Old 12-12-2013, 11:25 AM   #81
Diesel Dan's Avatar
Engine: DT466/AT545
Re: Smells Like Teen Spirit: Conversion of 1999 Thomas MVP
Originally Posted by porkchopsandwiches
I prefer a knob creek or a makers mark on the rocks, and if all else fails a gin and tonic.
Try Makers 46; it's way better than the original Makers Mark (I just tried them side by side last week). I'm with you on the Knob Creek - awesome stuff. But if you are on a budget, the best bottom shelf bourbon I've had is Ezra Brooks @ $13/bottle. And in the same category, and cheaper still, is Evan Williams @ $11/bottle, which is on par with Jim Beam in that it is "drinkable" but not nearly as good as Knob Creek/Makers 46. It is less than half the price though. Like most things, ya get what ya pay for...
Don't even get me started talking about Scotch, I'll fill up a page on that topic...
Cheers!
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 12-12-2013, 10:03 PM   #82
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
Please don't turn my page into a political debate...if you want to debate, let's bring our buses and meet up, last one there buys a keg. THAT is a good idea.
That doesn't make since...what are we going to do while waiting for the last person
you should buy the keg and we can partake when we get there
no waiting then
Didn't mean to turn it into a political debate, was honoring you & your spirit & ability to think & create
Old 12-15-2013, 10:43 PM   #83
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126b Rotella-Chugger
I installed some LED taillights:
Arguably unnecessary, but the left side signal / stop lights didn't work due to a ton of water leaking into them, they got rusted out. The new ones are sealed and entirely plastic. They are really bright! $20-25 a pop on Amazon. I also ordered LED marker lights for all around, adding 2 ambers per side. Anyone want the old ones? They still work fine, they just need some R&R. I also got 8 more LED license plate light deals to put on the pilars between the windows, 4 per side, for a cool effect. I may add some on the front and back later, but those are easier to get to when the inside is finished.
porkchopsandwiches is offline   Reply With Quote
Old 01-13-2014, 10:48 AM   #84
Finally getting back into the swing of things. I had been in the process of getting my bus ready to pass inspection, and I finally got it inspected and got tags. Due to an error on my part and an error on the dealer's part, the bus was sold uninspected, and MD state law requires dealers to sell all vehicles inspected. I didn't know this at the time, and I didn't think to ask for an inspection cert upon the sale. So I was caught in a catch-22 of not being able to register it and get tags (even temporary) because there wasn't an inspection certificate, and not being able to get it inspected because I couldn't get tags. The great state of MD. Eventually I just decided to drive it over to inspection tag-less, where I was passed by an officer without him batting an eye. I guess people leave army green buses alone.
I wanted to get it registered because my next door neighbor was letting me keep it in his yard. Very, very generous of him, but I have to say, the color it is, it really doesn't stand out too much.
I put on some new LED marker lights all the way around, $6 each from SuperBrightLEDs:
I added 2 per side for better visibility.
I got what every 19 year old guy asks for for Christmas, a Dometic RV toilet:
A 12 volt domestic water pump good for 55 psi:
Four of these roof vents, to which I will attach 12vdc computer fans:
And a power center, with slots for 120 volt breakers, a 55 amp 12 volt power supply, and 12 volt automotive style fuse slots:
Pretty good Christmas this year. Last year all I got was BMW suspension parts
So I finally got to drive it on public roads once it was registered (my cousin drove it up from where I bought it, and my uncle drove it to inspection) and it is pretty fun. Loads of low end torque on this motor, that quickly drops off as the RPMs climb. I guess the compressor wheel on the turbo is smaller for better low end but doesn't put out enough volume at the top end to keep the HP up. A variable geometry turbo would be a lovely addition to this motor (and a very expensive one). Most newer car and light truck diesels use VGT's so that they can rev higher and drive more like a gasoline car, while still keeping that low-end grunt that makes them so great.
