Old 01-12-2017, 12:17 PM   #421
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126b Rotella-Chugger
Picked up my PV panel, going to build a mount soon, and start hooking it up when it gets warmer out!
porkchopsandwiches is offline   Reply With Quote
Old 01-12-2017, 03:15 PM   #422
what charge controller are you gonna use? How many batteries ( or just hooking to the cranking batteries?)
did you find better deals that just purchasing a kit?
1967 M109 Deuce and a Half
platetees.com
onemanarmy is offline   Reply With Quote
Old 01-12-2017, 03:43 PM   #423
I am using a blue sky solar boost 3000i MPPT controller. It works with higher voltage 60 cell panels and can convert a 35 volt panel to a 12 volt system. I have four 6 volt 225AH batteries I've been using, and the MPPT controller has a separate charge output for trickle charging the starting batteries, so the banks would be stored separately. I couldn't find a kit that was quite like this, and all in I am about at $500.
Old 01-12-2017, 05:36 PM   #424
Nice. Thanks for the info.
Sent from my Moto G (4) using Tapatalk
platetees.com
Old 01-18-2017, 06:37 PM   #425
Engine: CAT 3126b 210hp, MT643
Hi. My name is Kevin and I am new. I have a 2001 Thomas similar to yours. I have the 3126 CAT engine as well. I have a question about the blow by. Do you get little oil specs on the back after a trip? Mine had little specs after a 2 hour drive. Not much, but I believe it was coming out the breather. Mine doesn't appear to leak oil while sitting and idling. Are the blow by specs normal for this engine?
atx200416 is offline   Reply With Quote
Old 01-18-2017, 08:40 PM   #426
Chassis: International S3800
make sure your oil isnt over-full.. if someone over-filled it you will end up getting oil blowing out of your blow-by draft tube..
Old 01-22-2017, 04:46 PM   #427
Yeah I do. I would consider it normal for a high mileage highly worn engine. As long as your oil consumption isnt absurd id say its fine.
Old 01-22-2017, 04:47 PM   #428
Yeah I got my oil changed at a place in nebraska on a trip, and they overfilled it by a gallon. Haha.
Old 01-22-2017, 05:17 PM   #429
Thanks
Thanks for the reply. You are an inspiration. I have read your whole thread. Mine is at Freighliner getting the front drivers side windshield replaced. I have a couple of things I need to fix myself. I also need to change the fluids and filters. I'm excited for this project.
Old 01-22-2017, 05:21 PM   #430
I am going to change the oil when i get it back from Freighliner. I am going to see if it looks overfilled. They did overfill the coolant, so it is a possibility. Thanks.
1999 Chevy Escort FE Bus Conversion Bullwhacker007 Short-Bus Conversion Projects 28 03-04-2018 04:57 AM
The Journey Visvi 1999 Thomas MVP ER wmkbailey Skoolie Conversion Projects 873 08-10-2016 04:13 AM
1999 Goshen 15 passenger rv conversion highpsiguy Short-Bus Conversion Projects 28 04-11-2015 08:07 AM
1991 Thomas conversion Will Skoolie Conversion Projects 16 06-24-2013 03:03 PM
Thomas E-350 Shuttle bus conversion crazycal Short-Bus Conversion Projects 8 05-22-2013 12:50 PM
