Old 05-14-2015, 01:19 PM   #241
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
is the roof rack bolted to the ribs on top?
thanks
Cliff
Yes, stainless sheet metal screws, this is a factory roof rack.
Old 05-14-2015, 10:32 PM   #242
Placing my order first for 3 of those lights...where do I send my money?
Great improv.
The-Breeze is offline   Reply With Quote
Old 05-17-2015, 10:16 AM   #243
browncrown's Avatar
Rated Cap: 79 at Birth
Love your lights...brilliant idea!
BC
My Conversion Thread: https://www.skoolie.net/forum/viewtopic.php?f=9&t=3065
Old 05-17-2015, 02:26 PM   #244
Chassis: I.H.
But where did you get or order your lights that you took apart to use? Details?
Old 05-17-2015, 07:46 PM   #245
M1031A1's Avatar
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
LOVE the pun!!!!
M1031A1 is offline   Reply With Quote
Old 05-17-2015, 08:31 PM   #246
browncrown's Avatar
Originally Posted by M1031A1 View Post
LOVE the pun!!!!
Didn't intend that but...lol Those lights are NICE!!!
BC
Old 05-18-2015, 06:36 AM   #247
Chassis: AARE
This is the place, just one of many available
20 Pcs T10 Xenon White Car RV 24 SMD LED Light Bulb 168 194 501 W5W 2825 175 192 | eBay
Quite simple to take off the plug and solder on new wires.
Old 08-07-2015, 09:01 AM   #248
Chassis: AARE
I got the rear unit operational yesterday and couldn't be happier. Still have some final dressing up to do. It wasn't really all that hot yesterday, but I did get the bedroom down to 65 in a couple of hours. It was cool enough this morning to test the heat, made it toasty in the back. This thing is QUIET, if nothing else is making any noise, when I first start it up, I get a sense of the outside unit more than being able to hear it. When it's running the only thing I can hear is the inside fan, which is very quiet. It blows very cold or hot depending on the setting.
I hooked up my Kil-a-watt, on start up it VERY slowly climbs to 7.3 amps, then falls to 2 to 3. I just checked and while on high heat it was at 10 for a few seconds then fell again.
Condenser unit mounted in original condenser space. I will put the original screen and trim back on. The frame is the original, that never seemed to have been damaged, I also mounted a second rock guard in front. (the white one)
There was no way I could get the larger line routed around all of the corners, I tried, without kinking. The smaller of the rubber refrigerant lines from the original factory air was the right size, so I had new flair ends put on it and it worked perfectly, I'm hoping this will also alleviate the problems some have had with line breakage, the 1/4 inch line is much more forgiving. I then insulated the rubber line. When I pulled a vacuum, I was a bit surprised to find that it stayed exactly all night, I figured it would change some because of the temperature change. The sun was shining on it when I did it and it was cool the next morning.
The condensate tray on the evaporator had provisions for a drain at either end so I put a T in and used them both. I painted the inside unit so it wasn't that ugly white, I may do some sort of enclosure to hide it later.
I'm a little concerned about how the feet are fastened to the body, just two spot welds. I also made an upper mount to help control movement at the top, hoping to reduce stress on the bottom feet. I made the bottom rubber mounts more to keep from crushing the feet when I bolted it down than anything else.
Only time will tell if this was really a good installation, but right now I am extremely pleased.
Dick
Old 08-07-2015, 09:51 AM   #249
AWESOME work. I absolutely love your bus!
So hows that ac? you liking it?
Old 08-07-2015, 07:48 PM   #250
browncrown's Avatar
Have to agree...awesome job dude
BC
Old 08-08-2015, 01:41 PM   #251
Engine: 190hp 5.9 Cummins
As always, you don't mess around.
Good job.
Old 08-21-2015, 05:43 PM   #252
Chassis: AARE
I got the front air conditioner finished today, it's not really all that hot today, but they cool things down nicely.
The condensor is nestled between the frame rails in front, not sure if I will have to do some extra ducting to get the air flow right. These things don't really seem to move all that much air, even when things are running hard after the initial slow start. Time will tell. Have I mentioned how QUIET they are?
This view is from in front of the right front tire, pretty open to the fan, there is quite a bit of air movement out this general direction.
Same side viewed from the front.
Other side viewed from the front. It doesn't hang down as far as the front entry step and is farther back.
I was able to use the larger copper line, I cut the insulation off then but it back on after I had it installed. Lines go around the windshield on right side. Overall I am quite pleased with the whole thing. Measuring the power required to run, they could both be run on one 20A circuit. Only time will tell if things hold up in the bus environment.
Old 08-21-2015, 06:11 PM   #253
Chassis: Blue Bird
Engine: ISC 8.3
Niiiice. I may or may not be a little jealous. How well does it cool to the back of the bus..?
Old 08-21-2015, 06:33 PM   #254
Chassis: AARE
There's one just like it in the back. I didn't run it all that long, cooling down quite nicely.
Old 08-21-2015, 06:51 PM   #255
Do you have a plan to protect the AC? I look at the general state of the under body and it looks like it's going to take a beating from the rocks on the road, no?
mrblah is offline   Reply With Quote
Old 08-21-2015, 07:04 PM   #256
Chassis: AARE
Where would the rocks come from? It's in front of the tires. The rear one, which is behind the tires is protected.
Old 08-22-2015, 11:51 AM   #257
browncrown's Avatar
Great install on the air conditioning system!
BC
Old 08-22-2015, 12:26 PM   #258
Looks fantastic... Just about how I've been envisioning it... WELL DONE, sir.
Old 08-22-2015, 06:24 PM   #259
browncrown's Avatar
Very well done!!!
BC
Old 08-22-2015, 09:54 PM   #260
sojourner's Avatar
Engine: DT408
SWEET!!!! Or I should say, COOL!!
sojourner is offline   Reply With Quote
somewhereinUSA out and about somewhereinusa Conversion General Discussions 55 01-29-2019 02:59 PM
Props to be thrown to somewhereinusa bapos Forum Admin | Account Help | Suggestion Box 0 06-23-2013 10:54 AM
