Old 06-10-2010, 04:45 PM   #291
dogfinn's Avatar
Engine: 7.3L, International
Rated Cap: 35
Re: Smitty's Bus
Smitty, Where did you find your captains chair? I am in need of one real bad but can't afford the asking price for most of them.
Thanks
dogfinn from the Akitabus
dogfinn is offline   Reply With Quote
Old 06-10-2010, 09:07 PM   #292
JakeC's Avatar
Re: Smitty's Bus
Originally Posted by crazycal
I read that. So what color does it look like if it doesn't have a name?
ummm....it looks like the color in the picture...
Brutus
Old 06-10-2010, 09:26 PM   #293
bunedoggle's Avatar
Chassis: Safe-T-Liner MVP
Engine: CAT3116
Re: Smitty's Bus
oooohhh shiny. When can I bring my bus down for painting?
1. Always use the right tool for the job.
2. A hammer is the right tool for any job.
3. Anything can be used as a hammer.
bunedoggle is offline   Reply With Quote
Old 06-10-2010, 10:41 PM   #294
Will's Avatar
Engine: DTA 360, Fuller 6-speed
Rated Cap: 53
Re: Smitty's Bus
Originally Posted by JakeC
While the DTA360 does have slightly less hp and torque than the DT466, it is still a great engine and will last forever. It might slow down a bit more than a larger engine in the mountains, but it'll still get there. FWIW, it's the same size as the venerable 5.9 cummins...
I'm just thinking in terms of the terrain on the west coast. I have been on hills climbing at very slow speeds, like 25MPH. I know the 360 is just as bulletproof as the 466.
Just so everyone understands my intentions, it was not to slam Smitty's bus in any way. I was just curious.
I don't know what tranny he has, but I have a DTA360 with a 6-speed Fuller. I generally cruise at 65mph with the tach showing 2700rpm and get around 13mpg in the midwest. There is no hill west of West Virginia on I70 that will make me downshift until I get past Kansas. A 5% grade will drag me down to 50mph with a shift down to 5th. A 6% will bring me down to 45mph. Beartooth Pass is a 6%--though lots of turns that might send you down another gear and make catching back up a problem. I have been over a 9% (US30 west of Chambersburg, PA) and that took me down to 4th and 35mph. I68 is 100+ miles of 6% and 5% grades and that's where I was last weekend. I go around loaded tractor-trailers on the uphill parts and they blast by me on the downhills. Power to weight-wise, a 20,000# schoolie with 185hp is equivalent to an 80,000# semi with 740hp. Most semi's are 375-525hp. The semi has better gears and can use maximum power more often so they will often seem stronger, but when the grades get bad enough you will out perform them. I'm guessing having a slushbox Allison without a lockup converter would be worse, but I don't think power with a DTA360 is a problem. The transmission is more of a problem.
I think Smitty won't notice any lack of power. He'll drive 55 and get 10-12mpg and be fine on the hills. Just don't be afriad to let that motor spin. It's happy for thousands of miles on end at maximum rpm.
My bus conversion
Will is offline   Reply With Quote
Old 06-10-2010, 11:56 PM   #295
Will's Avatar
Rated Cap: 53
Re: Smitty's Bus
I'm pretty confident. When I left the marines in 1996 I rented a Budget F700 with a Cummins 5.9 at 180hp and an auto. It was a self move and it weighed 30,000# almost exactly, with my '64 Galaxie in tow. I averaged 12mpg (and a killing on the self-move) and I took it easy to make sure I got the best mileage I could. That was Southern California to Columbus, Ohio. My buddy that got out the year befoe tried to save money with a gasser U-Hual and made about 6mpg and lost money.
My rental truck box was 12' 6" tall--taller than your bus--so I don't see your addition as being significant. And you won't come close to 30,000#.
I said to not be afraid to let the motor spin and I meant it. On hills, downshift and hold it down and let the motor do the work. If you let the converter do the work, it does it by making lots of heat--slipping. I don't think the 500-series has a lock-up clutch. Lots of your fuel goes into making heat. The more torque the motor makes, the hotter the converter gets. Use the rpms.
My bus conversion
Old 06-11-2010, 09:37 PM   #296
Jerry Campbell's Avatar
Year: 1975
Engine: DD 6-71N
Re: Smitty's Bus
When my bus was empty I got 12 mpg. Last trip, 6000 miles and lots of mountains, I weighed 27,500 lbs and I got a little less than 10 as an average. Judging from the weight you got going on I doubt if you'll do any better.
When you start driving down the road with all that stuff it gets a little spookie going much over 60, especially if you're on the rough back roads which we like so well, the handleing changes, the brakes don't work as well, the steering gets a little sloppier. 55 to 60 is just fine by me + I get better mileage. I have a friend who has a rig similar to yours I think power wise. A BlueBird Wanderlodge, loaded to death. About an 82, with a 3208 Cat and an allison 6 speed. With my 6-71 with 5 speed tranny I pass him on a hill but when we get to the flatlands he buzzes by me. I'm sure whatever it turns out to be You'll love it.
Jerry
Jerry Campbell is offline   Reply With Quote
Old 06-11-2010, 11:07 PM   #297
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
Re: Smitty's Bus
Originally Posted by Smitty
If I break double-digits I'll be tickled to death.......
Smitty
I would have to agree!!! Last trip out I got 4.76 mpg! But, I have since found some issues with my distributor and ignition timing and am working to resolve that right now. I expect to be able to get 7-8 mpg if I really try. Of course we are comparing apples to oranges here so it is kind of a moot point.
Old 06-11-2010, 11:21 PM   #298
Will's Avatar
Rated Cap: 53
Re: Smitty's Bus
A 6-71 and 27,500#...A 4-stroke DTA360 will get better mileage than a 6-71, and he will be 5,000# lighter more than likely. I don't think his bus will reach 20,000#, honestly.
As to the gas motor--what do you expect? My Winnebago weighed less than half what my bus weighs--much less than half--and got half the mileage. I think 5mpg in a gas schoolbus sounds great.
My bus conversion
Old 06-11-2010, 11:46 PM   #299
Year: 1975
Engine: DD 6-71N
Re: Smitty's Bus
If I break double-digits I'll be tickled to death, but if not.....it ain't gonna stop me from leaving these Indiana winters in the rear-view mirrors
Smitty
Think you're going to be ready by the winter?
And where to?
I'm hoping to leave the first of November. I can already feel the call of the highway.
Jerry
Old 06-12-2010, 05:51 PM   #300
Year: 1978
Coachwork: thomas
Chassis: ford
Engine: 406 Ford
Rated Cap: 25
Re: Smitty's Bus
Well damn, that looks sharp. B.A. Baracus would be proud to drive that tank- and probably should.
You should do a similar guessing game w/ the bus weight as you did w/ the scrap weight...$$$. haha
bus-ted is offline   Reply With Quote
where'd Smitty go? family wagon Everything Else | General Skoolie Discussions 27 08-10-2014 11:06 PM
special thanks to smitty timbuk Everything Else | General Skoolie Discussions 14 04-03-2011 08:38 PM
@Timbuk @Smitty Abbott Everything Else | General Skoolie Discussions 6 02-27-2010 11:57 PM
Ohhhhhh.... SMITTY!!! the_experience03 Everything Else | General Skoolie Discussions 1 10-13-2009 04:33 PM
hey Smitty and Jimmy A timbuk Everything Else | General Skoolie Discussions 10 08-06-2009 02:34 PM
