Old 03-16-2014, 01:44 PM   #141
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126b Rotella-Chugger
Re: Smells Like Teen Spirit: Conversion of 1999 Thomas MVP
Side note, with the insulation in and even with the bus windows, that little electric 1500 watt heater makes a significant difference in inside temp. Can't wait to see what it does once the floor foam / ply is in.
porkchopsandwiches is offline   Reply With Quote
Old 03-16-2014, 07:06 PM   #142
Docsgsxr's Avatar
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
Now all you need are some alternating laser lights and a disco ball!
looking good man! Cant wait to get back to Alabama to work on mine, although I love 83 in Phoenix!
My build thread - viewtopic.php?f=9&t=467197
Old 03-23-2014, 08:02 PM   #143
Got a bunch done this weekend.
Got about 2/3 of the subfloor and 1/2 inch insulation in (not much insul but better than nothing).
Also anchored in the walls that are made out of doors. The foremost section is the crapper, with I fabbed out a 24-and-some-change inch wide opening, and I will either make an actual door out of the rest of the solid core doors I have, or buy a bi-fold closet style door to open inward. The middle bit is going to be a closet of sorts, probably containing utilities and room for other stuff. The rearmost section is a shower.
Better shot of shower. I am going to line the walls with FRP, caulk in and all that jazz, and rivet and seal in some aluminum flashing type metal (ex in a larger sheet) to the ceiling to keep water vapor from getting into crevices. The shower is right under a emergency exit which pops up for ventilation, nice feature. So the aluminum ceiling will direct shower steam (assuming I find a water heater that works good) into the roof vent, to outside.
Got my cabinets today, also free, and placed them in to move them around. It is a convenient material but I am not 100% on using the doors as a countertop. It is too much of one color in one area. I may go with ply or OSB (both with a heavy coating of poly) instead for a lighter color to contrast the dark wood. The countertop section will be cut in front of the emergency exit door and on hinges to hinge down so the door is still usable.
It is a nice roomy layout in my opinion.
Alternate view of bathroom. I will be using trim very liberally to cover all the oddities.
I will be buying something like this to mount to the emergency exits for when the vents are popped up. Sucks in air from inside and blows it out, would be nice for cooking ventilation, to cool off at night, and just get fresh air in without opening all the windows like if its raining. I just need to find them in the right size / capacity and in 12 volt.
Old 03-23-2014, 08:17 PM   #144
browncrown's Avatar
Rated Cap: 79 at Birth
Great progress...everything looking real nice!!!
BC
Old 03-23-2014, 09:09 PM   #145
Docsgsxr's Avatar
Did you build your stalls on top of the sub floor or directly on the metal flooring?
I am so envious! I want to work on mine so bad but now I'm at work in new hampshire....
Patience is not my best trait.
Great work dude!
Old 03-23-2014, 09:16 PM   #146
Thanks everyone. I built the partitions and then laid the floor, the brackets are screwed into the doors then screwed into the metal of the floor, no wood or insulation between.
Old 03-27-2014, 10:04 AM   #147
wmkbailey's Avatar
Engine: 3126
Man prokchop you are making good progress. I need to get back to my bus too, you are making me look bad.
William
http://thejourneyvisvi.com/
viewtopic.php?f=9&t=464989
Old 03-30-2014, 07:57 PM   #148
*accidental post*
Old 03-30-2014, 08:04 PM   #149
Yeah man get back to it! Let me know if you need help.
I didn't get anywhere near as much as I planned done this weekend because it was raining almost the entire time, then started wet-snowing, and got cold. Lame. So I did what I could.
Cut the countertops and cut out the sink, it is not installed but just sitting there (for now). It weighs like 100 lbs, cast iron Kohler unit. Got it for $40.
Got a fridge, 10.7 cubic foot Whirlpool from Best Buy, $404. Fits nicely, will run off the inverter when driving.
Shower in case I haven't posted a pic yet. FRP paneling will be on the sides.
Rear bed platform, right now a workbench. Wide enough to fit a "full" size mattress. Tons of storage underneath.
Originally the fridge was going to go here, but it stuck out too far, so I am using it as a closet. Once I buy a microwave I will put a shelf on the top for that and the rest will be a closet.
The crapper. With a bit of wheel well intrusion that will be taken care of.
View from the back.
View from the front.
Cabinets. Between the two I will be putting a counter section on hinges with a latch, that can hinge down so the door is still usable.
I would like to reiterate that all the walls and countertops, and the floors of the closets are made out of used solid core doors that were free. They are pretty heavy, but I highly reccommend them, it was nice to not have to frame out walls. I am planning on running wiring in exposed PVC conduit for kind of an industrial look so not being able to run wiring in it is not an issue. Some of them have a sheetrock-like center, these were fire-rated doors. Some were just particle board all the way through. They are considerably heavier but stronger.
The cabinets were also free. And the OSB is $8 a sheet (if you can deal with the smell and how easily it caves to water exposure). I think I will seal it with poly before I put the top flooring down, just to be safe.
I have been messing with designs for a booth, which will go in front of the crapper (passenger side of the bus) across from the kitchen cabinets. Here is what I have to far:
It is roughly 7' long overall, 32" wide (we are all pretty skinny, ha). The idea is the tabletop will be able to come down (remove poles) and sit on the seat bottom once cushions are removed, and be usable as a bed, a "twin" air mattress will fit over it. Thoughts?
Looking forward to 70+ degree weather for part of this week.
Old 03-31-2014, 08:41 AM   #150
Docsgsxr's Avatar
That is the exact table design I am going to use, however, I am going to buy a memory foam mattress for the bed, and cut the mattress so it will remain on the benches when used as a table, and then have the small part to put on the table top when it is dropped down to make the bed. That way I don't have to store an entire mattress. If you have someone who is (or if you are) handy with a sewing machine, you can create removable covers for each part so you can just strip and launder the covers. (Plus the piece that you store can be put into a vacuum bag and put underneath the bench. It will regain its shape when you open it up!)
I like the fridge. I saw one at lowes that was stainless for about the same price. Think I am going to get that one.
Love the progress you are making. Maybe after this summer you, me, and wmkbailey can all get together for a "family portrait" of our rigs!
-Doc
1999 Chevy Escort FE Bus Conversion Bullwhacker007 Short-Bus Conversion Projects 28 03-04-2018 04:57 AM
The Journey Visvi 1999 Thomas MVP ER wmkbailey Skoolie Conversion Projects 873 08-10-2016 04:13 AM
1999 Goshen 15 passenger rv conversion highpsiguy Short-Bus Conversion Projects 28 04-11-2015 08:07 AM
1991 Thomas conversion Will Skoolie Conversion Projects 16 06-24-2013 03:03 PM
Thomas E-350 Shuttle bus conversion crazycal Short-Bus Conversion Projects 8 05-22-2013 12:50 PM
