06-22-2010, 12:25 PM
#21
Engine: 7.3L, International
Rated Cap: 35
Re: the akitabus
Well the next time cam really quick, like 1 minute later.
Working on the drivers window. Ebay purchase 14.99 plus shipping. talked to Kinro and I am going to order a trim ring from them for the window.
Also decided to get two vented 22x22 windows for the back, seeing how we will not have any windows in the back bedroom that will be able to open,
not to bad of a price, 99.00 apiece from Kinro with trim rings.
Can't remeber if I posted a pic of the two piece door that is now one piece, welded a 1x3 tube steel between the two panels then add some all metal after grinding. Still have alot of all metal work to do over the entire bus, but all in good time.
Till next time
Dogfinn
06-22-2010, 12:41 PM
#22
Re: the akitabus
Great project, makes me feel lazy compared to the work I am doing on the buses right now.
06-29-2010, 01:48 PM
#23
Rated Cap: 35
Re: the akitabus
Started working on the various window frames, Driver, salon driver side and passenger side.
Different shots of the windows, plus a shot of where we hope to put the 36" flat screen above the widshield.
06-29-2010, 01:52 PM
#24
Rated Cap: 35
Re: the akitabus
Just more shots.
07-01-2010, 02:35 PM
#25
Rated Cap: 35
Re: the akitabus
I hope to get to some of the windows in this weekend. What I plan to do is insulate the lifted area (windows) with 2" blue, pink foam whatever I can find at the best price. Below that on the walls and above the chair rail I will use I" foam, as that is what the chair rail bump out is. So that will give just under 2" on the ceiling (not touching that, all ready insulated) 2" on the walls and all most 3" below the windows to the chair rail. below the chair rail I will use it as a wire chase as many before me have done. Sorry no drawings at this time.... it is only in my mind that I know this. I should probably sit down and start writing things out... but I really don't ever work that way. I like to just do, then REDO when it does not work. Call me stupid or thick skulled, thats just the way I roll.
Oh and by the way developed a coolant leak from somewhere up front where that enging thingy is. I have not been able to isolate where it is leaking as it is nearly impossible to see everything. I think it is coming from the pipe extension off the water pump that was there to shut off coolant to the cabin and eventually to the Webasto heater. I did originally replace the little hand valve at the end of this standard pipe extension. Then the other day I noticed coolant dripping and as I was trying to find the leak I undid the ext. with a pipe wrench and low and behold the ext. just twisted right off, leaving the screwy end (threads) inside the water pump. Time to find the EZ out and replace the pipe extension and see if it still has leak... It is hard for me to believe that the wter pump goes out when all I have relly ever done is idle it and perhaps pull the bus back and forth in the drive. (ok so I did take it around the block once or twice about 3 weeks ago) I will try to post some pics of this pipe and valve, and perhaps you guys out there in (outter bus space) can help with your ideas. You have been much help so far so THANKS.....
till nest time TNT
Dogfinn
07-07-2010, 03:10 PM
#26
Rated Cap: 35
Re: the akitabus
Got both Salon windows in, still waiting on trim ring for drivers window. here are a couple of pics of salon windows
Window cut outs
Passenger window in but not sealed at this point, thats why the tarp is still on.
08-03-2010, 04:48 PM
#27
Rated Cap: 35
Re: the akitabus
Fixed the coolant leak, took about 3 hours to find the right tool to remove the broken pipe stub from the water pump housing, finally ran down to work shop and found the right tool, it was 20 years old but had it out in a jiffy compared to the extractors that they sell now a days.
got the rest of the windows in.
and galley.
and started LP tank storage compartment, used to house the On Spot air compressor and tank but was a huge wast of space, so cut out the bottem and added a 5 inches to the height
08-03-2010, 04:51 PM
#28
Rated Cap: 35
Re: the akitabus
this will store two up right 5 gallon LP tanks.
just some welding grinding and cutting
08-04-2010, 07:42 AM
#29
Re: the akitabus
What size rivets did you use on the sheet metal over the windows?
08-04-2010, 12:00 PM
#30
Rated Cap: 35
Re: the akitabus
Seeria
Seeria the Bus Nut,
Over the windows are the original rivits that came with the bus, of which I can't even find that style of rivit. All the other rivits that I used were 3/16" barrel (I think), they are the largest rivits that you can get at Lowes and Home Depot, and they vary in length depending on what I had to go through. Hope that answers you rquestion.
08-05-2010, 03:18 PM
#31
Rated Cap: 35
Re: the akitabus
Well I finshed up the LP storage compartment, now its time to start running gas lines and electriacal wire
A little paint and it should work just fine
So much to do and so liitle time.
