 07:32 PM
