01-01-2017, 09:22 AM
#201
Year: 98
happy New Year
nice work, I can see that with your travel plans more insulation is not required but now that all the difficult work is done I think adding and filling the dead space with more insulation does not add a lot of cost and certainly would increase the possibilities if you would ever change plans or would sell the bus. It also helps with sound / noise an leaves less space for critters to hide.
Are you using expandable foam around the edges to seal and glue everything together? Filling up all the space also adds considerably to the rigidity.
thanks for the 70-80F trip route links
Later J
01-01-2017, 09:35 AM
#202
I'd Love to do a full perimiter of the USA trip sometime... i have ZERO interest in going to Canada or Mexico. .. but yeah start at the top of I-95 in the fall and work southward.. then outwest in the early spring...
even though I dont camp I'd drive by bus anyway
Hey Christopher,
There is sooo much to see in the US. I took a six year trip and covered 46 States. I would do it again in a heartbeat if I had the means right now.
But.... Mexico has its merits as well. Give it chance You are missing out if you don't at least give it a try.
It is going to be 82 and sunny in Mazatlan today.
01-01-2017, 02:34 PM
#203
Engine: t444e
I'm going to be filling the entire void between the stringers with foam board and I won't be living in my bus full time. Chasing 70degrees or not, IMO you are under insulating
01-01-2017, 02:56 PM
#204
I'm thinking of insulating 2" in floor, sides, and ceilings. My bus will spend 99.8764675% of its time in FL, and likely the remainder of its life in the southeast.
01-01-2017, 03:35 PM
#205
Originally Posted by joeblack5
happy New Year
Later J
Thanks for your input Joe, it's appreciated. All the foam board is cut bigger than the opening and is a very tight press fit so no need to glue it all together.
As far as the critters go there are way to many other places for them to enter if they want to get in, like the front bi-fold bus door. So I'm not worried about that. I'm not trying to make an impregnable fortress from bugs.....lol.
01-01-2017, 03:47 PM
#206
Oh, I'm going to have A/C in my bus and a heater as well if I ever need them in the mild climates I happen to be in. Besides, all the insulation in the world will only do so much with those horrible inefficient single pane windows we have in our buses
01-05-2017, 09:02 AM
#207
Finally got all the rusted through areas patched around the wheel wells and put on a good coat of rustoleum paint. Now time to put in the floor insulation and plywood subfloor.
01-05-2017, 09:18 AM
#208
Do you plan on closing all those seat bolt holes first?
01-05-2017, 10:27 AM
#209
Oh yeah, my bad. Forgot to mention that Will probably go this route with door panel fasteners and a dab of silicone caulk to seal them completely.
01-05-2017, 12:41 PM
#211
Originally Posted by DoubleO7
DoubleO, that is not a bad idea either. Thanks for pointing that out. Appreciate it.
01-05-2017, 02:47 PM
#212
Rated Cap: 65 pax
Originally Posted by FlyboyHPD
Sounds good Sandi. I'm definitely going to make a trip up to New England someday for a great lobster roll.
And live maine lobster off the boat in the harbor! We did that summer of 2015... amazing!
01-05-2017, 03:07 PM
#213
Looks like you got a lot accomplished during the holidays. Tango, GreyCoyote and myself will be getting together soon to have a couple of beers and discuss this Texas Skoolie thing. Would you be interested in meeting with us ?
01-23-2017, 11:24 AM
#214
Did you all meet up? i was off for 3 weeks during the holidays and would have had the time but I didn't see anything posted about it.
01-23-2017, 11:29 AM
#215
My bus got a new "man cave" this weekend. A nice 13x55 enclosed and secure storage unit. Will be better than having to work out in the damn sun come summer time again.
Here is a little video. Will try to get it to post later today.
https://www.facebook.com/eric.bakke....1050405312065/
01-23-2017, 11:32 AM
#216
No we were all busy. Will let you know when we can schedule. You know how life is. It's always getting in the way.
01-23-2017, 11:35 AM
#217
Anyone know of a place that I can get a lanyard type drain setup to help drain my air tanks instead of crawling under the bus every time?
01-23-2017, 01:03 PM
#218
congrats on the ManCave! good for you!
01-23-2017, 01:48 PM
#219
Engine: Navistar 7.6L
Like this $11 one?
https://www.amazon.com/Compressor-Va.../dp/B00BBZGWIC
01-23-2017, 02:04 PM
#220
Thanks DoubleO, that might just do the trick. I'll crawl under the bus and get a measurement to see what size the manual valve is and if this will work.
