11-14-2010, 10:03 AM
Rated Cap: 79 at Birth
Re: The Big Bus Build
Welcome! That is a nice looking ride.
11-14-2010, 11:23 AM
Engine: 3208 na boat anchor
As they say in bus world, welcome to the madness. You'll find out what that means.
11-15-2010, 02:59 PM
Year: 1983
Chassis: Carpenter
Engine: 8.3
Welcome! It looks like you got a great start! Nice rig.
seth
"grease buddy" and all around nice guy
11-15-2010, 03:57 PM
Coachwork: Chevy
Sweet bus! Plenty of potential!!
12-24-2010, 09:04 AM
I'd suggest that you hold on at least some of the seats, you WILL need some angle and square iron sooner or later...
12-26-2010, 12:47 AM
Engine: DTA360
Rated Cap: 16
X2...
Nice looking bus...
01-16-2011, 01:40 AM
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
wow mthat bus looks to be in fantastic condition.Up here its 2 words,rust and mold! Welcome here lots of good bus people here
01-16-2011, 10:01 AM
Man, the floor looks beautiful...nice job
02-01-2011, 05:52 PM
Chassis: AARE
Engine: 3116 Cat 250hp
After using your bad dog biter for a while, are you satisfied with the performance and longevity of blades?
02-01-2011, 08:44 PM
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
can you provide a link to the recessed lights pls?
02-03-2011, 12:44 AM
Engine: DTA360
Rated Cap: 16
Could you give me some info on that cutter you're using???
Thanks, Luey...
EDIT::: I was only on the first page when I posted...
Sorry about that...
03-06-2011, 08:25 AM
Year: 1994
Chassis: tc2000 fe
Engine: 5.9
so what size did u have the pannels cut to0,to fit in the opening ,iam leaveing the window in my bird....thanks
03-06-2011, 01:44 PM
Rated Cap: 89
Originally Posted by gocmndo
... Each window weighs over 15 pounds and the window skin with the brackets to secure it to the window frame weighs just under 6 pounds. By changing out the 10 windows we will be saving over 100 pounds when you consider two emergency exit windows...
We are skinning windows this weekend as well. Our emergency windows weight a lot more than our regular windows. The each piece of glass is much heavier.
03-06-2011, 08:28 PM
Rated Cap: 89
... Once I get all of the window skins in place I will caulk around the outside and inside to seal out the water and wind...
You didn't caulk the metal sheets in place BEFORE you attached them?
03-07-2011, 11:27 AM
Rated Cap: 89
My window frames were originally caulked in on the sides (1 thin bead but I prefer a bigger bead) and the bottom was set in a bed of caulk. I'm reinstalling the same way. And yes, I did dry fit all the windows/skins first. But I am using the original track frame for my skins. Makes a big difference I guess.
Pics of the window skinning. http://aluminumasylum.webs.com/bluebirdfepg2.htm
03-19-2011, 05:52 PM
looking good, real good. where did you get the rear view camera? I have been looking at them on line at rearviewsafety.com they seem a good price.
if you dont mind, can you tell me abit the one you got? size of screen number of cameras, and if you dont mind how much its worth?
tks
06-06-2011, 01:42 PM
Martin: the 4 white lights on top may be illegal. Did you research about it?.
06-06-2011, 02:45 PM
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
love the led lights, where did you get them? Cabinets look great, really good cut up next to ceiling....
06-06-2011, 04:45 PM
Rated Cap: 89
Lots of RV's from all over the country have "docking lights" on their RV.... what's the diff? We are keeping 1 set on the front and rear (dedicated switches at switch panel next to drivers seat). I don't know about anyone else, but I plan on being able to light up our campsite if I'm pulling/backing in at night (you haven't seen some of the places we have stayed in... 3 ft to 20 ft drops off the back end of the campsite). Also it will light up the area behind us in case we have to do something to the towed vehicles... like change the tire.
06-07-2011, 02:55 PM
Just remember that just crossing paths with the right ASSembled HOminid LEft in the wrong mood is enough to ruin your day or worse. Personally I like to be on the right side. Things elastic enough to be "interpreted" usually leave you at the wrong end of the gun.
