Old 12-25-2010, 09:57 PM   #41
yankeflyer's Avatar
Chassis: Safe T Liner
Engine: 3208 turbo
Re: The 72 foot 1994 bluebird/fleetwood motorhome
Roswell - cool - there must something there to take a picture of - still what an adventure -
yankeflyer is offline   Reply With Quote
Old 12-25-2010, 11:33 PM   #42
Chassis: Thomas Navistar
Engine: 7.3 turbo diesel
Rated Cap: 64
I like you lady friend on your refrigerator in this picture Pretty jealous about your trip sound like fun!! thanks for keeping us all updated on it. I'm in Virginia so you got a place to stay or just tell me when you coming through so i can sit on the highway and grab a pic of your rig puttin by
crazyluke4 is offline   Reply With Quote
Old 01-10-2011, 07:39 AM   #43
Year: 1974
Coachwork: American eagle
Chassis: Silver Eagle
Engine: Screaming Jimmy 8v-71
Rated Cap: 46
I was going through texas and was about to miss my exit and snap..there goes the hitch and allot of sparks as the trialer hits the pavment and slamed into the back of the bus.Seems my custom patch weld job on the cracked hitch I put on didn't hold. So I had a new custom hitch installed. Not a bolt up one. I had a shop for 650. Build out of 3/8 tube steel a custom hitch. Tired of driving and sick of walmarts so I am putting the hammer down back to Los Angeles 10-4. The trip for the most part was uneventful other than the What I belive is the oil pressure sensor **** out on me as well. Guess it is common with pre 98' cummins 5.9 The bus is ready for a good filter change,fuel air and maybe do a transsmisition filter fluid change. Can I use regular 10-30w in the transmistion?..Heehe J/K
"Thunder Bird"
Chadluc is offline   Reply With Quote
Old 01-10-2011, 10:34 AM   #44
Stuff's Avatar
snap some road side pics man!
Old 01-10-2011, 02:15 PM   #45
lornaschinske's Avatar
Rated Cap: 89
You have far too much "beige" inside there... You need to add some colour to the decor. Look s like the interior of a stick-&-staples RV. (puppy dog does not count)
Fulltime since 2006
Old 01-11-2011, 12:23 PM   #46
bus-bro's Avatar
Engine: 3208 na boat anchor
It does because it is.
Old 01-11-2011, 12:29 PM   #47
yankeflyer's Avatar
Engine: 3208 turbo
Bet ya wish you had that on tape.
Old 01-14-2011, 10:26 AM   #48
Year: 1974
Rated Cap: 46
Took pics can't find card reader for my SD card in camera. Update on the no oil pressure. Engine never burned a drop of oil. I switched to T6 5-40 and it burned all the oil about.I did an oil change about 3000, miles ago. So in around 3000 miles it burned 4 gallons of oil. I had to buy 4 gallons of oil to add to engine. It had no oil pressure because It had no oil in the engine!! Where did 4 gallons of oil go? I filled the oil in roswell,nm. I have now driven back to Los angeles,CA I am going to check the oil when I go out to the bus in a few hours and let you know How much it burned. Maybe 2 thin of an oil.If thats the case I will be switching back to a 15-40 conventional. ?? Any idea's ??
"Thunder Bird"
Old 01-14-2011, 10:56 AM   #49
yankeflyer's Avatar
Engine: 3208 turbo
Rotella is what I use in my caterpillar, it seems to be the most popular at the truck stops to th the truck drivers. If you haven't noticed a large pool of oil underneath your engine after setting at your local Wal-Mart parking lot , then you must be burning it. The good news is as long as you keep oil in the crankcase it will keep pulling for a long time.
[urlhttp://motors.shop.ebay.com/__?_from=R40&_trksid=p3841.m39.l1313&_nkw=cummins% 205.9l%20engine&_sacat=][/url]
Old 01-14-2011, 12:58 PM   #50
Diesel Dan's Avatar
Engine: DT466/AT545
So I assume you are sure that it is not leaking oil rather than burning? If it's burning that much oil, that's a little scary. If that continues you could experience "runaway diesel" one of these days. If you don't know, that's a condition where so much oil from the crankcase is bypassing the pistons that it feeds the combustion chamber in an uncontrolled manner and the engine revvs out of control until it self-destructs! In that situation turning off the ignition key, fuel cut-off, hitting the brakes, all will be useless - the only way to avert disaster is to manually block the air intake by stuffing something like a folded blanket into it or a flat object on top of it, depending on how your intake is shaped.
