Old 01-23-2015, 11:00 AM   #211
Ditto that. But then, always chalk it up to being hard to get good help when I do it myself Ha Ha. Jack
Old 01-23-2015, 02:46 PM   #212
damn that sucks,
Old 01-23-2015, 05:16 PM   #213
charles_m's Avatar
Year: 1982
Chassis: International S1800
Engine: DT466 Trans: MT643
WOW
I can't wait to hear how the radiant heating works for you!
What is the r-value of your floor insulation under the pipes?
www.bustoshow.org
Blog: www.lookatthatbus.com
Instragram: @lookatthatbus
Old 01-23-2015, 09:11 PM   #214
Chassis: All American RE
Engine: Cummins 8.3
Rated Cap: 90
somewhereinusa,
Looking beautiful, brother! I have a similar bus ('92 AARE) and a similar plan for hydronic heat! some questions for you:
1. What are you doing for flooring on top of your foam?
2. Is that the home depot Pex, or where did you get it? What's the minimum bend radius it feels comfortable with?
3. What kind of coolant did you have to get to get aluminum compatibility?
Your shower is looking great too. (Really the whole bus!) I've been following your build for a long time, and am finally doing my own.
JDecker is offline   Reply With Quote
Old 01-24-2015, 05:03 AM   #215
Coachwork: ward
Chassis: international
Engine: dt360a
really good stuff, somewhere! digging the shower man. oh, i just mailed ya $20, ya think ya can cross ship 10 of those fancy DIY LED lights to me? lol
Old 01-24-2015, 08:23 AM   #216
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Rated Cap: Her, me and Molly
Originally Posted by JDecker View Post
somewhereinusa,
It's 3/4 inch plywood, really nice stuff. It has a plastic coating on both sides. The coating seems to hold up really well. I got 11 sheets for $110 dollars at an RV surplus place
I buy most of my pex from pex universe. the tubing is here.
http://www.pexuniverse.com/bpr1210-1...ier-pex-tubing
I spaced the tubing about 6.5 in apart with a nice radius at the curves, That's a bit less than recommended but It seems to work ok
compatibility?
This is the coolant I used. Whole system takes about 15 gal.
http://www.supplyhouse.com/Hercules-...minum-5-Gallon
Charles M
I've had the heat working in the bedroom and the original front bus heater for over a year and works quite well. Last winter with outside temp of -20 I was able to get warm reasonably comfortable with just that and one electric space heater
The insulation is 2" foam board listed at R10
Dick
Old 01-24-2015, 08:35 AM   #217
Coachwork: IC
Chassis: CE300
Rated Cap: 32
One of my favorite bus conversions on here! Great work!
Old 01-24-2015, 04:42 PM   #218
Chassis: IC RE
Engine: T444E International
This bus is looking GREAT! Glad to see it coming along!
- Andy
Maynard is offline   Reply With Quote
Old 01-28-2015, 08:47 AM   #219
Hank's P-O-S's Avatar
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
Originally Posted by somewhereinusa View Post
I finished up the hitch today. I'll either have to move "stuff" or move the bus to try out hitching up the towd.
This is the bracing I put inside the bumper. Final version changed a little. I had to cut notches in the brace to clear air conditioning pulleys.
Putting the pin in is a little tricky, but can be done from above or below. Not with the engine running though.
I couldn't get any usable pictures that showed the inside when mounted.
Dick
How much weight do you tow with that hitch?
I was thinking of doing something like you did except with a second cross member.....er....and stuff, I don't have an RE.
Hank's P-O-S is offline   Reply With Quote
Old 01-28-2015, 09:27 AM   #220
Chassis: AARE
Practically none, originally a Jeep Cherokee, now a VW Rabbit PU. Rabbit weighs less than 2000 lbs.
somewhereinUSA out and about somewhereinusa Conversion General Discussions 53 08-24-2017 02:09 PM
Props to be thrown to somewhereinusa bapos Forum Admin | Account Help | Suggestion Box 0 06-23-2013 10:54 AM
