10-15-2017, 11:10 PM
#101
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
I don't hang out in bars, but I do like to go to Home Depot/Lowes on Saturday nights.
Found this stuff:
Not cheap, but has primer, paint and clear-coat. I bot one, will give it a shot.
Genius. Someone is making virgin pallet wood and selling it to the Millennials.
10-16-2017, 07:06 AM
#102
Chassis: Thomas
Engine: CAT 3126
I must've had my head under a rock somewhere not to notice all of your great research and posting on your paint job. Looks really good and I think you were right to use a spraygun instead of rolling. Great find on the rest oleum automotive paint. I wonder what the formulation differences between that and the gloss white oil based that they sell under their professional badge.
10-16-2017, 07:07 AM
#103
Found this stuff:
Attachment 16581
Attachment 16580
Attachment 16582
Man, that was a helluva deal!
I wanna try some of that stuff!
10-16-2017, 08:08 AM
#104
Maybe you could make one of those hitch receiver steps so you could remove it and tow something???
Thanks Rusty, it is only a ball so I didn't think they made one. They do. I am getting one.
I still want a porch but have 20 other things I want to do first.
That's awesome. Better then the candy bars that save blue wales.
I will have to pick up a few for my Prius I case I ever have to drive over a downed tree or something.
10-16-2017, 09:46 AM
#105
Traveling
Rated Cap: '00
I'll let you guys know how that paint looks- I have fleet white truck that needs touch-up.
10-16-2017, 10:48 AM
#106
Entire bus was spray foamed- underside and wheelwells - from factory. Except just this one panel in the rear, had that crappy fiberglass. They were pretty liberal about cutting the foam for tail lights, so will be spot-filling.
Damn, wish mine was.
10-16-2017, 01:21 PM
#107
Traveling
Rated Cap: '00
I'll trade you my foam for your engine.
10-16-2017, 01:47 PM
#108
ISX15 tied to an MD3060*.
* I dunno if that engine actually mates with the MD3060 but I wouldn't be stuck at 35mph uphill.
10-16-2017, 01:51 PM
#109
can an 8.3 like yours be "turned up" even if you could get to that 300 HP threshold you'd probably be able to getting a good running start on hills and maintain.. seems to me I read somewhere that even though 643 isnt rated for it people have run it hard with no issues..
ie back in the day me with my 454HD cammed and intaked and carbed in front of an AT545 that I never trashed... iit was rated way low but seemed to handle whatever I tossed at it. and the 643 is one BEEFY MoFo of a transmission..
10-16-2017, 02:20 PM
#110
It weighs 600 lbs, there had better be some beef to it!! As for turning up the 8.3 L, I've no idea. My paperwork from BB says I have the 260hp engine as it is. Would 15% increase be noticeable?
10-16-2017, 02:21 PM
#111
Traveling
Rated Cap: '00
I have MD3060 trans. I also have a extra Cummins 6CTA sitting here. I know they had them in the FE All-Amercian, but can't see how it'd ever fit in a TC2000. I would like to measure AA frame spread....
Anyway, I'm in no hurry, my bus has - I forget- 26,000 miles on it? I can turn-up the smoke if need be, she'll take it.
10-16-2017, 02:24 PM
#112
28" between frame rails on mine.
10-16-2017, 02:27 PM
#113
I have seen the 8.3 in RV applications at 350-400hp. I am sure that comes at the expense of longevity but it shows that it can be done.
I was reading on Wikipediea the other day and IIRC: Bluebird did NOT put the 8.3 in the TC2000FE but they DID put them in the AAFE.
10-16-2017, 02:32 PM
#114
Traveling
Rated Cap: '00
Boat people get 600 HP out of them, for awhile.
I've heard same thing, BUT....Blue Bird blurred the lines on some of their custom orders- Some TC's are beefed-up to AA standards.
10-16-2017, 02:35 PM
#115
I'm an RE for what it's worth.
10-16-2017, 02:41 PM
#116
im interested to know what hills you go 35 and what your actual weight is.. Ive driven my DEV bus that has a GVWR of 27500 (I havent weighed its actual weight).. with a DT-360(185 HP) and an AT545 all over the eastern US hills and havent hit any that I didnt go at least 42 - 45... makes me wonder if its just s simple as your fuel pressure is low, turbo waste gate stuck open, or such that causes you to not make the rated power ofyour engine..
10-16-2017, 02:43 PM
#117
RE's rule....
10-16-2017, 02:47 PM
#118
Traveling
Rated Cap: '00
RE's rule....
My bus is an RE.... when I back down the driveway !!!!
10-16-2017, 02:53 PM
#119
The hills are 7~9% grade per the signs. My actual weight was 20,600 per the scrap yard scale. For what it's worth, the land fill scale said the same. I'm now up a little with the new sheet metal. Weighed at 1/4 fuel tho.
At 38mph, it finally drops to 2nd gear and I've had that happen a few times.
RE's rule....
Indeed.
That doesn't count unless you are steering from the other end. A set of pulleys and a cables like an old outboard and you can fix that.
10-16-2017, 04:57 PM
#120
Traveling
Rated Cap: '00
Got me thinking, Bob... Never a good thing.
Here is my frame:
