07-15-2015, 07:55 AM
#281
Chassis: I.H.
Central FL, not far from the mouse.
07-19-2015, 01:11 PM
#282
Engine: DT408
Still thinking about how to go about the whole roof raise. I was thinking, has anyone done, or know of it being done,a roof raise using the front and rear end caps of another bus of the same model and basically raising the center section behind the cab and just behind the last bow? I'm only going up 12"-14" so I can't see air flow being that big of a deal since my bus is basically like pushing a shoebox down the road anyhow. This would simplify the raise considerably and maintain maximum structural integrity to boot. If I use the ends like I have I would also get some added light through the cider windows. Any advice from experience out there? Maybe suggestions on where to get the parts?
07-19-2015, 02:00 PM
#283
Yeah that is sorta the way it used to be done on buses.
07-19-2015, 02:13 PM
#284
donors are out there!
School bus body
If I had the way......
it'd be in my back yard!
07-20-2015, 03:25 PM
#285
Year: 1965
Coachwork: Looking for a bus...maybe
Chassis: International Scout
Sojourner- I downloaded your barrelponics how-to about two years ago...funny running into you here! Ended up doing a regular dirt garden, but will try Aquaponics one day!
As for the roof raise, you could always sink the shower down through the floor for some extra headroom.
07-20-2015, 04:07 PM
#286
Engine: DT408
I can't sink the shower into the floor for a couple reasons. One, the entire available space under the floor it taken up with basement storage. The space under the shower has a stabilizer jack and propane storage. I'd also have to lower the grey water tank for it to drain. Good ideas outside the box though. Even if the shower wasn't an issue, we'd still have to raise the roof for normal counter top height and reduce stepwell encroachment. We're gonna be living in it full time so we want it to be as comfortable as it can be. If ti was just a camper, we'd leave things as be and already be using it.
Thanks again for the suggestion!!
I am an sojourner in the earth; hide not Your Commandments from me. Psalm 119:19
Here is the patience of the saints; here are the ones keeping the commandments of YAHWEH, and the faith of Yahshua. Rev. 14:12
07-20-2015, 04:12 PM
#287
Year: 1965
Right on.
Whoop whoop! Raise the roof! Looking forward to watching your progress.
07-21-2015, 08:51 AM
#288
Engine: DT408
Hey guys and gals, just found an ebay store that might be of interest. Lots of truck stuff that could be used on a skoolie. I have not ordered from them or am endorsing them per se. Just thought it was a very large resource.
Cargo Control for Truck Trailer items in Global Parts Inc Kenworth Peterbilt Mack Freightliner Volvo store on eBay!
07-24-2015, 10:19 AM
#289
Engine: DT408
Had a very interesting conversation with Walter Wade the other day concerning skoolies. He's a very nice man, and if you catch him near a phone he's not already on, a wealth of information. He has a skoolie graveyard and I've got to find a way to get up there someday.
Anyhow, he was mentioning the use of a 2 speed differential for getting good highway speeds in direct drive and when in the mountains, just chill out and take it easy. Sounds like a good idea to me since we plan on boondocking and could use the low side from time to time. I'm not finding much for the N190 rear axle though. Any suggestions?
Also, he mentioned adding a PTO to my trans (MT643) with a hydraulic pump to drive winches, log splitters, etc. i was even thinking of doing something like that for Lori's grain mill or a genset. Lot's of possibilities. Now to find a salvage dump truck with a 4.10 2-speed N190 rear and blown engine and MY643 tranny with a good PTO and pump unit on it. Oh yea, those are sitting on every corner. Also, going out to take some pics of the progress so far (had to stop, grinder died).
07-24-2015, 10:51 AM
#290
Engine: DT408
#291
Engine: 190hp 5.9 Cummins
I'm not a fan of cutting up the roof.
IMO it should be left as one piece.
After all, it is the strongest part of the bus.
I like the look your after, I just feel it's not a good idea.
07-24-2015, 11:25 AM
#292
Engine: DT408
Hey Nate, I hear your concerns. The plan is to maintain as much of the structural integrity as possible by adding bows at both the upper and lower transition points for the factory end caps to attach to. By using both the inner and outer factory endcaps (on both ends) I can maintain most, if not all the factory designed structural strength. Maybe even strengthening it with the added angles. Also, by leaving the factory rear end cap intact (both inner and outer) I retain the structural integrity of that component as well. I, at first, thought about doing an angled transition as I liked the look but at 14"-20" raise, I'm not really going to be pushing that much more air driving this shoebox down the road seldom as it will be. If need be I can always add a wing to divert air over the bus. If I can find windowed caps, I also gain extra light into the interior.
07-26-2015, 12:55 AM
#293
Good description.
Thx
07-26-2015, 09:19 AM
#294
Engine: DT408
By the way Nat. Sorry about misspelling your name (Nate).
07-26-2015, 09:21 AM
#295
Engine: DT408
Can anyone out there tell me if the body bows are the same on all models of international skoolies? It will help to know if there is a difference when looking for a donor.
07-26-2015, 11:58 AM
#296
All good about the spelling of my name, people do that in real life too.
If your coach work is Bluebird, than any Bluebird from the last 5 years each way should fit.
Same with Thomas.
International only made the chassis.
07-26-2015, 12:08 PM
#297
Engine: DT408
Same with Thomas.
Mines a 1995 international AmTrans. Some of the dognose buses out there are International's but not BB or Thomas. Would be easy to find a donor if a 1990-2000 dognose would fit.
07-26-2015, 12:41 PM
#298
Same with Thomas.
funny.
I assumed your name WAS Nat... Like Nat King Cole.
07-27-2015, 12:19 AM
#299
We can't get Am Tran buses here, so I have nothing to reference to.
Only one here is a privet contractor. He has a 07 RE300 with a 300hp DT466 and a 3060 trans with 6th gear and a engine brake.
He paid 131,000 in 07.
EastcoastCB
My name is Nat.
Nat_ster is my company name. It stems from the days of napster the mp3 download client.
At that time I was a computer tech, programer, website updater, ect.
I have carried the name from trade to trade as I have changed through the years.
07-27-2015, 01:55 AM
#300
Moderator
Engine: DT408, AT545
Rated Cap: 23 500 gvw
EastcoastCB
My name is Nat.
Wow, I thought I overpaid for my buses.
