11-28-2016, 10:28 PM
#21
Coachwork: Wayne Corp
Yea and it looks like the church didn't do any prep work on thier paint job. Not to mention all the scrapes and dings the church put in it. Nothing a little welding and grinding cant fix. Plus a thick layer of elastomeric paint.
Sent from my SAMSUNG-SM-G891A using Tapatalk
1990 International 3800 DT360 and AT545.
2007 Dodge 5.9 with a 6 speed.
6 Kids,1 Cool Ol Lady
Lots of life to live.
01-31-2017, 12:13 PM
#22
I am back at it after a break. I am now removing rust from the floor and putting down Ospho. Its a long process. I haven't taken any pictures as of yet. I also have drafted my 12VDC system and my layout.
02-04-2017, 08:27 PM
#23
A twisted wire wheel on a grinder plus elbow grease and a filthy pair of coveralls..... Finally i put a coat of Ospho. I am almost done with the weld prep on the floor. I had a ton of rust. Slowly working towards the finish line. 😊
05-09-2017, 08:24 PM
#24
After a busy couple of months at work. I am finally back working on the bus. I did a little work here and there. I wire wheeled 5he entire floor. Osphoed the floor. Primed the floor with Rustolium heavy rusted primer. Patched large sections of the floor. Sealed the seams. Primed again and then finally today I was able to lay the topcoat of Rustolium paint.
05-09-2017, 08:54 PM
#25
I liked how that piece at the rear right bumper looks. Beautiful work.
Nice to see individuals like your self just playinn but building something real, solid and functional.
You know your craft well sir.
05-09-2017, 09:19 PM
#26
Great work!! I also had to stop on the inside and start working on the outside because of leaks!!
I sealed up a few of the problem Windows but they're still leaking so i guess it's time to figure out if it's coming from the drip edge as well.
You really don't mess around when you say you're gonna spend time on the bus. It's looking and coming along great!
05-09-2017, 09:46 PM
#27
Coachwork: Carpenter Body
Rated Cap: 65 to Zero. Folding Chair
Wow, good job. You had to replace more flooring than I did.
Looks great.
D.L. Jones III
"The Independence"
98 International
05-10-2017, 09:05 AM
#28
That is a lot of patching. I will have to do some myself. Hopefully not anywhere near that much. More ceiling tin? Better than selling it for 4 cents a pound. Should have kept a few of my seats. I'll reuse the ceiling panels. I wonder if I can get them fully flat. I wouldn't mind redoing the entire floor. Rust proof the original then cover with ceiling panels and repeat.
I need to get to this point. My ceilings and walls are still up. This weekend is the gf's bday and next is mother's day. I need to get to grinding rust before it gets hot and nasty out.
05-10-2017, 11:21 AM
#29
Thanks all for the cudos... I used some of the removed interior pannels for the patching. Wayne used heavy duty steel panels all throughout the bus. I am trying to reuse all of the metal I can.
With the leaking windows I did have to fully pull them and seal everything. I had water coming in around the frames. . It is a little extra work but you get a sealed bus.
05-10-2017, 11:24 AM
#30
I finally found my insulation and ordered it on Amazon. I am using 1.5" Rock Wool Panels. They are rated to 2000deg F and ate not susceptible to moisture problems. The main reason is they are 100% safe. No offgassing.
05-10-2017, 11:59 AM
#31
I understand that modern rockwool is much improved over older glass insulation. I was always worried about dust, like in the glass insulation.
Modern spray foam doesn't seem to off gas like the old stuff, and it's non flammable. I did used some styrofoam panels which I guarantee won't hold up to the heat from a match.
Robin
Nobody's Business
05-10-2017, 12:21 PM
#32
My windshield was dripping on the inside. I have't seen ANY leaks elsewhere. The floor (rust) has stayed dry since the plywood was ripped out.
Got a link handy? Sounds like something that the gf would be all over especially if it's all natural and real wool.
05-10-2017, 12:56 PM
#33
GREAT job!!!!
That's the same system of rust repair/paint I use.
For exterior- add a hardener to the paint, and use a clear over it and it will last a long time!
05-10-2017, 12:57 PM
#34
It is made by Roxul http://www.roxul.com/products/roxul-comfortboard-80/ it is made from Rock.
05-10-2017, 01:00 PM
#35
Its good stuff. I tell folks about it all the time. I'm using it on all my interior walls.
05-10-2017, 01:11 PM
#36
Well, the government hates it.
Network Error
- A communication error occurred: "Operation timed out"
The Web Server may be down, too busy, or experiencing other problems preventing it from responding to requests. You may wish to try again at a later time.
05-10-2017, 01:24 PM
#37
The link didnt post
05-10-2017, 02:20 PM
#38
The link didnt post
Doesn't work when going directly either. Grrrr.
I found it on Lowes and Home Depot tho.
Roxul Comfortboard IS Sheathing Board
Roxul COMFORTBOARD IS a rigid mineral wool insulation sheathing board that is non-combustible, water repellent, fire resistant and sound absorbent. Roxul COMFORTBOARD IS is an exterior non-structural insulation sheathing that provides a continuous layer of insulation around the residential building envelope.
05-10-2017, 02:24 PM
#39
Depending where you live it may be special order. It is readily available in the north. I had to get it from Amazon to avoid buying twice the amount needed. Home Depot and Lowes would only it to sell me in bulk...
05-10-2017, 02:40 PM
#40
Well that's jacked up. Does MD count as the north? I didn't see anything about bulk on their website. Not that I'm ready to buy anything anyway.