TNT
08-05-2010, 08:40 PM
#32
Coachwork: Ward
Chassis: Ford B600
Engine: 6.6L Turbo Diesel
Rated Cap: 26
Re: the akitabus
That looks clean and professional!
08-10-2010, 09:53 AM
#33
Engine: DTA360
Rated Cap: 16
Re: the akitabus
Looks really good...
What part of the PNW are you in???
I'm in the Spanaway/Graham area...
Where did you pick up the windows and sheet metal???
Thanks,
Luey...
08-10-2010, 04:50 PM
#34
Rated Cap: 35
Re: the akitabus
Luey, I am just north of Seattle, Shoreline to be exact, I got the sheet metal from Ballard Sheet Metal, they do all sorts of fabrication, but I just bought it as plain flat sheets. Down the sides i used 20 gauge and to bend around the corners I used 24 gauge, the reason its green, is that was all they had in 24 gauge when I lifted the lid and I didn't want to have to wait for the unprimed stuff to get here.
The widows all came from either Bottom dollar surplus or Midwest surplus (thru EBAY) I think the most I paid for any window was 169.00 landed at my door. Some I got for as little as 45.00$ landed.
I am now working on getting the inside ready for wood sheeting so i can then really set the windows w2ith the trim rings in.
Thanks for the postive words about our bus.
Dogfinn
08-10-2010, 05:08 PM
#35
Rated Cap: 35
Re: the akitabus
Starting the widows I thought that I would counter sink screws in the edges then chaulk and screw them down, well that didn't work very well then I thought I have a welder, DUH
so using clamps and a drill, I just drilled small holes just barely into the interior frames and spot welded them, then ground down the weld. it worked really well. There is alot to learn but I am having a ball doing it.
This is looking from the outside at the batroom window. There are some ripples in the sheet metal where I welded the tow pieces together, if I was going to do again I would just overlap the two pieces and rivit them. That welding creates a lot of heat which means expansion and warpage. Not to bad for first try though.
Starting to insulate with 2" foam board, still have to run some more wires and glue in wood blocks prior to sheeting for lites and blinds and such.
TNT
Dogfinn
08-11-2010, 02:01 AM
#36
Engine: DTA360
Rated Cap: 16
Re: the akitabus
Nice way to over come the oops...
I've been thinking about buying a spot welder for that kind of stuff... I've plug welded lost of things like you did, but for thin stuff that doesn't have to be fully welded a spot welder would come in real handy...
BTW, I love the window work... Gotta get me a drivers window like that...
09-15-2010, 12:53 PM
#37
Rated Cap: 35
Re: the akitabus
Hello all,
We really have not spent much time working on DA BUS, we have been regrading the back yard, perpairing for raised areas for a putting green and a fire pit area.
Here is a pic of the galley mock up . Well I can't seem to load any pics.
We have the passenger side about 3/4 done as far as the 2" foam is concerned and have most of it sheeted with laua (spelling) hope I got all the wires that I need in there.
We are getting closer to the part were we actually get to build something, WALLS and THINGS, hopefully some time in the next month or two. We have our Wedgewood Stove (in the carport)
and our roof top 13,500 BTU AC with heat (in the garage) and our RV 500 tankless water heater (in the living room). if I could just quite working for a living then I could work on the bus.
09-28-2010, 04:37 AM
#38
Year: 1974
Coachwork: CARPENTER
Chassis: GMC-6000
Engine: 454 CHEVY
Re: the akitabus
love the akita's we have had them in the family sence about 1983 my mom and dad have one now. the first one we had i took for walks on a skatebourd it was a site to see 85lbs akita pulling a 140lbs kid down the sidewalk on a skatebourdin 1987,but it was fun!
hd d44 4.56, eaton ff 4.56
10-13-2010, 11:40 AM
#39
Rated Cap: 35
Re: the akitabus
Insulation almost done, this is looking forward on the drivers side
and looking aft
Why does it seem to take so loooong to complete even the simplest of tasks. this weekend i hope to get the shetting up down the drivers side so that I can butyl chalk and install all the trim rings on the windows..... we will see.
Next step for us is to figure out exactly where the toilet and sinks will go so that I can start the tanking process.
So much work and so little time.
dogfinn
10-13-2010, 05:04 PM
#40
Rated Cap: 35
Re: the akitabus
Smitty,
I was not planning to but you bring up a very good point, thank god I live in a very reasonible climate (Seattle) and really don't plan at this point to go any where were the cold climate would be an issue, My wife and I perfer the heated parts of the country. So I guess the answer is NO NO AND NO. I love looking at this site to get ideas and getting feed back on what I am doing... so please give me feed back good and bad. OK NO THERMAL BREAK. BAD.
Dogfinn
