10-13-2010, 01:59 PM
#421
Re: Smitty's Bus
Oh that done it, I'm hunting you down and forcing you with fresh baked food to make me cute little hotwater hose heater box thingy like the one you have.
Great idea, love it, making it!
11-06-2010, 09:40 PM
#422
Year: 1974
Coachwork: CARPENTER
Chassis: GMC-6000
Engine: 454 CHEVY
Re: Smitty's Bus
Originally Posted by "
Here's today's project......
I'm
So today I bought a 2 gallon poly sprayer, and an "add-on" flexible shower arm, cut the wand off the sprayer, cut the lower end off the shower hose connection, heated the hose to soften it, and slid the two together.
I went ahead and installed (for the winter) the piece on my shower arm that holds the new shower head in place, so it will be just like showering before but instead of using the shower faucets, I'll just squeeze the handle on the sprayer hose to allow the water to flow. Since I have about 7-8' total hose, I can now set the sprayer outside the shower stall, and have my space back. I will still be heating water on the stove, but since I've been using the wood stove most of the time, I can heat the water in a pan setting on top the wood stove, so I'm not using LP to heat water. If I want hotter water, I'll stick it on the cook stove for a few minutes since it's already pretty warm.
I'd considered spraying some spray foam to fill the space between the sprayer inside the bucket, but I think I'll take some left-over Refletix and tape it around the sprayer itself. I don't take long showers (like you can with 2 gallons of water), so I'm not overly concerned with the water cooling-off before my shower is finished.
Smitty
[img
http://www.skoolie.net/attachments/photobucket/img_47989_2d3f5d2b72a383f22641e44556c39a8b.jpg[/img]
hey smittty why don't you just coil some copper tubing around your stove pipe and plum it into your hot water lines? and put a y valve in so you can swich from the roof to the wood stove, sences wyou are using it for heat.
hd d44 4.56, eaton ff 4.56
11-07-2010, 09:47 AM
#423
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
Re: Smitty's Bus
11-08-2010, 02:40 AM
#424
Year: 1974
Chassis: GMC-6000
Engine: 454 CHEVY
Re: Smitty's Bus
Originally Posted by keith
this we all know!!!
11-08-2010, 11:58 AM
#425
Engine: DT466/AT545
Re: Smitty's Bus
Originally Posted by Smitty
...I'm gonna be here a little longer than planned, and since my solar water heater was a "quickie" build, it wasn't intended to work in these below freezing temps. Since it froze last week, I've since disconnected it, and blown the water out of it...
Thanks for the update on the solar shower Smitty. Seems like passive solar is not a viable option for freezing temps. I wonder what would happen if you were to put water in there in the morning and use it by nightfall, even if the temps were freezing during the day? Any idea if it would get up to a reasonably warm temperature for a shower?
11-08-2010, 08:30 PM
#426
Engine: 3208 na boat anchor
Re: Smitty's Bus
Smitty. your shower solution is a boondocker's dream.
11-14-2010, 11:52 AM
#427
Rated Cap: 89
Re: Smitty's Bus
Smitty built a DIY "Lower-Flow" low flow shower head! For those times when "Low Flow" isn't low enough!
11-14-2010, 02:48 PM
#428
Rated Cap: 89
Re: Smitty's Bus
It's called "Re-purposing"!
11-15-2010, 04:27 PM
#429
Coachwork: Chevy
Re: Smitty's Bus
Love the bus! Wish I could hire you to build me a similar model!!I was thinking of doing something similar to your back deck for propane tanks, but I dont have enough room to "cut" my bus. Any suggestions?
11-16-2010, 12:02 PM
#430
Coachwork: Chevy
Re: Smitty's Bus
I see, thats pretty sweet, Im sure it would be expensive though. Something I will look into a little later!
11-17-2010, 01:18 PM
#431
Coachwork: Chevy
Re: Smitty's Bus
Looks great though. Another thing I would need to consider though is since mine is a shortie I dont need a special license to drive it. If I added an extension, it may be too long and I might need to get a different license. Im not sure, but I do know that PA does like to make things hard, so Im sure I'd have to jump through hoops
03-15-2011, 11:38 AM
#432
Re: Smitty's Bus
*poke poke* Where is Smitty?
03-15-2011, 02:01 PM
#433
Rated Cap: 89
Re: Smitty's Bus
... Correct me if I'm wrong here guys, but anything under 35 feet and 13 tons does not require a CDL if it's not commercial use, right?
Depends on the state. In MOST states, there are exceptions. Recreational vehicles, regardless of length, air brakes and/or weight are exempt from the CDL requirement. That is why so many coach converters opt to title as "Recreational Vehicle", "House Truck", "Motor Home" or whatever your state's designation is. Insurance is often cheaper. Lots of folks insist that you need the CDL because of air brakes,or weight but if you look at the CDL exemptions for your state, it should have RV's listed (buried) in there somewhere. If you don't look for the exemption and only look at the standard list that tells you what type driver's license you need for what type vehicle, then you will (mistakenly) think that you need a CDL. UNLESS you are using your bus as a COMMERCIAL enterprise, then you should be titling as a private RV. If you are titled as COMMERCIAL, then you are required to keep log books, stop at weight stations, and are subject to any and all fines applicable to COMMERCIAL use.
03-19-2011, 12:59 PM
#434
Re: Smitty's Bus
poor Smitty has been MIA for a month and a half now...
03-19-2011, 01:04 PM
#435
Chassis: Safe T Liner
Engine: 3208 turbo
Re: Smitty's Bus
Well hey maybe GTFO - GTFO of Indiana.
05-25-2011, 11:00 AM
#436
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
Re: Smitty's Bus
GTFOS
05-25-2011, 02:04 PM
#437
Chassis: Super Coach II, 36 Ft. RE
Engine: Cat 3208T, MT643
Re: Smitty's Bus
He had some run-ins with the local cops--maybe he's in Jail?
Hope not.
He was a prolific poster so I figure something happened.
06-15-2011, 08:53 AM
#438
Rated Cap: 48
Re: Smitty's Bus
I did notice that his outside-page link is dead...he had a ton of pics and other posts there. I know he had health issues, I hope he's ok.
The older I get, the more I don't know.
08-08-2011, 08:42 AM
#439
Re: Smitty's Bus
Anybody have Smitty's website address?
08-08-2011, 11:17 AM
#440
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
Re: Smitty's Bus
Yea i have it but you can;t have it but ill tell you this ,he's doing ok.....
keith
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
where'd Smitty go?
family wagon |
Everything Else | General Skoolie Discussions |
27 |
08-10-2014 11:06 PM |
special thanks to smitty
timbuk |
14 |
04-03-2011 08:38 PM |
@Timbuk @Smitty
Abbott |
6 |
02-27-2010 11:57 PM |
Ohhhhhh.... SMITTY!!!
the_experience03 |
1 |
10-13-2009 04:33 PM |
hey Smitty and Jimmy A
timbuk |
10 |
08-06-2009 02:34 PM |
