01-17-2019, 03:52 PM
#441
Chassis: AARE
Engine: 3116 Cat 250hp
Playing with walnut and my Shaper Origin. Bad weather is starting to set in so I'm spending more time in the shop. I just finished some new LED light fixtures.
This is 43" long.
Detail of fixture.
Bracket detail.
Next project is a makeup mirror/station cabinet for DW out of walnut.
01-17-2019, 04:40 PM
#442
That is a beautiful fixture you created, get ready for some orders ,
Can we see a night shot of that. The brightness must be like daylight?
Thanks,
01-17-2019, 06:44 PM
#443
Beeeuuutiful!!! Nice work.
02-08-2019, 06:20 PM
#444
Chassis: AARE
I love my Shaper Origin
I love this tool. I occasionally need a printed circuit board for some project or other. In the past I have etched them with acid. Messy and time consuming. I would draw the picture, print it with a printer, heat transfer that onto the board then dunk it in the acid solution which would eat the copper layer off. Then I would have to very carefully drill all of the holes.
With the SO I still have to draw it up. There was a bit of trial and error before I figured out cut settings. The last one, the top one in the above picture, took about ten minutes. This method puts the holes exactly in the right places. Accuracy is exceptional for a hand held tool. That board is less than an inch tall.
This is a few of the mistakes, as you can see I can even cut the piece out.
02-08-2019, 09:36 PM
#445
Chassis: Blue Bird
Engine: ISC 8.3
That Shaper tool is incredible. Gotta love milled circuit boards -- we don't see many of those anymore! I've done a few boards over the years using the positive or negative photoresist followed by the ferric chloride etch.. but now I usually order my boards through oshpark.com. I could barely manage to get 0.05" SOIC footprints to work out with the photoresist technique; with today's VQFN and smaller/denser packages I expect the DIY photoresist would really be a struggle.
How fine can you go when making PCBs with that Shaper -- any idea what traces & spaces widths or pad pitch it can reliably manage? And.. dare I ask.. have you tried to make a two-sided board? It seems like it might work.
02-08-2019, 10:46 PM
#446
Chassis: AARE
You can get pretty accurate. The traces on this board are 3mm, a couple are 2mm. My bits are some of the limiting factors. The first one I did I just outlined the traces with a 20 degree engraving bit at a depth of .003" (forgive me I think in inches) I didn't take out any of the unneeded parts between the traces.I don't have any way to measure the spacing but it would appear to be .002" or so. I checked with an ohm meter and everything was good.
The smallest end mill I have is .0625. For the one in the picture I did as much as I could with that bit then ground the sharp point off of a 20 degree engraving bit and finished up in the tight places with it.
Two sided should be possible especially, since you would have the holes to help with alignment.
My stuff is pretty simple and are almost always one offs. I could probably just solder on a breadboard but, I hate doing that and think they just look messy. I wish I had this when I built an electronic ignition for my Cushman.
02-09-2019, 04:59 AM
#447
I did the old photo tech boards but only for through hole based boards. Even then if I needed really thin traces I had issues occasionally ... started ordering my boards out and they came back drilled and with plated through holes. I’ve soldered SOC with fine tip but never used any QFN packages that weren’t already soldered to a DIP adapter
Christopher
02-25-2019, 11:30 AM
#448
Chassis: AARE
Mirror cabinet
I just finished a solid walnut mirror/makeup cabinet for mumsywumsy. It is really hard to get any pictures so I did a video. Pardon the shake, didn't realize just how shaky this old guy is getting.
https://youtu.be/K0uPL7RnECE
I'm sure someone has told me how to embed videos but I don't remember.
02-25-2019, 11:42 AM
#449
Nice work on the cabinet, I like the auto shut off light.
04-06-2019, 11:48 PM
#450
Rated Cap: 34
Copied this pic when I first saw it last year, so i could find it when I was ready to start my shower.....LOVE the look of this.
The shower walls look too thick for paneling.....is that a beadboard, or separate planks with a plywood backer and sealer, or what? And if they are separate planks, did you bevel or round-over the edges? And how did you seal between the planks? I thought about just using copious amounts of spar urethane, but that would require finishing in a horizontal position....due to space limitations, I'm planning on building in-place. And my walls will only be waist-high.
Thanks for any insight.
04-07-2019, 08:27 AM
#451
Chassis: AARE
The wood is tongue and groove red cedar should be available at most lumber stores.
https://www.lowes.com/pd/5-375-in-x-...ank/1000456701
I built the panels by edge gluing the planks with waterproof white glue and then used three coats of Spar urethane while the panels were laying flat,
making sure it ran into the cracks well.
https://www.lowes.com/pd/Minwax-Helm...l-oz/999913671
For the two walls that are freestanding I glued and varnished luan panels to them. Walls are arranged to shower pan like this.
Corners are sealed with silicone then I made a triangle piece out of the cedar to glue in place with silicone.
I would think that you could build walls and assemble inside especially since you are only going waist high. Let me know if you have further questions.
Dick
04-07-2019, 04:19 PM
#452
Chassis: AARE
Shower door
After 4 years I finally have a shower door. It also serves as a night light.
04-07-2019, 05:03 PM
#453
Very well done sir! Lots of talent showing,
04-07-2019, 07:09 PM
#454
Rated Cap: 34
That is exceptionally well done.
And thanks, Dick, for the pointers in your previous post. I can only hope mine turns out as well as yours.
04-07-2019, 09:48 PM
#455
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
did you do the glass decoration? - is it etched or sand blasted? - by hand or computer? - looks great
04-07-2019, 09:49 PM
#456
Chassis: CS RE
Engine: ISC 8.3 L 260 hp
That is the coolest shower door I've seen! Nice work!
Ted
04-07-2019, 11:08 PM
#457
Chassis: AARE
Thanks guys.
I did the decoration with my Shaper Origin. https://www.shapertools.com
I drew the design on my computer then cut it into lucite.
04-08-2019, 02:11 AM
#458
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
Thanks guys.
great tool - must be fun creating with that
04-08-2019, 10:11 AM
#459
2 questions for you:
#1 How do you cut a straight line if you're that shaky?
#2 Why the double hinge? It's interesting just wondering why.
I believe it's just [youtube] K0uPL7RnECE[youtube]. Use just the last part (the identifier) between the two. And don't forget to include the backslash in the trailing. I left it out so you could see the html tags.
04-08-2019, 10:16 AM
#460
What size shower pan is that? In the pic plfking posted, I count two hat channels. That's a big shower.
