Old 02-19-2014, 01:22 PM   #41
Re: Sloppy Yellow
Purchased 427 lbs of steel for the roof rack today. $280. Another $120 for bolts and parts and it'll be done. Hopefully….
DanMan80 is offline   Reply With Quote
Old 02-19-2014, 01:23 PM   #42
Re: Sloppy Yellow
Bought a heat gun to remove all the lettering. Works awesome.
Old 02-19-2014, 08:55 PM   #43
Engine: 190hp 5.9 Cummins
Re: Sloppy Yellow
Thanks for the pics.
Old 02-21-2014, 09:37 AM   #44
Re: Sloppy Yellow
Looked at dozens of bunk bed designs & kinda worried about attaching them to my bus since I'm not particularly handy. Then yesterday I came up with an idea; since I'm already drilling holes in my bus, use longer bolts to secure my verticals to the bus & attach 2x2 material to it on the inside for the bed frame.
Grade 8 bolts, 8" long will do the trick nicely. Any qualms regarding using 2x2's for bed frames??
Old 02-21-2014, 09:52 AM   #45
Re: Sloppy Yellow
Very handy. It's my dads, and older than I am.
Old 02-21-2014, 09:54 AM   #46
Re: Sloppy Yellow
Inside the bus looking at a 6" bolt inserted from the outside. Grade 8, 3/8" from Fastenal.
Old 02-21-2014, 09:57 AM   #47
Re: Sloppy Yellow
I'm hoping this will work out. I guess I could always use 2" Square Tube 11 ga, but it's def more expensive.
Old 02-21-2014, 11:25 AM   #48
Rated Cap: 47
Re: Sloppy Yellow
Every time I read the name of this bus I think of an ex girlfriend from a long time ago.
Motobus is offline   Reply With Quote
Old 02-21-2014, 01:24 PM   #49
JakeC's Avatar
Re: Sloppy Yellow
I would put a lock-nut (or a regular nut with Loctite) under the 2x2 first. You don't want a compressed 2x2 responsible for keeping tension on the bolts that hold your rack up!! Put a nut on the bolt and tighten against the metal of the bus, drill 2x2 large enough to go over nut, use large washer and second nut to hold 2x2 in place.
Brutus
Old 02-21-2014, 02:06 PM   #50
Re: Sloppy Yellow
Thats exactly what we're going to do. I figure we'll rout an "inset" on the bus side of the 2x2 so the lock nut will fit snug. I appreciate your comment as we didn't think of that until we looked at the picture!
Yellow bus illegal where? rlohrey Conversion Tutorials and How-to's 38 01-24-2015 10:35 AM
the big yellow beer can jolly_rogger Skoolie Conversion Projects 18 09-11-2011 06:37 PM
Yet another reason to not have a yellow bus baadpuppy School Bus News 1 08-24-2009 10:30 PM
yellow bus paint jeephauler Conversion General Discussions 14 02-25-2007 09:25 AM
How much school bus yellow can I keep? Branden Conversion General Discussions 2 06-03-2005 06:26 PM
