06-18-2017, 07:23 PM
#61
Brilliant idea using interior sheet metal over windows. You just solved several issues for me. Thx
Sent from my SM-T377V using Tapatalk
06-19-2017, 11:18 AM
#62
Coachwork: Wayne Corp
I try to recycle all I can. Keeps the conversion cost down. I tried hard to line all of the pannels up for a seamless installation. I took a good bit of pictures during the window delete. If you have any questions let me know.
Sent from my SAMSUNG-SM-G891A using Tapatalk
1990 International 3800 DT360 and AT545.
2007 Dodge 5.9 with a 6 speed.
6 Kids,1 Cool Ol Lady
Lots of life to live.
06-19-2017, 02:53 PM
#63
Chassis: Thomas
Engine: CAT 3126
Good idea! I wonder what else they might be useful for if not covering windows?
Sent from my SM-N900P using Tapatalk
06-19-2017, 03:28 PM
#64
My ceiling panels are perforated but I'd still like to use them to cover several windows. My theory is the perforations are small enough to keep out those huge Alaska and Canadian mosquitos. Sometimes I've needed ventilation without the bugs.
Robin
Nobody's Business
06-19-2017, 08:14 PM
#65
I also used them for patching the floor, and outside walls.
06-20-2017, 07:34 AM
#66
My ceiling panels are perforated but I'd still like to use them to cover several windows. My theory is the perforations are small enough to keep out those huge Alaska and Canadian mosquitoes. Sometimes I've needed ventilation without the bugs.
I dunno if yours are the same as mine. Probably not since I only have two that are "screen" but mine are small enough to keep out everything except maybe gnats. Since they swarm and not really fly thru stuff, would work for them too.
06-20-2017, 10:11 AM
#67
I plan to keep all my windows, but I clearly see the need to cover at least some of them. There has been plenty of talk about using either regular or perforated panels to cover windows from various members here. I've never seen ceiling panels used for exterior window covers yet.
Bugs are fairly bad this time of year. I need some ventilation without the bugs being able to get in. I'm remembering trips through Canada on my way to Alaska in muggy weather and not being able to open a window even at highway speeds due to mosquitos. There are areas where the mosquitos will actually kill deer due to blood loss.
The AlCan highway doesn't seem to have rest stops, other than the occasional fishing turn-out. This was years ago, but there were no bathrooms along the highway. Attempts to do your business in the woods, like a bear, were met with mosquito bites that feel like bee stings. From what I'm told it's largely a matter of timing, because some people report no problem with bugs on the AlCan.
Chances are it would be simpler to just use bug screen.
Robin
Nobody's Business
06-20-2017, 10:23 AM
#68
The sun screen under my TDI moonroof is what I'm thinking you'd end up with only in metal.
not being able to open a window even at highway speeds due to mosquitoes.
That is pretty impressive (in all the wrong ways). That very well may need the zombie mosquito proofing that the steel ceiling panels would provide.
I'm thinking they are doing it more permanently than you. The window behind a cabinet, in the bathroom, etc. Air flow but no visibility. Weld the sucker on there and forget it.
06-20-2017, 11:17 AM
#69
Those are some extraordinary bad ass mosquitos that I had never seen before or since. I figure perforated ceiling panels would stop a bb from penetrating so it ought to be good for skeeters. I'm just talking about several strategically placed panels to allow ventilation while in skeeter country. Not behind the shower that I don't have.
I was thinking of just pop riveting the panels because I frequently have a tendency to change my mind and rearrange.
These are bug screens that little kids can't stick their finger through.
Robin
Nobody's Business
06-20-2017, 11:38 AM
#70
WI and MN have some pretty badass skeeters too. ME has black flies that will take a chunk of hide out of you as well. You'd think FL or LA that has a growing season of 363 days a year would have skeeters with wingspans that are measured in feet. Instead it's the mutant bastards that only have a 3 day growing season that get the size of pterodactyls.
Think I'd rather have skeeters. You can swat them and no one looks at you like you're crazy. Not that it is generally the snot lickers' fault. There's more than one occasion I've wanted to slap the bejesus out some brain dead mother in the grocery store.
06-20-2017, 12:00 PM
#71
Recycling
The ceiling panels would make a perfect sun roof, like a Range Rover roof.
Robin
Nobody's Business
07-04-2017, 01:23 PM
#72
07-04-2017, 01:36 PM
#73
Looks good! How do you get the wood to bend to the contour and not crack?
Christopher
07-04-2017, 01:37 PM
#74
Lots of relief cuts 3/4 of the way through. Set your skillsaw depth and make cuts every so often.
07-04-2017, 01:39 PM
#75
Like this
07-04-2017, 01:56 PM
#76
Chassis: Thomas
Engine: CAT 3126
Looks great! What is the plastic sheeting for?
07-04-2017, 03:53 PM
#77
One of my FAVORITE builds goin, man!!!!!! You're doing it RIGHT!!!! Keep up the good work!
You should try to come to our skoolie bbq weekend. Last weekend of Sept.
07-05-2017, 04:59 AM
#78
It acts as backing for the insulation. Reduces debris while i work with the unfaced rock wool. Helps with providing a thermal break betwixt the wood and metal frame. It also gives it a better backing to the pallet board walls i will install. It will have a black backdrop so you dont see insulation in the gaps.
07-05-2017, 05:01 AM
#79
Thanks East Coast. That sounds like a good time. I will definitely try and make it.
07-05-2017, 07:58 AM
#80
Christopher
You could just go down to Home Depot and sort thru the 2x4s. I've seen plenty with more bow than that.
Too bad they often come with a twist that is as bad or worse than the bow.
