01-05-2017, 08:13 AM
#181
Originally Posted by Justin McCormick
I've had 2 of those light go bad on me within a month of owning them, less than an hour of use. they do no like getting wet.
I've read that people have better luck cramming silicone in ever possible area where water may get in.
1967 M109 Deuce and a Half
platetees.com
01-05-2017, 10:28 AM
#182
Chassis: Saf-T-Liner MVP ER
Engine: Cummins 5.9L Diesel Engine
Rated Cap: 83
Good to know. I will keep my eye on them. They seemed to have good reviews and look and feel well built. If they go bad, I can easily get to them and replace them.
01-05-2017, 11:00 AM
#183
I would go easy on the silicone sealant anywhere sun can touch it. UV light can really degrade silicone quickly.
The best sealant to use where two surfaces are mating is butyl rubber. You can get it in tubes that will fit in caulking guns or in tape form. The tape form comes in varying widths and thicknesses.
If you mount a light and use butyl rubber tape it is very easy to cut away the excess and leave a very nice factory edge finish. And once done it tends to stay done for a very long time.
The only real problem with using butyl rubber in any form is it is relatively difficult to work when the ambient temps go below 45*. It becomes very stiff and hard to mold when things get cold.
01-05-2017, 11:06 AM
#184
silicone...rubber...whatever
just something to keep the water out
platetees.com
01-30-2017, 10:03 AM
#185
Rated Cap: 83
01-30-2017, 10:46 AM
#186
Year: 92
Engine: DTA360 5.9L
its about time you gave us an update! i've been eagerly waiting a month to see what you've done haha. great work as always!
01-30-2017, 10:59 AM
#187
Rated Cap: 83
Thanks! The weather had been crappy which made progress slow. As the weather improves so will the pace of work.
02-06-2017, 08:26 AM
#188
Rated Cap: 83
02-07-2017, 10:09 AM
#189
Rated Cap: 83
02-07-2017, 12:43 PM
#190
That's some fine work you doing there Justin. That will be some of your son's fondest memories.As Tango says " ONWARD" love the video !!
02-07-2017, 03:12 PM
#191
Rated Cap: 83
Thanks! The kids are actually a big help on the bus.
02-07-2017, 03:42 PM
#192
I may have already asked you this Justin. Where are y'all at in Texas?
02-07-2017, 03:47 PM
#193
Rated Cap: 83
We are in Arlington, altho the bus is in Alvarado.
02-22-2017, 12:21 PM
#194
Rated Cap: 83
02-22-2017, 05:19 PM
#195
I think I would have rotated the gate valves 90* one way or the other.
I think you will find that pulling straight up on that rod is going to be difficult once some crud and corruption have invaded the rod.
02-22-2017, 06:19 PM
#196
what do you do to keep plumbing from freezing? i see a lot of buolds with exposed plastic pipes below.. or do you just chase sunshine and drain the tanks if travelling to cold climates?
02-23-2017, 09:01 AM
#197
Rated Cap: 83
Good information! I vaguely wondered about that as I was putting it in. Should have done some more research before setting it into place.
02-23-2017, 09:04 AM
#198
Rated Cap: 83
Well yes, we plan on chasing sunshine. But if we find ourselves in colder spots, the fresh water will be inside the bus along with all the water lines. From my understanding there is stuff you can put in the holding tanks to prevent freezing right?
02-23-2017, 09:06 AM
#199
Ya...the Valterra valves can get pretty sticky. I set mine parallel to the ground with the valve handle towards the rear to try and minimize how much road grime collects there.
02-23-2017, 12:39 PM
#200
You can hear trace. That is what we use on pipelines in cold climates!
