05-05-2010, 10:18 PM
#21
Re: Slab Cab'n
It took one weekend per side and another for the back corners. And we have 20+ hours into the bumpers but they look great, forgot the camera but will post some by the end of the week-end!
Better add this before I forget too.
We had 3 10'x5' sheets of steel sheared in halve, then those 6 pieces were bent at 90deg for the bottom inch (to stiffen the sheets when they were mounted). And yes they are very stiff! The cost for sides were $470 and were .090-.110 thick....not sure what the gauge # is.
The Back corners were 28" then bent for 12" more 6' long. We chiseled out the rivets along the roof and slid the sheet under the roof tin, transferred holes and re-riveted! We needed to cut a "pie" out on the sides so the angle matched the door and lined up with the roof. We then welded the pie together (our only welding on the bus). These sheets were $40 and a dog bite, yup the fabricator bending the steel for us, his dog got me on the back of the leg, but I'm fine though!
The Bumpers are made of 3/16th steel plate. they were made into C channel 2"x14"x2" for a cost of $280. We then "pied", heated, bent and welded the corners. We welded bolts in position on the backside to make it a bolt-less bumper. I then brought them to work ( a machine shop) set them up on a boring mill and put all our holes in. We're still pissing with the bumpers a bit but they look a hell of a lot better than the original guard rail style bumpers that were in it!
And to date we are at 1100 rivets used with another 250 piece box coming!
05-14-2010, 01:22 AM
#22
Re: Slab Cab'n
Well ordered up a set of these simulators for our Dayton rims
http://www.rvwheel.com/22daspwhsi.html
And have the automotive paint, primer, activator and thinner ordered up. Going to try to finish sanding, wash, wipe clean with thinner, mask and spot spray our primer on this week end. Leaving the "real" paint job for next week end (Canadas May 2-4 long week end) Paint, primer and supplies came to just shy of $1000. Cheaper than we had thought! SO hopefully I'll figure out how to post picts up here again soon and in a few weeks you'll get to finally see the finished product! 3 1/2 years in the making!
05-15-2010, 09:09 PM
#23
Re: Slab Cab'n
Finally figured it out again....hope the picts do it justice
And it begins - rust removal
The insides
Definitely better
New rust-free side
05-15-2010, 09:14 PM
#24
Re: Slab Cab'n
Passenger side half done, need to remount the rub rail to cover the seam
aahh what are we gonna do with this....aargh
New 1 piece back corners
New Back bumper
05-15-2010, 09:18 PM
#25
Re: Slab Cab'n
Corner shot with new bumper fitted
Modified hitch to fit bus
New front bumper
Final prep work before a bath, then the next day was thinner wipe down and taping before primer round 2
05-15-2010, 09:21 PM
#26
Re: Slab Cab'n
Bumper and light bar off, bondo done...getting oh so close
Lean-to ... AKA our paining booth for the next 10 days
Priming time
Here we go
05-15-2010, 09:23 PM
#27
Re: Slab Cab'n
Gonna paint the roof white tomorrow and the white stripes down the side, hopefully mask some more this week and paint the silver stripe. Then we can knock out the burgandy next week-end and start to put it all back together again
05-16-2010, 01:12 AM
#28
Moderator
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Re: Slab Cab'n
This picture reminds me of another bus stuck in the sand.
05-16-2010, 08:43 AM
#29
Re: Slab Cab'n
That picture was taken in one of Eldoras camp grounds. For the Wolrd 100. Race was rained out for Saturday night but they had it Sunday afternoon. This was Sunday morning. the front bumper stopped 3 feet from the highway. We sat on the bus saturday night and watch some movies, it rained so much our cooler chests were floating outside! That is why we installed truck horns thru the front bumper now!
05-16-2010, 01:10 PM
#30
Coachwork: THOMAS
Chassis: SAFE-T-LINER
Engine: CAT 3116
Rated Cap: 83
Re: Slab Cab'n
That is some nice metal work. Are those all 4x8 pieces of stock steel fabricated? Or did you get body panels from Blue Bird?
05-16-2010, 08:22 PM
#31
Re: Slab Cab'n
We had a local fab shop take 5x10 sheets and shear them in half, then brake (bend) the bottom 1" at 90deg so the sheets had rigidity! Worked out great, had a bout a foot left over on each side. It is actually skirted down about 3 more inches too!
If you ordered from Blue Bird I assume you'd get a sheet that went up and down, from the bottom of the windows to the bottom of the skirt. We only really had rust from the rub rail above the wheel wells and a LOT on the back, so it made more sense to just replace what we needed!
05-16-2010, 08:32 PM
#32
Re: Slab Cab'n
Shot from the top
Gloss white on the roof
and down the sides
and across the back
Heres a sneak peak from an artists rendition
05-16-2010, 08:49 PM
#33
Re: Slab Cab'n
Oh ya I fab'd up a new exhaust pipe. It is 2 - 5" Chrome pipes with a 45deg bologna cut on the end
05-17-2010, 07:53 PM
#34
Coachwork: Thomas SafTLiner
Chassis: FE
Rated Cap: 60
Re: Slab Cab'n
Cool looking exhaust!
Are you going to paint your wheels? I have the same wheels, and can't decide whether to paint them a different color, or maybe just a shinier coat of black.
05-17-2010, 09:39 PM
#35
Re: Slab Cab'n
05-18-2010, 07:23 PM
#36
Moderator
Re: Slab Cab'n
That's a very cool paint design. I like it.
05-18-2010, 08:30 PM
#37
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Re: Slab Cab'n
VERY NICE. That is a nice paint scheme!
05-19-2010, 01:52 PM
#38
Re: Slab Cab'n
I believe I may have to have a set of those myself I don't know why, but I was under the impression they didn't make simulators for Dayton wheels...so I'm glad you posted this
If you give us 2 weeks I'll get a picture with them mounted!
Thanks BUSBOZO and crazycal
05-19-2010, 07:31 PM
#39
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
Re: Slab Cab'n
HI,,, I HAVE A 94 BIRD AND WANT TO KNOW HOW YOU ATTACHED THE PANNEL TO THE WINDOW FRAME ? I DON'T SEE ANY REBITS NICE JOB AND TO WHAT SIZE DID YOU CUT THEM TOO FOR EACH WINDOW
THANKS KEITH
05-19-2010, 07:43 PM
#40
Re: Slab Cab'n
Hey, Keith not sure what size of tin we used but I remember how we did it, no pictures either. We took the windows out and discarded them. Then I measured the hole, when I orderd the galvanized tin for them, I had them add an 1" in height and width, got the tin back and glued them to some 1/2 plywood the same size stacked them up and set a very heavy object on them for the night so they could dry. When we went to install them, we caulked them in place, and screwed them from the inside using small "L" brackets and wood screws in the plywood and self tappers into the window braces. Hope that helps.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
A movie with slab city in it
CAMO-MONSTER |
Everything Else | General Skoolie Discussions |
0 |
06-21-2009 03:42 AM |
