05-20-2010, 07:46 AM
#41
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
Re: Slab Cab'n
thanks man ,,,iam all ready pass pulling the window out,so i guess iam going to have to put the tin over the window itself,my bus is done..
05-20-2010, 11:12 AM
#42
Re: Slab Cab'n
Good Luck with that one.
05-21-2010, 10:19 PM
#43
Re: Slab Cab'n
The rest of the paint showed up today, long 3 day weekend ahead of us...
White roof and stripe painted already, and taped off...
Its GO time, pictures to follow sun-mon.....
05-22-2010, 04:12 PM
#44
Re: Slab Cab'n
Heres the silver we're using for the stripe, and the tow hooks
and the silver stripe
the burgundy on the back of the bumper
and some loose pieces with burgundy on them.
05-22-2010, 10:10 PM
#45
Re: Slab Cab'n
Looks good!
05-23-2010, 06:28 PM
#46
Coachwork: THOMAS
Chassis: SAFE-T-LINER
Engine: CAT 3116
Rated Cap: 83
Re: Slab Cab'n
CAN'T WAIT TO SEE THIS DONE!!
05-23-2010, 10:54 PM
#47
Re: Slab Cab'n
And a bit more, tomorrow we pull the tape off.
Back bumper
Front Bumper
Nose
Front corner
Back corner
Back door sneak peak, and yes the bondo felt smooth, but the red sure shows up the bumps in it,,,
Burgundy, white, silver white, and a 14" burgundy bumper yet
05-24-2010, 01:21 PM
#48
Re: Slab Cab'n
Well we had high hopes of peeling tape today, BUT when we backed her out in the light the burgundy was very blotchy, so on top of the 5.5 hours of painting we had into the burgundy we put another 5 hours into it today and have about 7-8 coats everywhere! Hopefully the tape comes off tonight.
05-24-2010, 07:37 PM
#49
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Re: Slab Cab'n
Looking good. Too bad about the rear door. Next time what you want to do is hand block the filler with something straight and long with the sandpaper on it. Then when you think you have it as straight as possible. Shoot it with a coat of primer. Let dry. Then you want to hit it with some black spray paint out of a rattle can. This is called a "guide coat".
You don't need a heavy layer of the black. When that is dry, take your sandpaper on your block and use long even strokes across what you just painted.
All the low areas will still have the black paint in them. The high areas will have no paint (from being sanded off). This will tell you you need to add another skim coat of filler to the entire area.
Repeat process until there is NO black paint after sanding, indicating NO low areas. Reprime, then add color. This can be very tedious. All depends how picky you are.
If you want to fix the area, you will need to wait until the paint cures. Then sand down to the filler and start process above.
05-24-2010, 08:17 PM
#50
Re: Slab Cab'n
What the main problem is with the back door is, when we first got the bus, the back door was in rough shape, and we decided to loose the bottom window. We only covered it with thin body metal and used the body to clean up the edges. We shoulda got some thicker gauge and riveted it to the outside to put some sturdiness into it. And yes you are very right as to how much work you want to put into it, and both of us don't like body work too much, so we'll live with it. But thanks about the info on the correct way to fix that issue!
05-24-2010, 08:27 PM
#51
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Re: Slab Cab'n
Anytime! Good luck!!
05-24-2010, 08:39 PM
#52
Re: Slab Cab'n
TAPE IS OFF....with minimal boo boo's
Tape off
From the back
New simulators, and dual 5" Chrome pipes
From the drivers side
Front simulator
Back simulator
05-24-2010, 08:43 PM
#53
Re: Slab Cab'n
looks awesome!!!!!!!!!!!!!
05-24-2010, 09:25 PM
#54
Coachwork: Ward
Chassis: Ford B600
Engine: 6.6L Turbo Diesel
Rated Cap: 26
Re: Slab Cab'n
WOW I can't BELIEVE my eyes!!!!!!
05-24-2010, 09:45 PM
#55
Year: 1978
Coachwork: thomas
Chassis: ford
Engine: 406 Ford
Rated Cap: 25
Re: Slab Cab'n
Man, that's a fine job. Your hours into it sure show.
Busbozo- the long block technique you mentioned is gold. Thanks. Little gems like that make my time here well spent.
05-24-2010, 09:49 PM
#56
Re: Slab Cab'n
Thanks guys...we appreciate it...learned lots on here over the years.
I think what I like about the paint job most is you barely notice the 2 rub rails any more!
05-24-2010, 10:01 PM
#57
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
Re: Slab Cab'n
Looks great, hard work really paid off.
05-24-2010, 10:56 PM
#58
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
Re: Slab Cab'n
oh great now we are all gonna have to paint up our busses that nice.That thing looks great! i see many hours there.....timbuk
05-25-2010, 04:40 PM
#59
Re: Slab Cab'n
Looks great!!! Even my picky daughter likes it, despite it not being pink and purple.
05-25-2010, 09:17 PM
#60
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Re: Slab Cab'n
No problem Bus-ted! I eat up the same little tricks of the trade when I see them on here also.
WOW. Those simulators look great. Those really clean up a bus conversion!
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
A movie with slab city in it
CAMO-MONSTER |
Everything Else | General Skoolie Discussions |
0 |
06-21-2009 03:42 AM |
