Old 06-30-2015, 04:27 PM   #261
Engine: 190hp 5.9 Cummins
Originally Posted by The Nebuchadnezzar View Post
Call me crazy but everything on my bus functions and I have lots of work to do converting, I can't understand why extra wiring is so upsetting to folks, guess I'm from the "if it works don't fix it" camp.
Because we don't want to bury a mess that can cause a big mess of problems later on.
It's best to know every system in your bus like the back of your hand.
Do you really want some wire that was not needed causing a short and burning up your alternator? Or boiling your battery?
I leave nothing behind me to surprise me later. When working over sea's, I make sure to double tap the fallen enemy. One extra bullet is cheap insurance.
Old 07-03-2015, 02:46 PM   #262
sojourner's Avatar
Engine: DT408
Got my order of bullet hinges in and had to try them out. I got he access doors for the fuel tanks and stabilizer jacks together and primed. I still have to punch the holes for the cam locks. I'll o that later when I put some rubber cushions in to keep them from rattling (I hate rattles).
Here's the propane tank assess door. I still have to frame in the paddle latch when I get them. Primed to keep the rust down.
Here's the cover for the Central AC unit I'm making from a window unit. This panel will be screwed in place instead of a hinge since it will not be gotten into very often.
I've never liked the radiator grill for several reasons. One, it had broken due to vibration and rattles excessively. Two, the headlight panels were mounted to it and because it broke, the headlights would shake. Three, the old grill required you take 4 screws loose to open the grill to access the radiator fill neck. I have another place to top off the radiator but my grill only requires 2 screws and it tilts out. Four, there seems to be a common problem with cooling for many who have these FE buses. While mine never did on the 1800 mile trip home from TX, I thought while redesigning this grill, why not get a lot of air flow in the process.
Here's a pic with everything removed and the radiator and after cooler freshly painted with some flat black (you'll understand why when you see the grill):
Installed the mounting bracket. The headlight mounts bolt to this bracket and are very solidly mounted:
With the grill mounted. It can be easily removed if need be as the bullet hinges are both facing the same way. I reused the letters from the old grill. When the pain seasons well, I'm going to fill them with silicone from the back side to tie them into the mesh of the expanded metal:
I am an sojourner in the earth; hide not Your Commandments from me. Psalm 119:19
Here is the patience of the saints; here are the ones keeping the commandments of YAHWEH, and the faith of Yahshua. Rev. 14:12
sojourner is offline   Reply With Quote
Old 07-03-2015, 02:49 PM   #263
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Beautiful work as always.
Idea now filed away and officially will be stolen! sweet grille!
Old 07-03-2015, 07:17 PM   #264
sojourner's Avatar
Engine: DT408
"Steel" away!!
Old 07-03-2015, 07:24 PM   #265
here's a swipeable paint scheme!
http://www.skoolie.net/forums/f11/be...-best-123.html
instead of resurrecting an old thread
Old 07-03-2015, 08:36 PM   #266
sojourner's Avatar
Engine: DT408
Nice paint scheme. Hide those rub rails!!
Old 07-03-2015, 10:06 PM   #267
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
Bah...my rub rails are going to be right out there and visible...black against blue. I like the new grille. Looks very much like mine-
Just without the ladder
Captain Obvious on deviantArt
Old 07-04-2015, 02:31 AM   #268
Interesting, the Genesis uses only a half size intercooler for the engine intake air.
The TC 2000's use a full size intercooler.
Old 07-04-2015, 08:05 AM   #269
Coachwork: IC
Chassis: CE300
Rated Cap: 32
PLenty of them don't even have one. Like mine.
Old 07-04-2015, 08:28 AM   #270
damn you're an excellent fabricator and craftsman.
Impressive work, sir.
I love that bus.
I second that emotion. This is amazing work. Gorgeous!
whirlygigg is offline   Reply With Quote
