10-17-2016, 11:02 PM
#401
Keep on truckin' guys! Great to hear of your adventures.
12-21-2016, 06:54 PM
#402
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126b Rotella-Chugger
Hello everyone,
So I have (finally) been drawing up designs for solar for my rig. It looks pretty simple. It is third in my to-do list, after 1) tires and brake inspection, and 2) reinstalling my webasto, getting the heater lines bled and adding an "auxiliary" radiator, made out of an old heater core from the back of the bus. I run into overheating issues in the summer even with a new radiator, so I figured additional cooling would help considerably.
For solar, I found the following charge controller:
https://www.amazon.com/Solar-Boost-3000i-Controller-SB3000i/dp/B0179V9JQI
This controller is "MPPT" style, which to my understanding, allows for better utilization of power from the panels. In addition to this, it can regulate voltage more effectively, and allows you to use higher wattage, higher voltage 60-cell panels like you'd put on a house, rather than 12 volt system specific panels. The controller maxes out at 280 watts on higher voltage panels, I believe. I haven't done extensive research on this yet, as I just got done with final exams and have been busy with work, but any insight on this setup would be appreciated.
I believe this in conjunction with my four 6-volt, 225AH batteries that I've been using, would work great in sunny Colorado. I'm not 100% sure if it would be enough to power my 120 volt fridge, but it would more than cover usage from lighting, fans, phone chargers, stereo and the domestic water pump. As of now, we've operated 3 days on batteries alone running all those devices before the voltage was too low. I don't have great figures on my electrical usage as I don't have an ammeter or watt meter installed, but with the LED lights and minimal electric motor usage, we don't use much power at all. I think this controller in conjunction with a ~260 watt panel would be more than enough to keep my batteries topped up.
I'm planning on moving my webasto heater to the front of the bus, as there's a ton of space underneath the front, and a large 12 volt line to the house batteries is right there. I was going to plumb this into the line coming from the engine, before the front heater core, and have the auxiliary radiator plumbed up front, off the heater lines, with gate valves in front of it. I'll post up a drawing soon so it makes more sense, but basically it'll allow the heater lines going to the front of the bus to be used as aux heat in cold weather, or an aux radiator in hot weather, but without using the heater inside the bus as a radiator, if that makes sense. Not the most elegant setup, but functional.
Before all this, I need at least one tire. Preferably used, as I can't justify getting new tires for something that sees fewer than 5,000 miles per year (usually). The rear passenger side outer has major curb rash from previous operators rubbing the curb all the time, and the sidewalk is starting to bulge. Any thoughts on truck shops / used truck tire suppliers in the Colorado front range area would be appreciated.
Thanks in advance for any advice!
12-21-2016, 07:05 PM
#403
Also, do I hold a record for most views of a thread or what?! 236,000!
12-22-2016, 05:21 AM
#404
Engine: Caterpillar 3116
Rated Cap: 78?
very cool, nice find.
12-22-2016, 05:51 AM
#405
Year: 92
Engine: DTA360 5.9L
your view count is ridiculous, a year and a half ago when i got on this site and yours was here, i think it was around 120,000. so thats almost 100,000 views in a whole year, crazy!
12-22-2016, 08:54 AM
#406
I do know that it was your thread that caused me to register...
So, I guess everyone can blame you for creating this monster
12-28-2016, 11:41 AM
#407
Hey everyone,
So I drew up a drawing of my plans for how to plumb the heater lines to the front of the bus. Currently, the lines are in place, but the Webasto is not mounted. I am planning on mounting this under the front of the bus, as there is a lot of extra room and the wiring is right there.
My second idea was to take the rear heater core that was formerly in the back of the bus, currently not hooked up because I could never get the air out of it the way I had it mounted, and mount this under the front of the bus, along with the electric fans on it, to be used as an auxiliary radiator to attempt to combat my occasional overheating issues and add a little extra cooling.
I was wondering if anyone had thoughts on this and whether or not it sounded like a stupid idea. I have all the parts to make it work minus a few gate valves and barb fittings, and I drew up a rough diagram of how I would plumb it:
The idea being I would use the two gate valves to the front heater to shut off flow to the Webasto and inner heater loop when it is warm outside and I need the extra engine cooling, and then open those and shut the ones off to the auxiliary radiator when it is cold out and I no longer need the additional cooling.
Does this sound excessively complicated just to avoid pumping extra heat into the cabin? Should I just forget about the extra radiator underneath and use the main heater inside the bus for aux engine cooling when needed?
Also, how does the placement of the Webasto look in the loop, does this make sense the way it is routed?
Any advice appreciated. Thanks!
12-28-2016, 12:55 PM
#408
Chassis: Blue Bird
Engine: ISC 8.3
Seems reasonable to me. I too have been thinking about using an extra body heater, or a junkyard radiator, for a little extra summertime engine cooling.
I've often wondered why there should be a valve on both the supply and the return line. So far as preventing flow where you don't want it to go, it would be adequate to put a valve in the supply side only (for example). Is it for service or in case of downstream failure that valves are put in the return lines also?
12-28-2016, 01:06 PM
#409
In my mind, the reason for shutoffs on both lines is because I feel like if you leave the return without a valve, the pump(s) might pull vacuum on the line, in effect pulling some coolant from that part of the loop. The stock heaters on my bus had a shutoff at the supply and return. Though this was probably more for the purposes of being able to isolate the heater loop / engine without having to drain it all, I think it would flow more happily with both sides having a shutoff, but maybe I'm crazy. I figure it's another $8 for an extra valve, and even if it doesnt help with flow, it would make replacing a leaking heater core easier down the road.
12-29-2016, 09:35 AM
#410
Just read through the entire thread....thanks for sharing. Hope you don't sell it, you'll regret it.
