Old 08-12-2016, 08:40 PM   #431
plfking's Avatar
Rated Cap: 34
Originally Posted by sojourner View Post
Been working as I get time and finances. Was working on the new dashboard and couldn't wait to dry fit the gauges.
Gonna be fun to sit behind this some day!!!
Very nice.
(....we need a "Like" button on here....).
Old 08-12-2016, 08:57 PM   #432
Ryannmelis's Avatar
Coachwork: Wayne Corp
Still lots to do with switches and indicator lights. Once everything is drilled and sanded, then I need to get it anodized to give it some color.
That is awesome
Sent from my SAMSUNG-SM-G891A using Tapatalk
1990 International 3800 DT360 and AT545.
2007 Dodge 5.9 with a 6 speed.
6 Kids,1 Cool Ol Lady
Lots of life to live.
Ryannmelis is offline   Reply With Quote
Old 08-12-2016, 11:00 PM   #433
Chassis: International S3800
I dig that!!! looks nice and custom.. almost like a peterbilt panel which i love!!
Old 08-13-2016, 10:58 AM   #434
sojourner's Avatar
Engine: DT408
The Peterbilt corvette dash is the inspiration behind this one. Took the concept and adapted it to the space in my bus. All the gauges are, in fact, vintage Peterbilt gauges. I recalibrated the tach to work on my International DT408.
sojourner is offline   Reply With Quote
Old 09-09-2016, 06:27 PM   #435
sojourner's Avatar
Engine: DT408
Haven't posted many pics in a while so here goes.
While the stock mirrors are good at showing you what's going on, they are a somewhat gangly mess and not very "elegant". I fabricated some new brackets and am reusing the stock mirrors to get a more "West Coast" style:
I've also been blanking out the light holes and marquis window. Good thing too!! There wasn't 1/8" of overlap on the cutout with the rubber seal. Needless to say, water had been leaking inside. Not anymore!! I also purchased a 300 watt LED light bar in case some additional illumination is requires while boon-docking.
In this photo, you can see I have no headlights. I'm upgrading from the 35 watt stock headlamps that came with the bus to 100 watt H4 Halogens. This requires a total rewire with heavier gauge wires and new relays with the lights getting their power directly from the battery. I'm waiting on some heavy duty connectors to wire the lights in:
View from the back with windows, flasher lights and marquis window blanked. By the way, all these panels are sealed with Sikaflex marine sealer. No more leaks!!
I also replaced all the turn signal, brake, backup and running lights. Some with stock (which I will put in LED bulbs) and some outright LED fixtures (running lights).
No real need to explain these pics. Anyone who's done this knows what it means when the back of the bus looks like this. Oh yea, the ugliness begins!! I must say, two crowbars used together pops the panels right up!!
This picture hints at why I'm doing the floors now. Not only to deal with some minor rust but I'm relocating the battery to a bracket under the floor between the frame rails. I had to remove the stock battery box when I built the two fuel tanks. When finished, a hatch in the floor will give us access to the battery box (full plastic enclosure) from within the cabin to service the battery. The plastic battery box will keep any chance of battery acid dripping on the driveshaft which could lead to a very bad day. I'm using a marine box designed to catch anything a battery might "ooze". It also has the advantage of shortening the battery cables.
After getting all the floor panels out, the screws removed, I power washed the inside floors and sides to clean up the never ending flow of Texas dust from inside. I found out that the easiest way to remove the tar-like patches used to stick the old insulation in place is to pressure wash the patches. It strips it off easily with no chemicals or messy wire brushing. Now things are MUCH cleaner:
Once the battery boxes (one for starting and the other for solar system) are installed in the floors and the entry door relocated I'll then treat the rust and paint the floor.
I am an sojourner in the earth; hide not Your Commandments from me. Psalm 119:19
Here is the patience of the saints; here are the ones keeping the commandments of YAHWEH, and the faith of Yahshua. Rev. 14:12
Old 09-09-2016, 10:25 PM   #436
Don't forget to adequately vent that battery box...
I know it should go without saying, but just in case!
Wouldn't want a fellow Skoolie aficionado to get poisoned
Old 09-10-2016, 06:42 AM   #437
sojourner's Avatar
Engine: DT408
I totally hear ya . The box itself is vented and will sit in a frame well below the floor so there's plenty of air circulation around it. The hatch (access to remove the battery box cover and then access the battery) will have a weatherstrip to keep both vapors and cold air from seeping in and will be latched down into place. Having been a marine tech as my career, I have a built in concern for things that make fumes in confined spaces.
Old 09-10-2016, 08:16 AM   #438
Oh heck! You got this then!
Old 09-10-2016, 09:21 AM   #439
You may or may not have some issues down the road with that lightbar up front. Most states and I believe some Fed regs have a limit on how high up white lights on the front of a vehicle can be and I have heard of some skoolies having to cover or remove them. There has been some discussion on this here so you might want to look into it.
Old 09-11-2016, 10:43 PM   #440
sojourner's Avatar
Engine: DT408
Thanks for the heads up. A cover would be no problem to make if need be.
