Old 04-09-2017, 07:59 PM   #261
FlyboyHPD's Avatar
Gotcha. Plugging those leaks are very important, from the ceiling and the windows. Otherwise whatever floor you put down will get ruined.
Hopefully the rain will let up and allow you to make some more progress or at least make it more pleasant to work on.
1999 International AmTran, DT466E, MD3060
https://flyboyrv.wordpress.com/
FlyboyHPD is offline   Reply With Quote
Old 04-10-2017, 03:58 PM   #262
FlyboyHPD's Avatar
Spent the morning getting rid of a bunch of old wiring. Still have a lot more to go but at least making a dent in the process.
This was just from the rear and midship heaters. Still have the front and rear flasher wiring to remove.
Old 04-10-2017, 04:08 PM   #263
Robin97396's Avatar
There was that much change in the side panel too?
You're a brave man. I pulled out the dead end wires that were just hanging, but anything that could possibly have to do with the interlock stays right where it is.
Robin
Nobody's Business
Old 04-10-2017, 04:22 PM   #264
FlyboyHPD's Avatar
Well to be honest I knew that what I was removing today had only to do with the heaters inside the bus so I was not to concerned.
I will at some time try and remove other unknown wiring but to be on the safe side whenever I do that I will always remove/cut only 2 or 3 wires at a time and then re-start the bus to make sure I haven't broken any interlock circuits.
Old 04-26-2017, 08:26 AM   #265
FlyboyHPD's Avatar
Not a Skoolie but the interior and attention to detail is amazing.
https://www.facebook.com/houseboxhou...c_ref=NEWSFEED
Old 05-03-2017, 08:19 AM   #266
tobeamiss's Avatar
Beautiful!!!
oh yes she did!
http://www.skoolie.net/forums/f11/to...-it-16557.html
international amtran, southern comfort
