Old 02-07-2018, 05:26 PM   #241
Chassis: Bluebird
Engine: 5.9 Cummins/Allison
Rated Cap: 74
Originally Posted by Tango View Post
I have a similar item (red ripper) it bent the teeth floor is directly glued to steel with the darnedist stuff I have ever seen Funny how some is glued to steel and some have plywood even on same type of bus must have to do with specs
Gdog 5651 is offline   Reply With Quote
Old 02-07-2018, 05:53 PM   #242
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Originally Posted by Gdog 5651 View Post
I have an ironworker former and punch press machine that I am sure weighs 2 tons. funny when theives broke into the shop at the other house that's the only thing they didn't steal.
I'd give my left nut for one of those. I can't wait to see what your build loks like.
Old 02-07-2018, 05:58 PM   #243
Mine were Mubea's, a Piranha, and one new one from Belgium that was a total POS failure.
Old 02-07-2018, 06:04 PM   #244
Chassis: Bluebird
Rated Cap: 74
Mine is older and smaller than that but will do everything that one will do. you just have change dies more often I also have about 65 different homemade and factory dies for different operations Also ordered windows today once they get here I will start a build thread on the roof raise.
Old 02-07-2018, 06:11 PM   #245
Chassis: Bluebird
Rated Cap: 74
I just looked at the start of your build page I am like sooo jealous of the work you don't/didn't have to do I am too lazy to read the whole thing did you ever get the fuel situation figured out? and was it the lift pump?
Old 02-07-2018, 06:40 PM   #246
Traveling
Rated Cap: '00
Yes, lift pump was bad, luckily. I upgraded to AirDogRaptor and all new fuel lines. Starts with a bump now.
Old 02-07-2018, 07:49 PM   #247
plfking's Avatar
Rated Cap: 34
Originally Posted by Rusty View Post
Let me know if you ever want me to pack your parachute for you. I always wanted to pack one to see if I could stuff it all in the bag.
Stuffing it all into the bag is the easy part. The hard part is getting it to come back out in a manner that's useful to you when you're 2000 ft in the air and approaching a planet at 120 mph.
Don
The Busted Flush
Old 02-07-2018, 08:07 PM   #248
Robin97396's Avatar
And now we've got sailbussing. Whoo hoo!
Robin
Nobody's Business
Old 02-07-2018, 08:55 PM   #249
Engine: CAT 3208
Rated Cap: 84 pass 36200 gvw
HEEELLLLP !!!!!!!!!
MY BUS WON'T START !!! I'm parked on the sidewalk and need to MOVE !!!
I was just taking out all those wires- WHY is there so many wires? And now it will NOT start !!!
After I removed the big black box thingy, it won't start and I brought it all down to the recycler already.
Do I need to hook-up the switch to the engine or can I just connect the 2 wires by long, brown thing?
There was a few sparks when I cut some wires, but I don't think they went to anything. I hooked the 2 batteries together, but not sure if I did it right- do the red ones go together, or is it the black wires???
SOOOOOMEBODY PLEAAASE HELP !!!!
Funny, I had just the opposite problem. Pulled out about 110 lbs of wire, restarted bus, checked everything still worked that I needed, thought I was golden. Turned off key and engine kept right on going!!
Your last line was me exactly. Lucky my son-in-law used to be a diesel mech.
snonut is offline   Reply With Quote
Old 02-07-2018, 11:06 PM   #250
Traveling
Rated Cap: '00
Ha- I bet you were pretty impressed with your skills- bus started right-up.
...Go to turn it off...and you're sitting there waiting....maybe it's just "dieseling".
2003, bluebird, md3060, succubus, tc2000
