11-02-2015, 10:35 AM
#21
Engine: 190hp 5.9 Cummins
Good progress.
I like seeing people using good brand tools. I saw a Makita cordless drill.
11-09-2015, 10:26 AM
#22
Rated Cap: Your mom +1
Got a little more work done on the outside, not much but I have pics!!! It's slowly coming together. Gonna have to put a different door on it sooner rather than later too. We're thinking about one of those full view glass security doors. The opening seems to be 36" x 80"
Just have the corners on the front and rear corners and windows to skin up then the bus will finally be enclosed once again.
12-04-2015, 04:37 PM
#23
Bus is fully enclosed, and I was finally able to get enough consecutive sunlight after work to put the door on. Fits like a glove after I trimmed the bottom step back a little.
12-04-2015, 08:28 PM
#24
Chassis: MVP
Engine: CAT 3116
The door looks great!
12-05-2015, 07:44 AM
#25
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 2 ATV's and friends
...x2 on the door! Gotta come up with something for my bi fold as well.
01-11-2016, 09:18 AM
#26
01-11-2016, 09:51 AM
#27
That is a serious volume of floor insulation. What are your plans for the roof & walls? If anything like the floor, you will wind up driving an Igloo cooler that will make it easy to maintain a stable temp come heat or sleet.
Nice work.
01-11-2016, 09:55 AM
#28
Yes, nice work!
01-11-2016, 10:48 AM
#29
Yeah, Its going to have 1/2" less in the walls and most likely the same as the floor in the ceiling. My old lady gets cold easily and I don't like listening to whining so I'm going overkill to make a nice warm bus for her...
01-11-2016, 12:25 PM
#30
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
My wife says she LOVES your front door!!!! Great work so far!
01-11-2016, 12:38 PM
#31
Yes! I, too LOVE that door. I'll be totally copying that for sure.
01-11-2016, 12:57 PM
#32
Just don't buy the door at Menards. That place is a crap-hole, and their customer service is some of the worst I've ever dealt with. I'll be warrantying the door this week. Some of the glass clips were broken off when I received it and I just fixed it myself, no big deal, just a couple bucks for new clips. This past weekend we got rain that turned into ice and two of the vertical posts on the door grille filled with water and then froze and ripped open. It would appear they didn't finish the welds and water was able to get in. No more Menards for this guy... ever.
01-12-2016, 09:00 PM
#33
Year: 1994
Chassis: TC/2000
Engine: Cummins 5.9TA
lookin' good, can someone tell me what this is?
"Gradually I came to realize that the process of saving the desert of the human heart and revegetating the actual desert is actually the same thing." -Masanobu Fukuoka
01-12-2016, 09:46 PM
#34
Chassis: TC 2000
Engine: 5.9
Rated Cap: 83
The hole
The hole is to access the fuel sending unit in the tank.
Hopeless Busaholic!
01-13-2016, 06:00 AM
#35
Yep.
01-13-2016, 09:33 AM
#36
And...you do NOT want to permanently cover that access port. As sure as you do, something will go wonky with the sender and dropping the tank will be your only option.
Mine did not originally have access but I installed a hatch that is now accessible from the storage area under sofa/sleeper. Since I replaced both the fuel tank and the fill neck, adding access to the sender just made sense.
It is the rectangular area just inside where the fill neck is located.
01-13-2016, 09:56 AM
#37
Sage advice, Tango.
01-13-2016, 10:00 AM
#38
Rated Cap: 87
I see Tango knows how to get his filler neck "in gear" Sorry, can't help the puns sometimes. However, it also shows how resourceful we can be. LOVE the shifter boot idea. I may actually steal that one in my builds......
01-13-2016, 10:41 AM
#39
You ID'd it correctly M --- It is indeed a shifter boot. I borrowed a couple of hole punches from a buddy to get the right, tight fit around both the filler neck and the vent hose. Hope it will do the job.
My next sealing challenge will be the steering shaft where it will penetrate the new firewall. Still not quite sure how to address that issue but it will likely be something similar. i.e., re-purposed scrap.
01-15-2016, 11:17 AM
#40
Just bought a 42 gallon h2o tank on pplmotorhomes.com. Got it for 80 bucks on sale. If anybody reads this today and needs a smokin' deal on a tank they're running a sale that ends this evening at 7pm...