I can't believe you didn't have any tire issues on your cross country trips...did you carry a spare? or a way to change a tire?
I see you're staying in school? What are you studying? Still driving the E30? Did you tow it behind the bus to CO?
Looking forward to the solar updates and what you end up using.
1967 M109 Deuce and a Half
platetees.com
12-29-2016, 12:34 PM
#411
Yeah I know I'll regret selling it if I ever do, I won't get 1/10th of what I have into it!
I have still not had any tire issues, after about 20,000 miles of road trips. I am on borrowed time with these. I do not carry a spare. When I get back to CO I am going to call a few truck shops and get prices on used tires, I can't justify putting new tires on this thing with how little mileage it sees. Used tires that are higher mileage but not as old as the ones on it would be best. The passenger side rear outer has a bunch of curb rash (not from me) and needs replaced pretty bad, I think I saw it starting to bulge a while ago.
I am at school at CU Boulder studying Environmental Science. I still have the same E30, I drove out there in January of this year, no issues (never had any issues with that car). I actually got a job as a mechanic with an auto broker who deals with a lot of E30s. I don't have a vehicle towing setup on the bus as of now, and no plans for one.
I should be able to get rolling on solar as soon as I get back, there's not a whole lot I need to do to prepare for that. I'll post pictures of the install, if I remember to actually take some pictures this time!
12-29-2016, 06:51 PM
#412
Engine: 8.3 Cummins ISC
Rated Cap: 75
Do you ever regret not removing the stock school bus windows and skinning them over with sheet metal?
12-29-2016, 07:05 PM
#413
For how I use the bus, no. I use it as a "fair weather" bus, for leisure, generally. For my purposes, leaving the school bus windows in adds to the charm of it being a school bus conversion. Visibility is great, and the amount of light you get inside during the day is excellent. If I was building a full time rig, I absolutely would have removed the windows and skinned them over, as I don't even want to think of how inefficient the school ones would be to heat with when it is single digits outside.
12-29-2016, 07:39 PM
#414
Engine: GMC
Rated Cap: 42
You are so right. Our bus is also a fair weather bus and we love the light. We can handle anything down to about 20 degrees without any problem and the wife would not have supported the whole project if it was dark as a cave.
12-29-2016, 08:50 PM
#415
Yeah. We slept in it for like 5 days in Asheville, NC a couple years ago when I had the Webasto hooked up as the main heat source. It was about 20 degrees outside, and I had no temperature control wired into the webasto, thinking it wouldn't be able to keep up, and it got so hot in there we all woke up and opened the roof hatches.
I went inside this German dude's bus in NOLA, which I saw in an RV park there. He invited us inside, the windows had been skinned over, and it was super dark. For a non-fulltime setup, leaving the skoolie windows in is the way to go in my opinion.
12-30-2016, 10:21 AM
#416
I hate dark and dreary interiors.. (unfortunately I see alot of them in RV's and conversions).. if my bus gets cold I'll add more heaters.. if it gets Hot i'll add more Air-conditioners..
im keeping all the windows..
double pane skoolie windows do exist.. ive seen them in videos of alaska Busses.. bluebirds and thomas's
12-31-2016, 05:51 PM
#417
Hey Porkchops,
I just read your entire thread the past few days and first off great job buddy! No wonder your the view champ here you actually take the time to quote and respond to people which is really nice and very respectful. Your parents, by the sounds of them, must be very, very proud of their boy. I hope your studies are going well and you land yourself a career you actually love. Don't for the life of ya sell that bus my son. There are so many possibilities with it, just parking it at a decent park and going to it on weekend's makes it invaluable. Then there's always a road trip North to visit the Canadian country side, summer of course, winter's are worse in most parts here than anywhere in Minnesota. Just a heads up there.
I have so many notes from your build that will definitely be worked into mine when it's my time. I'll be waiting for the May/June auctions to buy my rig this summer. I'll be avoiding the Cat for sure. Thanks for all your experiences you shared and each helpful tip. I'll be waiting to see how your Solar array turns out.
Watch out for crabs, they're not always in the ocean. ;)
Kelly John
12-31-2016, 10:40 PM
#418
01-11-2017, 08:42 AM
#419
Rated Cap: 75
Forgive me for asking a late question, but were you able to configure the Webasto on your bus as a primary heat source?
Is it a viable alternative to a propane furnace or a woodburning stove?
I'm in a similiar situation as yourself, younger guy that is very tempted to make the jump into the skoolie world. I actually drive school buses as a part time job so I'm very familiar with them and know exactly what I would want in a skoolie conversion.
01-11-2017, 02:22 PM
#420
No worries! Personally I wouldn't use a webasto as a main source of heat when parked. I think propane would work better for long term parked situations. I'm installing the webasto to aid in cold starting and warming the engine up on cold days, and keeping the heat acceptably warm when driving it on cold days. I'm buying a portable propane heater for long term use when parked and running it off a 20lb cylinder, because I don't want to invest a bunch of time and $ into a heating system I won't use all that often.
Wmkbailey (journey visvi thread) last I checked uses a webasto as a main source of heat. You might ask him, first if he still uses it as the main source, and what fuel costs. The thing about the webasto is it smells like a diesel truck when running and I wouldn't want that smell around all the time when running the heat. The way my webasto is run I don't have it able to shut off circulation to the engine, so if I was running the webasto I'd be heating the engine when parked which would be a huge waste of energy. Also my coolant lines are run under the bus which would waste more energy. So for long term heat I was going to get a "Mr buddy" propane heater which is reasonably safe to leave on all night (has a low oxygen shutoff) and cheap to buy, which is good since I don't use it in the cold that much.
Let me know if you have any questions.
