Old 06-10-2015, 09:35 PM   #101
My daughter came up with a saying:
"If it's yellow let it mellow, if it's brown flush it down".
That philosophy has helped us considerably since our leach field here at home got breached and we tend to have overflow from the tank go into the ground about 100ft away. We live in an agricultural district on 4 1/2 acres so we haven't gotten around to putting new field in yet.
We have a jabsco toilet for the bus. It's a marine toilet and has the wet dry feature (add water when taking a crap and leave dry when peeing only.
It has the good ole hand pump to pump in as much water as we need to flush it down when we chose. I think it's a great water saver for the bus. If anyones interested I can run out to the bus to get the model #, we bought it brand new off of CL for a $100 bucks from a guy who changed his mind and bought a smaller one for his boat rebuild.
The-Breeze is offline   Reply With Quote
Old 06-10-2015, 09:51 PM   #102
Chassis: I.H.
I'll post a pic when its finished. I am building mine from stacks of 3/4" plywood. The outside will be shaped like a basic house toilet. The inside will be open to the bottom with just enough cutout of the bottom layer for the bucket to keep it upright and lined up. It will have a conventional seat and lid.
Old 06-10-2015, 09:58 PM   #103
Zephod_beeblebrox2's Avatar
Year: 1994
Coachwork: carpenter
Chassis: international
Engine: 466dt
Rated Cap: 59
I demolished the toilet I built in order to use the brackets when I was short. I'm going to rebuild but stronger and better.Click image for larger version
ID:	7290 This is the basis for my toilet - and a box of cast lit lol.
Zephod_beeblebrox2 is offline   Reply With Quote
