Old 08-22-2019, 03:08 PM   #1
Engine: 7.3L Navistar T444 Diesel
Rated Cap: 54-78
Stella The Skoolie Build
Hope this is the right place for my build diary. I know I'm going to have a bazillion questions but I promise to search for the topic first.
Tammy1029 is offline   Reply With Quote
Old 08-22-2019, 04:18 PM   #2
Coachwork: Blue-Bird
Chassis: TC RE 3408
Engine: 5.9 Cummins 12V Mechanical
That looks like a good place to start. Welcome to the forum.
gs1949 is offline   Reply With Quote
Old 08-22-2019, 06:41 PM   #3
Chassis: TC RE
Engine: 8.3TA
Welcome to the madness. Enjoy!!
GaryC
Gustav is offline   Reply With Quote
Old 08-23-2019, 03:34 PM   #4
Rated Cap: 54-78
Seats finally removed
The first 15 came out easy peasy but the last 7 had an extra nut that was too close to an angled leg to get the ratchet on. I had to face my fear of the grinder and cut those bad boys off.
Old 08-23-2019, 03:38 PM   #5
Chassis: TC RE 3408
Good for you, I think it's all about challenging boundaries, especially self-imposed boundaries.
Old 08-23-2019, 03:43 PM   #6
Rated Cap: 54-78
Self imposed is correct. My next fear is over coming a circular saw. Jig saw, scroll saw, sawsall, Im totally fine with. Just something about seeing so many posts about accidents with them has me freaking out. If I could get HD to make all the cuts Id be thrilled. Lol.
Old 08-23-2019, 03:52 PM   #7
Chassis: TC RE 3408
Well, now you have the new attitude. You just need to practice and strengthen it.
I'm working on strengthening my attitude too. But in my case it's really not a new attitude. There was a time I never hesitated to taken on a new project just because it meant I had to use sharp tools and learn new skills.
But during those earlier times I was always pretty far from turning 70. Now I have a few weeks to go. So that's the attitude I have to replace, and I do feel younger or at least better since I started this bus project.
Old 08-23-2019, 05:41 PM   #8
Ronnie's Avatar
Engine: 345 international V-8
The heavier worm drive circular saws are less likely to kick back and because of the handle position if they do kick back they do not tend to come out of the cut and expose the blade to you. The high handle position on must modern circular saws can lead to it kicking right out from under you.
I have two worm drive "Skil" saws a 6" and an 8" .
Old 08-23-2019, 05:52 PM   #9
Chassis: TC RE 3408
And the right blade for the job is often fairly critical.
Old 09-07-2019, 01:23 PM   #10
Rated Cap: 54-78
51564D36-C8BF-4338-9A44-22FE09A5FE57.jpgHad to take a couple of weeks off due to the excessive heat. 114-118 every stinking day! Question??? This is the foam from the seat bottoms. You know how people box in the wheel wells in the interior and then use spray foam or loose insulation for sound deadening? Would the foam from the seat bottoms work the same way? Im trying to reuse whatever I can to save money and keep it out of the landfill. Even the plywood for odds and end use. Or a turtle house for my sisters turtle. 🐢 😂 Feels good to be back working on her.
