Old 05-27-2016, 11:17 PM   #11
Asetechrail's Avatar
Coachwork: Amtran Genesis
As a plus, the school district just did all the maint. items on this bus!!
Oil was so clean it was almost hard to see on the stick👍👍
Asetechrail is online now   Reply With Quote
Old 05-27-2016, 11:18 PM   #12
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Direct from the district is the way to go!
Roll Your Own Build Thread
Old 05-27-2016, 11:27 PM   #13
Carytowncat's Avatar
I am so excited for you guys!
Old 05-27-2016, 11:29 PM   #14
Sweet bus!
Feels so good to get it home, eh?
Great to have it home!! Just got to make room to get by my trailer and figure out level parking.
Old 06-02-2016, 05:53 PM   #15
Got the bus title transfer done today. Registered as a motor home. No inspection no questions asked. I only have about half the seats out at this time. They didn't care. 😎👍😇
Old 06-02-2016, 06:05 PM   #16
Chassis: International S3800
I agree with the sound of the motor. a DT is rated at its most hours if you keep it at 2700 or below...
IHC rates them that the DT360 / 466 / 530 can be run up to 3200 RPM without harming the engine but they do state that the hours between major maintenance intervals will be shortened by running it over 2700 RPM.. the closer to 3200 you get the less hours you can count on..
they dont care in ohio either... they are just like stamp stamp print, type,,. ok here is your registration..
Old 06-02-2016, 06:45 PM   #17
GreyCoyote's Avatar
Chassis: IH 3800
Engine: Navistar DT466E
Rated Cap: 72 passenger
Wow! Any chance you can provide a factory cite for that data?
FWIW, the factory ECM config for the DT466 redlines it at 2600 rpm, and the DT530 is set at 2200 to 2400 depending on application. Both engines are way over their torque curves at these cycling rates.
Of course, the tractor pullers spin these motors well over 4000 rpm with 100+ psi of boost, so I'm all ears if there is a published spec that I dont know about.
"You can finally say you have enough horsepower when you leave two black streaks from corner to corner"
(Mark Donohue, famed TransAm driver)
GreyCoyote is offline   Reply With Quote
