Old 07-09-2013, 03:06 PM   #1
Rated Cap: 71
Skuld U Bus "Prime"
Hello All! I am just getting started with my first Skoolie project. So far it seems to be going quite well. I have all the seats and ceiling panels out but have been having difficulty getting the panels below the window out. They seem sandwiched between a bar under the window and another bar below that. I was hoping pulling off the screwed down black strips under the windows on the outside would provide some kind of access. Has anyone tried to strip down this far? I am stripping it because I want to raise the roof ala this post http://busweb.freeservers.com/raising.htm. I'll post some pictures soon. Has anyone completely stripped the interior down to the ribbed framing?
skuldu is offline   Reply With Quote
Old 07-10-2013, 03:16 PM   #2
eyedeal.ink's Avatar
Re: Skuld U Bus "Prime"
I think you need to take the windows out, removing the rub rail on the exterior (what I believe you are referencing) isn't gonna give you access, if you look up underneath you'll see these panels are screwed on (down) then the windows are installed.
"That's,. like,.. your opinion, man...." - the Dude.
eyedeal.ink is offline   Reply With Quote
Old 07-10-2013, 03:25 PM   #3
I would recommend a few things if you want a 6 inch raise cut the filler pcs at least 12" long and set them into the window channels, butt welding 1/16 thick tubing with a small mig is asking for trouble in my book
Old 07-11-2013, 07:53 AM   #4
JakeC's Avatar
I concur... Butt welding those seems like a terrible idea to me. I'm sure he'll be fine and all, but getting metal to fit inside the channel and having a substantial overlap seems a MUCH better idea.
Brutus
Old 07-11-2013, 08:05 AM   #5
wmkbailey's Avatar
Engine: 3126
I agree with above. I will be fitting square tubing in the channel and welding the over lap. Also per the great Elliot on "The Millicent Chronicles; two foot roof raise, big tailgate" I will also weld angle on the inside from the wall to the window post for added support. Check out his post for raising the roof.
viewtopic.php?f=9&t=1709
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
1986 Intl/Thomas Conventional, DT466 5speed, "Big Blue Bus" thrash Skoolie Conversion Projects 8 08-25-2013 11:57 AM
"Short" bus or "Regular" bus? TygerCub Conversion General Discussions 11 03-03-2012 12:37 PM
++SOLD++ 1989 TC2000 FE (Calif. CLEAN title, as "MH") chev49 Classifieds | Buy, Sell, Swap 1 02-18-2012 12:10 AM
"Tutorial" and "How To" internal error dunnwright Conversion General Discussions 6 11-16-2010 07:02 AM
