Old 10-21-2013, 12:30 AM   #41
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126b Rotella-Chugger
Re: Smells Like Teen Spirit: Conversion of 1999 Thomas MVP
We came up with a good name: THE DROPOUT
porkchopsandwiches is offline   Reply With Quote
Old 10-24-2013, 01:54 PM   #42
Not much progress in the last week or so, I have had to work more at school to keep passing grades so no bus time...I received some closed-end rivets that I will use to seal up holes in the floor and for sheet metal patches. I also recieved a gallon of "OSPHO" rust treatment - phosphoric acid-based liquid that you pour on rusty metal and it converts iron oxide (rust) into iron phosphate which is harmless to metal. You then paint over that. I will be using that on the floor after scraping / wire wheeling.
I picked up this gem for $40 today:
Not 100% sure if I will use it, but it came with full plumbing for the faucet and how often do you find a red sink?! It is a great size for the kitchen area. Very heavy too.
Old 10-24-2013, 03:20 PM   #43
wmkbailey's Avatar
Engine: 3126
Red looks good with dark grey and that matches your seats.
The weather and work has slowed me down so too.
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 11-05-2013, 01:58 PM   #44
I got a bit of a chance to work on the bus this weekend. I had been spending time attempting to do better in school and got rather sick for a few days. It is very, very hard to concentrate on schoolwork with this project going on.
I have been working on this and that, experimenting with different projects. I bought a gallon of "OSPHO" rust treatment; basically stuff you brush on and it turns iron oxide (rust) into iron phosphate, which doesn't harm the metal (science!).
I took out all the side panels and insulation that I could get to. There is still a bit of insulation behind the thicker metal left by the floor. This metal has a ridge at the top that the seats bolted to, and I am planning on cutting this off because it will get in the way of my walls. I am leaving some of the metal, because it is structural, it appears. You can see a few of the holes I cut in the floor to isolate / remove any really heavily rotted / rust through areas.
Here is one of the sheet metal patches marked up and ready to cut.
Here is the hole in the floor it is going over (poor photo).
And here it is welded in.
Done with a Hobart 120 volt MIG welder with flux-core wire.
A few more patches...
And I have yet to do this one. It is a bit tricky. It's also fun having to do this by yourself and right after welding, throw off the mask and run under the bus and put out fires (burning undercoating).
I plan on sealing the seams from underneath and above with polyurethane seam sealer (automotive grade) once I am done with the patches.
Here is a test section of the OSPHO stuff. I quickly wire-brushed the area and just brushed it on. This is after about 10 minutes. I came back the next day and the rust had turned black, and it leaves somewhat of a coating on the surface. The stuff is $40 a gallon shipped on Amazon and is very strong, I highly reccommend it. I am going to do all the rusty floor areas with it once I am done patching. You just wire brush the loose rust off, paint the ospho on, and let it dry, then paint over the dried ospho.
Also, I picked up all these cabinets for free from an office being demoed. They fit well in the bus.
Later this week and weekend I will be finishing up the patches and wirebrushing the whole floor, (rusty areas) vacuuming it, wire brushing again, vacuuming again, and laying down ospho liberally. Then to let it dry and paint with some metal primer, and seal up with seam sealer. Before I can start on insulation I need to seal the roof completely, which will mean fixing the hatches (temporarily?) and painting the roof with several coats of elastomeric coating. I also need to pop out all the windows, scrape the old sealant off them, and silicone them back in.
Old 11-05-2013, 02:29 PM   #45
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
Damn good score on the cabinets
Old 11-05-2013, 04:27 PM   #46
x2.................. NO shiat!!
Old 11-05-2013, 08:33 PM   #47
wmkbailey's Avatar
Engine: 3126
I have the steel for my hatches on order. When I get it I will give you my hatches.
William
Old 11-06-2013, 01:05 PM   #48
Awesome! I can't wait.
Old 11-06-2013, 06:00 PM   #49
wmkbailey's Avatar
Engine: 3126
They got the steel cut today and I picked it up. We will have to remove the hatches this weekend. I just need to get some butyl tape.
William
Old 11-06-2013, 08:43 PM   #50
Year: 1974
Engine: Detroit Diesel 6-71
Seriously!
Ospho is awesome! Caustic as hell so be careful, but it really does work. I did a few spots on my truck with it (no wire wheel, just a sprayer) and it turned the rust completely black overnight. There's a spot by the drivers window on the bus that needs some rust repair and I'm definitely using it.
You're making great progress on your bus! Keep up the good work!
Proud new owners of a 1974 Crown Supercoach - the big rolling twinkie!
viewtopic.php?f=9&t=466562
inkblots84 is offline   Reply With Quote
The Journey Visvi 1999 Thomas MVP ER wmkbailey Skoolie Conversion Projects 873 08-10-2016 05:13 AM
1999 Goshen 15 passenger rv conversion highpsiguy Short-Bus Conversion Projects 28 04-11-2015 09:07 AM
1991 Thomas conversion Will Skoolie Conversion Projects 16 06-24-2013 04:03 PM
Thomas E-350 Shuttle bus conversion crazycal Short-Bus Conversion Projects 8 05-22-2013 01:50 PM
1999 Chevy Escort FE Bus Conversion Bullwhacker007 Short-Bus Conversion Projects 14 12-19-2011 08:51 AM
