Old 11-12-2014, 10:47 PM   #11
Re: Suzie Blue - Our 1990 Blue Bird TC2000
All emergency exits and exit doors on school buses are wired for buzzers to go off if any of them are opened.
That includes roof hatch emergency exits, push out emergency exit windows, rear emergency doors/exits, and any side emergency doors.
Old 11-12-2014, 10:47 PM   #12
Somehow I am sending stuff more than once.
Sorry about that.
Old 11-12-2014, 10:49 PM   #13
The roof hatch buzzers are the most difficult to reset. The others just need to be closed. The roof hatches need to be closed correctly--not the easiest thing to do every time.
Old 11-13-2014, 09:50 AM   #14
mtunderwood's Avatar
Engine: 5.9L Cummins
Thanks for the advice. I realized this morning that the buzzer has to be for a door, window, or hatch because it happens as soon as I hook up the battery. I'll double check the hatch tomorrow and if I have time I may start wiring the alarms off for good.
-Mikey
Website - http://suziebluebus.com
Build Thread - http://www.skoolie.net/forum/viewtopic.php?f=9&t=468143
mtunderwood is offline   Reply With Quote
Old 11-15-2014, 08:53 AM   #15
The easiest way to do that is to cut the power to the buzzer.
Most of those switches create a ground going back to the buzzer.
If you cut the hot side to the buzzer you won't get a buzz and you don't have to worry about a hot line going out into the bus body that isn't going anywhere.
Old 11-16-2014, 04:02 AM   #16
Boy do I feel dumb! It was one of the side emergency windows. I thought I closed it all the way, but the latch didn't press the little metal nipple button down. Lesson learned, always press firmly on the nipples to avoid an alarm
-Mikey
Old 11-16-2014, 06:06 AM   #17
Coachwork: ward
Chassis: international
Engine: dt360a
and sometimes you need to give em a twist. there should be an audible confirmation.
Old 11-27-2014, 10:10 AM   #18
Happy thanksgiving all! Finally got all the seats out of our bus. I removed some of the rubber floor and thankfully there is no wood underneath. Aside from being covered in glue the metal is in great shape. Been busy working on a blog too.
The best part, I met another skoolie in my neighborhood
-Mikey
Old 11-28-2014, 06:24 AM   #19
Coachwork: IC
Chassis: CE300
Rated Cap: 32
That's great Mike!
Sounds like our buses are pretty similar. I'm halfway through getting the side panels off inside, and will likely have the ceiling out by the end of the weekend.
If you end up getting frustrated with the rivets give me a holler, I've gotten a good system down now for getting them out. Air chisel is your friend!
Keep up the good work! It takes blood, sweat and beers!
Roll Your Own Build Thread
Old 12-06-2014, 03:22 PM   #20
I've been so busy working on all the bus demo that I forgot to update everyone on here I just did a blog post with lots of pics so go take a look! Here's a teaser...
Build Update 03 (Lock It Up!) http://wp.me/p5lsmD-Z
-Mikey
Looking for 90 Blue Bird TC2000 FE manual (SOLVED) mtunderwood Classifieds | Buy, Sell, Swap 3 10-06-2014 09:24 AM
Need Wiring Diagrams for 1990 Blue Bird TC2000 BigBusParts Conversion General Discussions 2 03-11-2012 05:06 AM
blue bird tc2000 operators manual $10 rjz5400 Classifieds | Buy, Sell, Swap 4 05-21-2010 08:04 PM
1991 Blue Bird TC2000 4721 Classifieds | Buy, Sell, Swap 3 10-10-2008 12:10 PM
1991 Blue Bird TC2000 The Wanderer Classifieds | Buy, Sell, Swap 45 05-31-2008 11:19 AM
