Old 03-29-2011, 12:04 PM   #51
dogfinn's Avatar
Engine: 7.3L, International
Rated Cap: 35
Re: the akitabus
This site will only let me post 2 pics at a time, not sure if us or them, may be the pics are to big. what ever I will try to post as we go.
dogfinn is offline   Reply With Quote
Old 03-29-2011, 12:20 PM   #52
dogfinn's Avatar
Rated Cap: 35
Re: the akitabus
I don't know if a pocket door is the best idea, but we really did not want a door that opens in the conventional way for obvious reasons... there just is not enough room unless the door is facing back or front, opening out into hall was just not going to work.
Old 03-29-2011, 12:28 PM   #53
dogfinn's Avatar
Rated Cap: 35
Re: the akitabus
Old 03-29-2011, 12:43 PM   #54
lornaschinske's Avatar
Rated Cap: 89
Re: the akitabus
That is why we are going with a folding door. They are vinyl/PVC and we will use one for the "shower curtain", one for the toilet area door and one to divide off the bathroom from the galley/front of the bus. Because our shower opens out into the hallway that leads to the bedroom, I may add another door to close off the 63" section because it will help hold the heat in from the CAT heater while taking a shower. At $27 its pretty cheap and takes up very little room.
http://www.lowes.com/pd_35854-259-VS...folding%2Bdoor
Fulltime since 2006
Old 03-30-2011, 02:47 PM   #55
pipopak's Avatar
Re: the akitabus
That T connector at the showerhead , if it is zinc attached to copper you may have a problem with galvanic currents in the future.
pipopak is offline   Reply With Quote
Old 03-30-2011, 05:50 PM   #56
dogfinn's Avatar
Rated Cap: 35
Re: the akitabus
Great catch Pipopak you get an A +, it was a test and you passed, should i put a brass fitting between the two to act as an isolator ?
Old 05-06-2011, 03:10 PM   #57
dogfinn's Avatar
Rated Cap: 35
Re: the akitabus
Pics of the bathroom sink
Sorry, the board attachment quota has been reached.
what does this mean? i get this message when trying to upload pics.....HELP
Old 06-02-2011, 12:20 PM   #58
dogfinn's Avatar
Rated Cap: 35
Re: the akitabus
bathroom sink before tile
After tile
Next comes the ODWH (on demand water heater)
Old 06-02-2011, 12:31 PM   #59
dogfinn's Avatar
Rated Cap: 35
Re: the akitabus
Measure and cut for the water heater
Now the nerve racking part, the cut
And it is in.
Old 06-02-2011, 12:42 PM   #60
dogfinn's Avatar
Rated Cap: 35
Re: the akitabus
Rub rails with caps, installation compete.
Next I started on putting vented windows in the back. I hadn't worked on the bus for awhile and in my haste I cut for the back windows as if they were square... DUH
good thing you can glue metal back together... it just added about 2 hours to the process.
window in.
