Old 02-23-2012, 06:34 PM   #41
Re: Somewhereinusa
Mmm...we are planning three zones,bedroom,kitchen/lounge and driver/navigator....what is your 4th zone(or room)?
Are you planning to "heat" tile and other type heat sinks?or just wood floors
Old 02-23-2012, 09:04 PM   #42
Diesel Dan's Avatar
Engine: DT466/AT545
Re: Somewhereinusa
Wow, dude, that's cool. I mean... warm.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 02-23-2012, 09:30 PM   #43
Re: Somewhereinusa
Looks very good.
Old 02-24-2012, 09:08 AM   #44
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Rated Cap: Her, me and Molly
Re: Somewhereinusa
My four zones are bedroom,bathroom,kitchen, and front computer/living area. Floor will be 3/4 plywood that has a plastic coating on both sides. Pex will be in a sandwich with plenty of room around it for warm air to circulate (ie: not captive in grooves) I am also adding provision to put a heater/fan in each room if needed. Original front heat/defrost will be plumbed into the front zone.
I'm not an engineer, but I have been around the block a few times. I don't really know if any of this will work, but I will have warm floors.
Old 02-24-2012, 09:59 AM   #45
Chassis: Genesis
Engine: Cornbinder 466
Rated Cap: 71
Re: Somewhereinusa
Your doing all of this just for your dogs comfort? Good dogdad... Looks great, what type of compression tool are you using on the rings?
Tracy
Newfiedogs is offline   Reply With Quote
Old 02-24-2012, 10:12 AM   #46
Chassis: AARE
Re: Somewhereinusa
Actually the dogs will probably think it's too warm, although Kate will be 9 this year and may be looking for a warmer spot.
I got this tool from Lowes.com
http://www.lowes.com/ProductDisplay?...llow&cId=PDIO1
I wanted the one with the ratchet for tight spaces. I had to order it on line, the stores seem to carry the Apollo brand that has a lot of bad reviews. This one has good reviews.(It's probably the same tool with different colored handles)
Old 02-24-2012, 11:27 AM   #47
Chassis: Genesis
Rated Cap: 71
Re: Somewhereinusa
Thanks,
I have been wondering which to buy once I start running plumbing. Looks like it will work in tight spaces as well. I have a place I can rent one from but as you know its always better to have your own.
Tracy
Old 02-24-2012, 06:54 PM   #48
Re: Somewhereinusa
Sounds like it could be really cozy, but I have to wonder about condensation on the lines in the closed plywood areas. Packed into concrete, it's not really an issue, but plywood, even coated...and mold...??? Just thinkin out loud.
Old 02-26-2012, 07:01 AM   #49
Chassis: AARE
Re: Somewhereinusa
Unless you have some information I don't, condensation is only a problem on pipes with water that is colder than the air temp around them.
Old 02-26-2012, 09:38 AM   #50
PDBreske's Avatar
Rated Cap: 1
Re: Somewhereinusa
You're right—condensation won't be a problem for hot water lines (as long as you don't spring a leak somewhere, so be VERY careful with nails after you've installed the tubing under the floor).
I do question, however, the idea of having a "PEX sandwich with plenty of room around it for warm air to circulate." Air is an insulator and will tend to minimize the amount of heat transferred to the flooring. The reason they normally place the PEX into grooves is to transfer the heat directly to the floors, which then radiate that heat up into the room. Frequently, the PEX tubing will also be placed into aluminum channels that help to further radiate the heat. In either case, the PEX is held in those grooves very tightly to minimize insulating air and maximize heat transfer between the water and the surrounding surface.
Read about the "Camel" RV Conversion project!
My first passion is photography. Visit my website to see some of my work.
somewhereinUSA out and about somewhereinusa Conversion General Discussions 53 08-24-2017 02:09 PM
Props to be thrown to somewhereinusa bapos Forum Admin | Account Help | Suggestion Box 0 06-23-2013 10:54 AM
