01-14-2014, 02:22 PM
#181
Engine: 3126
Re: Somewhereinusa
Hey somewhere, I have been reading how you did your door. I plan to copy it also.
I found bear claw latches I want to use, but cannot find a handle to open them with. It looks like you used a cabinet handle, I have seen these, but cannot find where to buy them. Where did you get yours?
If you say, "Off an old cabinet I had." I guess I will have to dig more.
01-14-2014, 03:22 PM
#182
Chassis: AARE
Engine: 3116 Cat 250hp
Re: Somewhereinusa
William,
The handle I used I got at one of the surplus RV places in Elkhart. It's just a passage way door handle. And other "stuff" that I had laying around. I'm not really all that happy with it, they are made pretty cheap. I've had to weld it together twice.
That's one of those things on the list to remake, either when it breaks again or I get some of that elusive free ti me.
01-14-2014, 03:59 PM
#183
Re: Somewhereinusa
Would a "garage door" latch system work? It is basically the same shape and made for exterior use by it's very design. You can get them with keyed locks built in as well... what do you think?
01-14-2014, 04:06 PM
#184
Chassis: AARE
Re: Somewhereinusa
I don't see why not, that's probably what I'll eventually do. I'll just have to remake the levers with square holes, the garage door uses a bigger square.
02-17-2014, 10:23 AM
#185
Chassis: AARE
Re: Somewhereinusa
Well the weather has been bad and I'm not likely to work out in it so I thought I would detail work done.
I have three battery banks and I wanted an easy way to monitor them. I built this little panel to be added to the original driver switch panel. I have a lot of room since I took out a lot of switches having to do with school bus things.
Here is the panel itself.
The run position shows start system voltage when engine is running. The other three positions are for start batteries, house batteries and the aux is for the bank I have for computer batteries. When the engine is not running the panel is off until you push the button below the meter. When engine is running, with the switch in the run position the meter is on all of the time. You can also check the other banks while engine is running by switching to the appropriate bank and pushing the button.
I built this junction block to be installed in the wiring junction box accessible from the outside under driver side window. It will keep the strain of big wires off of the back of the meter/switch assy.
Detail of back of panel.
The complete assy.
We're expecting another 4 inches of snow this afternoon, then it's supposed to warm up the rest of the week. Hopefully I can get back to working on the bus next week.
Dick
02-18-2014, 01:21 PM
#186
Re: Somewhereinusa
That's awesome, you made this?!
"That's,. like,.. your opinion, man...." - the Dude.
02-18-2014, 03:36 PM
#187
Chassis: AARE
Re: Somewhereinusa
Thanks, yes I made it.
Some of my other recent projects are here.
http://somewhereinusa.x10.mx/electronics2.html
I love the internet, I can find out how to build all kind of things.
Dick
02-18-2014, 04:10 PM
#188
Re: Somewhereinusa
Dick
dude awesome...I think about stuff like this and then forget to do anything about...it's an ADD thing
02-18-2014, 06:16 PM
#189
Rated Cap: 79 at Birth
Re: Somewhereinusa
Most excellent work on the switch build!!!
02-18-2014, 07:35 PM
#190
Re: Somewhereinusa
x2 on the excellent work on that switch
02-19-2014, 09:39 AM
#191
Year: 87
Chassis: International s1700
Engine: 6.9 internatiional
Re: Somewhereinusa
[quote="somewhereinusa"]Well the weather has been bad and I'm not likely to work out in it so I thought I would detail work done.
The complete assy.
Dick[/
i love the blue bird logo on the panel as well. i will need a battery monitor in the future, i will need to get one with a Wayne logo though
02-23-2014, 05:44 PM
#192
Chassis: AARE
Re: Somewhereinusa
I wanted a panel mounted USB power/charging port, bot couldn't find any I liked. They were way too expensive, and ugly. Here's one I built for about $2.00 with parts I had laying around. If you run right down to your local Radio Shack, I'm assuming a price more in the $15 range.
back side
These are really easy and quite simple. If you want to do your own I've posted the schematic here. http://www.somewhereinusa.x10.mx/usbSchematic1.pdf
It will work with input voltages from about 8 to 35 V dc.
02-23-2014, 09:40 PM
#193
Engine: 190hp 5.9 Cummins
Re: Somewhereinusa
I like it, looks really well made.
02-23-2014, 10:13 PM
#194
Chassis: AARE
Re: Somewhereinusa
Sorry the link works now.
02-23-2014, 10:38 PM
#195
Re: Somewhereinusa
For redundancy, and easy viewing pleasure, Somewhereinusa's diagram.
03-18-2014, 11:29 AM
#196
Re: Somewhereinusa
thanks Nat
03-18-2014, 01:33 PM
#197
Chassis: G30
Engine: 6.2L diesel
Re: Somewhereinusa
This is an awesome bus build. It's enjoyable to see all these custom built parts you make, and they look so fantastic. Thanks for all the documentation.
03-19-2014, 06:59 AM
#198
Engine: DT408
Re: Somewhereinusa
Hello,
I went to your website (cool by the way) and was looking at your cruise control. I am assuming you've got an electronic controlled engine? I didn't see any interface with a means to hold the throttle. I've got a 1995 AmTran with a mechanical DTA408. Would love to figure out how to have this control a mechanical throttle.
I am an sojourner in the earth; hide not Your Commandments from me. Psalm 119:19
Here is the patience of the saints; here are the ones keeping the commandments of YAHWEH, and the faith of Yahshua. Rev. 14:12
03-19-2014, 08:24 AM
#199
Chassis: AARE
Re: Somewhereinusa
Originally Posted by sojourner
Hello,
I have an air throttle, the beauty of this system is that it attaches to the foot pedal, so it will work with any kind of system. It uses the GM cruise actuator which is electric so no vacuum needed either.
03-19-2014, 01:19 PM
#200
Engine: DT408
Re: Somewhereinusa
Thanks for the quick response. My next question is, I looked for somewhere in the schematic that would indicate where the actuator would be wired in but didn't see it. Am I missing something? I could be momentarily going brain dead (has happened once but that was unverified) . I'm assuming the speed sensor input could be picked up off the electronic speedo signal (I believe is coming from the transmission (MT643)? Also, been checking a bit on the web and can't find any conversations about this conversion. I'm wondering who's done it and if there's any photo's of such (some of us think in pictures). I'm a total DIY kinda guy but have learned, sometimes it's not necessary to make the mistakes myself and take the time to learn from others. I'm actually one of "those guys" that reds through instruction manuals before doing a task (and I will not give up my man card for doing so!!).
