11-01-2007, 11:37 PM
#41
Re: The "Behemoth" comes to life....
The stipe tape was purchased on ebay from Bardans Custom and will get some swishy type of graphics from another seller called Cut-Rite Graphics...
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
11-11-2007, 09:20 PM
#42
I got the hitch installed today, at least mostly installed. Need to add a couple more bolts, and to be honest I'm thinking of having the edges welded too...just for redundancy. Actually, if I had been able to find the right hitch, the frame already has holes in it....
*Cliff*
11-12-2007, 11:18 AM
#43
Rated Cap: 60
I would definitely put two more bolts in that and have it welded. What are you planning on towing with it? Even if you weld it and put another couple bolts in it, I wouldn't tow much more than 3,000 pounds.
11-13-2007, 08:54 PM
#44
It's rated for 5,000# and that cross frame is thicker stuff than the hitch is made of... And now that I've done all that work, I ran across a Class-4 (10,000# rated) frame hitch today for $50!! I gotta take some fresh measurements but I think I may be able to use it....
***SIGH***
*Cliff*
11-20-2007, 08:52 PM
#45
More progress this week, the mattress is in (Queen Pillowtop)....
The back-up camera and housing has also been installed, though the rear window a/c unit is kind of in the way...but that thing probably won't stay there long term... but for now I have a great view of the top of the a/c housing!! I'm going to add a second camera that looks more backward than this one,
*Cliff*
12-02-2007, 08:31 PM
#46
My latest aquisition.... year, configuration & exact model still unknown, but it is an Onan Generator removed from an older motor home. It's been sitting in this guys yard for a few years and he just wanted it gone...so I took home. He said it ran when it was removed from the MH a few years back, but has been sitting outside under a tarp for quite some time. Our Saturday counterman at the shop used to fix Gensets for a living and still works on them on the side, he told me to get a carb rebuild kit for it (Cummins/Onan is next door to our shop) and he'll rebuild the carb and figure out a fuel cell for it, and that it should run! Guess we'll see...
*Cliff*
12-02-2007, 09:13 PM
#47
looks like one of those highly coveted 1800 rpm geni's????
12-03-2007, 07:47 AM
#48
why not mount the camera on the A/C cover?
I guess vibration might be an issue though.
12-03-2007, 09:07 PM
#49
The back counterman at Cummins/Onan was suppose to come over today to ID the Generator for me. Since I drive for a living I'm not even sure if he showed up or not, but I'll go over and talk with him again tomorrow. I can't get much off that data plate...I can read the S/N or at least most of it...
As for the A/C... I think that is going to get removed from there. The roof top unit seems to do a good job on the whole bus, and if I move the roof unit to the center (it's in the rear right now) it should be all I need. If not, I can still use that window unit on the emergency exit side window...it just flips up out of the way! Still thinking about what I want to do there...
*Cliff*
12-12-2007, 08:26 PM
#50
Added the TV shelf for the bedroom on Sunday...
*Cliff*
12-16-2007, 07:46 PM
#51
Did some more ceiling work today... This section is over the drivers seat...
And also over the entry door...
More images posted on my site... Did most of the bedroom ceiling too, except the center section due to pending a/c move...
*Cliff*
12-16-2007, 08:29 PM
#52
Your bus is looking very professional. when do you plan on moving in?
12-17-2007, 08:09 PM
#53
Well, I actually WAS hoping to be aboard by Christmas, but it looks like perhaps early spring now. I've already set my Travel Trailer up for the winter, so I'll just plug away at the bus until the weather warms. This will give me time to get all the trim work done. I also have to get underneath of it and finish the cargo bay...something I started and never finished... Though it is very close and to be honest it's usable as it is right now, there is still a lot left to do!!
*Cliff*
01-02-2008, 09:43 PM
#54
The front facia above the windshield got finished this week... well, maybe still needs a few trim pieces!
*Cliff*
01-06-2008, 07:28 PM
#55
I used Sani-Lite on the bathroom ceiling... (that textured stuff they use for bathroom walls etc...) I'm kind of wishing I had used this stuff on the entire ceiling...it went in nicely. I still need to trim it out...
*Cliff*
01-08-2008, 10:09 PM
#56
Yes it does, and it bends nicely into the curve of the ceiling too!!
*Cliff*
01-09-2008, 05:54 AM
#57
Everything looks fantastic! That FRP board does go up nicely. Looks very clean. All your oak trim looks great.
01-09-2008, 09:11 AM
#58
Year: 1981
Chassis: Crown
Engine: 671 DD
Hey Cliff, is that the stuff that is sold in the big box stores (i.e. Home Depot)?
Robert
01-09-2008, 11:23 AM
#59
Year: 1981
Chassis: Crown
Engine: 671 DD
Originally Posted by ShortBus
Robert
I know I'm not Cliff, but I've seen it down the "paneling aisle" at Home Depot, between their Lumber and Millwork departments (at least at the Home Depot here.)
Thanks ShortBus, just wanted to confirm that it was the same stuff. Never knew the name of the stuff, besides FRP.
Robert
01-09-2008, 04:30 PM
#60
Year: 1981
Chassis: Crown
Engine: 671 DD
Originally Posted by jimmyaustintx
I looked at that stuff to do my bath and it is close to $25- 29 for a 4x8 sheet at HD
Wow, that's robbery. I seriously would have guessed around $8-12 a sheet, $15 tops. It probably costs them about $4 or $5 to make one. Oh well, nothing new I guess. The prices for just about everything are going up if they weren't already ridiculous to begin with. Probably further ahead dumpster-diving for a lot of the materials we use in our buses.
Believe it or not, I think that is the only thing that hasn't gone up in Home Depot. That's been the price for, at least, three years, that I know of.
Boy, that sure stinks.
