Old 02-11-2017, 10:57 AM   #21
Elliot Naess's Avatar
Engine: 5,9 Cummins
Millicent has (had) 15 identical windows. But looking at various photos now, I see several with two sizes. Somehow didn't notice that before.
I suspect they juggled seat spacing too. That is, seats might not match windows, and/or might have either 13 or 14 rows in the same floor space.
Sooooo.... To establish bus length, it is not enough to count windows from a steep angle.
Elliot
Old 02-11-2017, 04:27 PM   #22
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
Any chance of a prop on the nose?
I love this idea. Rolling art.
Old 02-11-2017, 05:34 PM   #23
Year: 1987
Engine: 6.9L Diesel
This is one of the most exciting projects I've seen in awhile. May the force be with you!
ps: Millicent was one of my gateways into this site. Big fan.
Old 02-11-2017, 05:34 PM   #24
Engine: 5,9 Cummins
A prop is certainly possible, but so far I'm thinking faux jet engine intake. There is probably a hubcap off an RV, or an industrial light fixture, or some such that fits. The ID of the hole is roughly 23 1/2 inches. It is round, but not flat, so it would be nice if the "hubcap" wraps around the outside a couple inches.
Of course, this is something we can swap out anytime we come up with a new one.
Elliot
Old 02-11-2017, 06:51 PM   #25
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
Old 02-11-2017, 07:10 PM   #26
Engine: 5,9 Cummins
Difficult to see the propeller in this photo, but it is there.
Elliot
Old 02-11-2017, 07:10 PM   #27
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
Awesome!
Old 02-11-2017, 08:23 PM   #28
Engine: 5,9 Cummins
Since we play with bicycles quite a lot….
Two wheels behind each other, with strips of sheet aluminum on the spokes to represent turbine vanes, alternating direction, imitating a jet engine.
And on the front, a chain drive from a dummy shaft sticking out below, similar to a supercharger drive on an old race car.
I can “see” this clearly. Hopefully, I am not the only one with “predictive vision”?
Elliot
Old 02-13-2017, 03:08 PM   #29
REDD's Avatar
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 2 ATV's and friends
I can see it, joining the spokes together on an angle with thin pieces of sheet metal. I also play with bicycles. Might be able to stuff a metal garbage can in the hole and make the whole thing an insert.
So I'm looking at your drawing, freakin awesome, way to big of a project for this guy but never the less, awesome!
-Steering/axle, looks like your wheels are tight together like a tractor? What's the plan?
-Blind spot from the small windshield, that's a lot of front end.
-teeth look cool, like an old war plane.
-Do you think you'll have any issues getting insurance?
-need some crazy mirrors to tie into your build.
Old 02-13-2017, 03:18 PM   #30
REDD's Avatar
Coachwork: Thomsass
So... shopping for a bus.
I'm struggling to understand the length of some Blue Birds. I'm approaching convinced that BB makes (made) different window sizes. Not concerned about height, but length. (One might also say window "width".)
Millicent measures 28", center to center of the window posts. Note... center to center -- not the window itself, which is a tiny bit less.
Put an other way, the full roof panels measure 56" and span two windows.
Could I ask you BB owners to run out and measure yours?
Millicent has 15 windows and 84 pax, and is 39-40 feet.
But I'm seeing buses with only 14 windows, yet also 84 pax and 39/40 feet. Longer windows and roof panels?
OK, I know you're looking for a BB flat nose.
A dog nose, you could almost put the hood inside and move the windows of the plane over the drivers seat. A couple of hatches on either side like an old Dodge swing fender and you're under the hood.
Mines 40' dog nose F/L, 10 windows the same and 1 larger at the rear [11 total]
