Old 03-20-2012, 01:17 PM   #111
dogfinn's Avatar
Engine: 7.3L, International
Rated Cap: 35
Re: the akitabus
now to the very back of the bus we go,
dogfinn is offline   Reply With Quote
Old 03-20-2012, 01:23 PM   #112
browncrown's Avatar
Rated Cap: 79 at Birth
Re: the akitabus
Wow, the galley area looks Super Rest of the progress looks like it's moving right along too...nice conversion
BC
Old 03-20-2012, 02:53 PM   #113
Diesel Dan's Avatar
Engine: DT466/AT545
Re: the akitabus
It's not often that someone seals up their rear door. Interesting. I'm curious to see how you utilize that space.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 03-20-2012, 03:09 PM   #114
dogfinn's Avatar
Rated Cap: 35
Re: the akitabus
We still have another rear door (wheel chair door), the reason we chose the rear door to seal off was it had the most problems as far as leaking,
we welded on the outside and caulked the inside ... no more leaks. If we had to do it all over again and had more time we might have just cut the whole back off and put in a straight wall for the rear, because now that we are sheathing it it is not the easiest thing to do, but should look ok when we are done.
dogfinn
Old 03-20-2012, 03:10 PM   #115
dogfinn's Avatar
Rated Cap: 35
Re: the akitabus
The back area will be the master bedroom.
Old 03-20-2012, 03:20 PM   #116
dogfinn's Avatar
Rated Cap: 35
Re: the akitabus
Old 03-27-2012, 12:50 PM   #117
dogfinn's Avatar
Rated Cap: 35
Re: the akitabus
Well we have finally sealed up the back door, first by welding, grinding and then cover the welds with all metal, here are some pics of that process.
Old 03-27-2012, 12:53 PM   #118
dogfinn's Avatar
Rated Cap: 35
Re: the akitabus
then the fun part, cover with all metal with lots of hardener.
Old 03-27-2012, 01:02 PM   #119
Diesel Dan's Avatar
Engine: DT466/AT545
Re: the akitabus
well, I think it's safe to say nobody's going to be coming in through that door! Looks great. I'm jealous of you guys with your welders. I'd like to learn that skill one of these days.
Gallery:
Conversion Thread:
Old 03-28-2012, 07:31 AM   #120
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Rated Cap: Her, me and Molly
Re: the akitabus
I took a night class at the local high school 40 years ago, one of the best,most useful classes I ever took
