Old 06-05-2015, 10:36 AM   #241
sojourner's Avatar
Engine: DT408
Remember, this is the internet. Don't trust anything you see. That could just be some model/actor he hired to stand in for him.
BUSTED!!! Whoda thunk I'd find such a handsome stunt double who's a professional Beluga Whale Bikini model who just happened to be "between jobs"!! Seems everytime he puts on a bikini and lays on the beach not only do children run off screaming in terror and people start gouging their eyes out the harpoons start flying from offshore whaling ships.
I am an sojourner in the earth; hide not Your Commandments from me. Psalm 119:19
Here is the patience of the saints; here are the ones keeping the commandments of YAHWEH, and the faith of Yahshua. Rev. 14:12
sojourner is offline   Reply With Quote
Old 06-11-2015, 06:42 AM   #242
sojourner's Avatar
Engine: DT408
Just saw a documentary on foam insulation that went bad. Nasty stuff when it doesn't cure properly (even when done professionally). I was wondering what alternatives there are out there with similar R values? Any ideas?
Old 06-11-2015, 07:03 AM   #243
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Foam board would be the next best thing, id imagine.
I saw the same show, I think.
Old 06-11-2015, 10:59 AM   #244
Engine: 190hp 5.9 Cummins
You bring your bus to them, they spray it in the right environmental conditions.
The number of spray jobs gone bad is so small, I'm not even going to consider anything else.
That video needs to be taken down, or labeled as histarya.
One bad job out of half a million good jobs. All caused by the operator not making sure his equipment was mixing properly.
Ask for references. I have a guy I use for all my home builds. No issues to date.
Old 06-11-2015, 05:14 PM   #245
Chassis: Genesis
Fully agree.
Timelord is offline   Reply With Quote
Old 06-15-2015, 01:24 PM   #246
sojourner's Avatar
Engine: DT408
Believe me, I'm not buying in to all the hype. Just asking for viable alternatives to spray foam. I'm not a fan of foam boards due to not addressing condensation issues and maybe even exasperate them by reducing air flow and drainage. There are many things I like about spray foam (noise reduction, if applied properly increase strength, and elimination of condensation altogether). That being said, and as good as the stuff is, it just seems a bit shortsighted that there's not a better way to insulate a metal container.
Old 06-15-2015, 01:50 PM   #247
Aerogel or Pyrogel...but it's a bit more costly.
Old 06-18-2015, 06:30 AM   #248
sojourner's Avatar
Engine: DT408
Thanks for the info. Still a long way away but always thinking ahead.
Old 06-18-2015, 09:22 AM   #249
sojourner's Avatar
Engine: DT408
OK everyone, here's some pics of my recent work on the basement storage bays. Got the drivers side installed. I've got the aluminum panels cut but will not install them until almost finished with the bus to keep easy access to installing wiring, plumbing, gas and HVAC.
Old 06-18-2015, 09:47 AM   #250
Coachwork: IC
Chassis: CE300
Rated Cap: 32
damn you're an excellent fabricator and craftsman.
Impressive work, sir.
I love that bus.
