Old 06-02-2011, 12:49 PM   #61
dogfinn's Avatar
Engine: 7.3L, International
Rated Cap: 35
Re: the akitabus
Next i am going to work on the frigerator cabinet and holes for vent... now that i have cut into side wall of bus I don't think I can stop myself from cutting more of them... its kinda fun.
till next time.
Dogfinn
dogfinn is offline   Reply With Quote
Old 06-02-2011, 07:47 PM   #62
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
Re: the akitabus
window looks good! so does the installation of the hot water heater
Old 06-03-2011, 02:16 AM   #63
willem's Avatar
Coachwork: Thomas MVP
Chassis: Thomas
Engine: Cummins8.3 Allison MD3060
Re: the akitabus
What are the details on the water heater, Finn? ($ too?)
Will
Vashon Autonomous Zone, Cascadia
http://www.the88.org
http://thesuper8.bandcamp.com/
willem is offline   Reply With Quote
Old 06-03-2011, 03:02 PM   #64
dogfinn's Avatar
Rated Cap: 35
Re: the akitabus
Not cheap... it is an RV-500, same unit that went in to the "Good News bus", got it from Global pro tankless or somehting like that... if you are really interested I can get you the correct name and a telephone number. I got the one with a winter protection system and it cost approx 1100.00. My water heater and refrigerator are the two most expensive thing I am putting into the bus. I have heard to many horror stories about 300.00 to 400.00 hot h20 tanks that rot out and don't last but a couple of years, so i dumped the big bucks for the rv-500.
http://precisiontemp.com/pt_rvmd_rv500.html
The above link should get you there.
till next time
Dogfinn
Old 06-03-2011, 03:16 PM   #65
dogfinn's Avatar
Rated Cap: 35
Re: the akitabus
Here is a couple more pics of the tankless heater.
Close up of the capped rub rails.
Pic from inside the bus of the hot water maker.
so much to do do and so little time.
Dogfinn
Old 06-05-2011, 02:14 PM   #66
browncrown's Avatar
Rated Cap: 79 at Birth
Re: the akitabus
Looking real nice
BC
Old 07-20-2011, 12:16 PM   #67
dogfinn's Avatar
Rated Cap: 35
Re: the akitabus
getting ready for the refrigerator vent, went with the Norcold N641, even the simplist of task seem to take forever to get done.
completed vent, also ran all the LP lines under bus... went with black 1/2" pipe and left stubs into the bus with valves then copper tubing to the appliances.
Old 07-20-2011, 12:21 PM   #68
dogfinn's Avatar
Rated Cap: 35
Re: the akitabus
close up of the rab rail end before fitting and welding caps on the cut ends.
after fittiing and welding caps on the ends, little by little we get better at what we are doing.
Old 07-20-2011, 12:26 PM   #69
dogfinn's Avatar
Rated Cap: 35
Re: the akitabus
Looking through the vent at the backside of the OD water heater sitting the the other wheel bump.
Little by little we make progress.
till next time
Old 07-20-2011, 01:36 PM   #70
browncrown's Avatar
Re: the akitabus
Very nice work...looks like you're making some good progress.
BC