The motor runs great on this bus, HOWEVER, I have noticed ridiculously high oil consumption, but it didn't seem to be going anywhere. There are no leaks, and the motor doesn't smoke at all, not even under acceleration. The blow-by is not excessive either. So I did a little research on the subject, and I was pretty sure I had a problem that never even crossed my mind: this engine uses a system called HEUI (Hydraulic [over] Electronic Unit Injection) which basically uses really high oil pressure off a separate oil pump to actuate the injectors, rather than an injector pump (like on the side of a 12v Cummins) or a cam-driven injector. This system works pretty well, but since both oil and fuel flow through the cylinder head, if a seal or O-ring goes bad on the injector, the two can mix, and send engine oil into the fuel return line to the tank (since the oil is at a much higher pressure than the fuel in that area). So I opened up the bleeder on the bottom of the first fuel filter and lo and behold:
This is fuel from the tank after it has gone through a filter. It is BLACK with engine oil. So I think it is safe to say that is my problem. I ran it by my cousin who is a diesel mechanic and he said that problem is not unheard of, and the fix is usually just to replace the O-rings on the injectors, which isn't too difficult or expensive. Worst case scenario the injectors need changed, which is about $165 each, but since the engine runs fine otherwise, this is unlikely. It was going through about a gallon of oil every 2 hours of runtime.
Here's how it sits now, right next door:
This week (hopefully) I will be insulating the roof, running wires for lights and speakers, and reinstalling the ceiling panels.
Old 01-13-2014, 11:37 AM   #85
she looks like she's hiding in the woods
Old 01-23-2014, 11:21 AM   #86
Not too much to update, I have been very busy and it has been very cold. I bought LEDs a while ago to convert the stock bus interior lights to individually switched LEDs, warm white, very bright. I wanted to use them because the holes were already in the ceiling. Here is how I did it:
Machine a rectangle for the switch in the lens with a drill press and brute force
Insert switch, and epoxy it on
These are the lights I am using. $80 for 20 of these on eBay with retrofit connectors for festoon, halogen and incandescent sockets. Hong Kong special, we will see how they hold up. Warm white, very bright, nice color.
All holes drilled and switches epoxied in
Harnesses made...solder and heat shrinked. I hate electrical tape.
Light boards siliconed in, all tested and working, ready for install.
Doesn't do it justice.
They will be individually switched (except the drivers, that has a dash switch) and also controlled by one main switch on the dash. Once it gets above freezing I will start installing insulation, the same way wmkbailey did (though not as much).
I hate winter!
Old 01-23-2014, 11:32 AM   #87
juliol's Avatar
Engine: 3208 turbo Cat
Well done, do you have the link for the LED lights on eBay?
Julio
juliol is offline   Reply With Quote
Old 01-23-2014, 12:01 PM   #88
AND SWITCHES PLEASE
Old 01-23-2014, 01:27 PM   #89
Toggle switches: http://www.amazon.com/Amico-250V-SPST-R ... ker+switch
LED lights: http://www.ebay.com/usr/2011_led came from this user on ebay.
They both took like 3 weeks to get to my door. Be aware there are other options out there, but they are very cheap.
Old 01-23-2014, 01:53 PM   #90
thank you!!
The Journey Visvi 1999 Thomas MVP ER wmkbailey Skoolie Conversion Projects 873 08-10-2016 05:13 AM
1999 Goshen 15 passenger rv conversion highpsiguy Short-Bus Conversion Projects 28 04-11-2015 09:07 AM
1991 Thomas conversion Will Skoolie Conversion Projects 16 06-24-2013 04:03 PM
Thomas E-350 Shuttle bus conversion crazycal Short-Bus Conversion Projects 8 05-22-2013 01:50 PM
1999 Chevy Escort FE Bus Conversion Bullwhacker007 Short-Bus Conversion Projects 14 12-19-2011 08:51 AM
