Old 07-09-2017, 05:04 PM   #41
Originally Posted by Stu & Filo. T View Post
My first was a 1960 Willy's Cj5 that I removed every nut & bolt from when I was 19, I put in a Buick 225 with a Smokey Yunick kit, then moved onto a 74 Cj5 with the 6 cyl,then a 72 Cj5 with the 304 then went to a 70 Cj5, have a 97 Wrangler now.. If I decide to do anymore projects after the bus it will be a pre smog Jeep Wagoneer with a Cummins or a 4cyl Detroit,Would love to have that as my toad.
I know of someone with a early 80s Cherokee (one of the last of the big body.. or maybe its a wagoneer). they have a 4BT and an allison 1000 in it..
Old 07-09-2017, 05:08 PM   #42
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
It would have to be 75 or older for me.
Old 07-09-2017, 05:19 PM   #43
is that a california thing? I figured itd be just ab ody that you customize out.. im assuming you cant de-smog anything that originally had it ?
we build on stuff here in ohio all the way up into the full frame of the 80s. and get away with ripping it to shreds and building it completely custom.
Old 07-09-2017, 05:24 PM   #44
Yes it's a CA thing, 76 & newer has to be smogged , only mods allowed have to be certified by the C.A.R.B
Old 07-09-2017, 08:33 PM   #45
Lots of Cummins powered Jeeps over on 4BTSwaps.Com. Some mild...some insane!