All my diesels get Shell Rotella 15w-40 or Chevron Delo 15w-40. I've tried cheaper oil and regretted it. Some people swear by the Mobile 1 synthetic oil, but that is way too expensive for my budget.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 01-14-2011, 06:06 PM   #51
Year: 1974
Rated Cap: 46
It's not leaking for sure. Not a drop.I did notice that the engine smokes alot after I switched oil. Espessially if you let it idle for any period of time. Could be it is still smoking when your driving it..Just the wind is blowing it away perhaps. when I get the funds I'm changing back to a conventional 15-40 before I did the change to synthetic the oil that was in it was in the bus from 2008 from when I bought it from the bus company. I drove another 4000. miles on it and it never burned a drop or leakied in 2 years. I swithced oil and now it is disapperaring. I think If I switch back it should be fine. Engine pulls and runs like an ox
"Thunder Bird"
Old 01-14-2011, 06:52 PM   #52
Year: 1974
Rated Cap: 46
Here is a picture of a fellow skoolie at a truck stop. When I was leaving his chimney started smoking.Must have built a nice fire.
"Thunder Bird"
Old 01-14-2011, 07:02 PM   #53
yankeflyer's Avatar
Engine: 3208 turbo
Ah - Palm trees
Old 01-14-2011, 07:12 PM   #54
Year: 1974
Rated Cap: 46
Here is pics of my new improved hitch.
"Thunder Bird"
Old 01-14-2011, 07:17 PM   #55
yankeflyer's Avatar
Engine: 3208 turbo
looks great
Old 01-16-2011, 08:06 PM   #56
Year: 1974
Rated Cap: 46
I checked the oil. It seemed fine?? I added 4 gallons of t6 in Roswell on my way to Los Angeles. By the reading on the dip stick it didn't burn any oil after driving 1200 miles under the same conditions. ?? Just have to keep an eye out for it. Thinking of moving to lake Havusu City,AZ Property seems a little cheaper there. Well need to save up for the move. ZI get in one place and I'm ready to leave
"Thunder Bird"
Old 01-16-2011, 11:42 PM   #57
bus-bro's Avatar
....and some wonder why skoolies have such a bad rep.
Old 01-17-2011, 11:55 PM   #58
CAMO-MONSTER's Avatar
Year: 1974
Coachwork: CARPENTER
Chassis: GMC-6000
Engine: 454 CHEVY
yeah i know what you mean even thou my skoolie is camo and is a 1974.
hd d44 4.56, eaton ff 4.56
CAMO-MONSTER is offline   Reply With Quote
Old 01-18-2011, 10:19 AM   #59
Stuff's Avatar
not too shabby. I like it. Also grats for taking some pictures! lol
Old 01-23-2011, 03:03 PM   #60
Year: 1974
Rated Cap: 46
Yes that jesus skoolie was something. That like someone who has the mentallity as in ..buy a bus ,paint the windows , cut a hole for the chimney throw in a couch and 5 gallon bucket to **** in. then slap some jesus love on the side and there you go. Your at home home sweet home. **** I would so The same! Just not with the jesus thing going..I'm only 25. Maybe reepaint the bus and do the jesus thing if I was 50
"Thunder Bird"
1994 BlueBird Project gslocobrea Skoolie Conversion Projects 4 02-27-2012 10:20 PM
Foot valve Bavo76 Mechanical and Drivetrains 5 11-08-2011 11:09 PM
Short , 24 foot Bluebird school bus for sale, title- RV lott Classifieds | Buy, Sell, Swap 1 10-18-2011 12:12 PM
1994 Cummins Bluebird 5.9L Bus $3500 obro StrongCo Classifieds | Buy, Sell, Swap 1 09-25-2010 03:29 PM
1994 bluebird turn signals not working Chadluc Conversion General Discussions 3 07-24-2010 04:10 PM
