Old 11-03-2014, 03:18 AM   #241
Chassis: TC2000 Rear engine
Engine: Cummins 8.3; MD3060
Re: The Broccoli Bus
Hi, I have couple quick questions for you. I can see your bus has storage under the floor. Is it all the way from side to side and from front to back or just few boxes/compartments? And what is your clearance to the ground? I built full "basement" on my bus and left about 10" clearance.
Thanks
Here is my conversion thread:
http://www.skoolie.net/forums/f11/98-bluebird-tc2000-conversion-2-feet-roof-raise-3-slideouts-9728.html
Vlad is offline   Reply With Quote
Old 11-03-2014, 12:20 PM   #242
Chassis: TC2000 RE
Engine: 8.3l Cummins
Yes, there are double doors on each side, and it's one large compartment that reaches across front to back and side to side. (the reason I bought that particular bus! )
10" sounds about right, I'll need to measure it. There is a large panel covering the frame rails in the middle, so there is (as manufactured) no access up inside the frame rails. I plan on removing that center panel so I can stand water tanks straight up in the center between the rails, allowing access to directly below the floor as well.
When I get a chance, I'll get some dimensions and post them. Take a look at the build thread for "Big Bertha" I think they have nearly the same layout I have, without the roof raise.
Thanks
aaronsb is offline   Reply With Quote
Old 11-03-2014, 10:14 PM   #243
Rated Cap: 40 Prisoners
Just did some internet surfing and ran across www.rvtechmag.com and in their reviews they check out a unit called an Earthbound RV which has holding tanks that are coated with a ceramic infused insulation which has an R-13 insulation factor, would be great for the front cap and dash where insulation needs to be thin. Also I have a large amount of 1/2" dacron sound insulation about 6" wide by 5 feet long some plain and some with aluminum facing on one side if you need some. Also I still have the two holding tanks available as well as three toilets.
Old 11-05-2014, 02:05 AM   #244
Thanks for your reply. I wasn't so lucky to have "basement", so I built one 17'x8'x2'.
I can see you work on your insulation. I still have few things to do before insulation. I can see you put 2" insulation between "studs". You have voids near studs. Do you want to go over with 1" foam to cover everything? If yes how do you think to attach your paneling over the foam?
I was thinking about screwing 3/4" plywood striping to studs(ribs) to have something to hold paneling later. I know plywood over steel ribs is not going to be the greatest insulation....
Old 11-05-2014, 11:19 AM   #245
charles_m's Avatar
Year: 1982
Chassis: International S1800
Engine: DT466 Trans: MT643
I love all the work you've put into this build! Such a custom setup.
Just wondering what you're thought process was in choosing that particular type of foam board for insulation. I'm planning on using foil-faced polyiso board like this:
http://www.homedepot.com/p/TUFF-R-2-in- ... 5yc1vZbaxx
I'd be lying if I said I wasn't jealous of your metalworking skills and unimog.... someday!
www.bustoshow.org
Blog: www.lookatthatbus.com
Instragram: @lookatthatbus
Old 11-05-2014, 12:19 PM   #246
Chassis: TC2000 RE
I'd say go with the polyiso, it's a better insulator. The reason I went with the EPS is more to do with cost than anything else.
There is a rule of diminishing return on engineered or installed R value for a given structure, and for my needs, I felt my money was better spent on other items. For example, I plan on insulating the basement from the underside, and the doors for the basement with the same "cheap" foam, and also applying a bed liner cover over the insulation in those areas to keep up durability.
If I had gone with the polyiso, the funds for doing that would have gone to just the foam board itself. Additionally, r value is one component in many to make the insulation effective, and I think the returns on the r value difference will not be all together that much different.
Here's a toy to play with some numbers:
http://chuck-wright.com/calculators/insulpb.html
There's a huge body of work related to this. I am not a civil engineer, I just stayed in a holiday in express one time.
Old 11-05-2014, 12:24 PM   #247
Chassis: TC2000 RE
I purchased stock in the Dow chemical company buy buying about 30 cans of "good stuff" spray foam (red can). With the nozzle I am spending time injecting spray foam into the crevice and gaps around each panel installed in the bus. Then, I'm shaving it down flush with a wire wheel.
After that, I will tape the seam with foil tape, and apply an elastic foam tape that's about 1/8" thick. Then, on top of THAT, I'll be installing 1" eps foam board (foil facing inwards) jointed to the wooden support boards. If I'm feeling jaunty I may spray foam the gaps between the wood boards and the 1" boards, but most likely I'll just do a close fit, then foil tape the 1" boards to the wooden support boards you seen in the pictures. I fully expect the interior to look like a giant jiffy-pop pan when done.
On top of that, I'll install the finish panels, which I'm trying to decide between white ABS plastic with a fine sand texture finish, or .060 FRP panel with the same texture finish. I'm leaning towards ABS due to it's ease of install.
Old 11-05-2014, 10:21 PM   #248
My point is how are you going to install your finishing panels? Are you going to glue them to foam? Btw I found a bunch of iso boards on Craigslist. Picked them up today. Got a great deal 15CAD for 4x8 sheet 2 inch thick.
Old 11-05-2014, 10:33 PM   #249
Chassis: TC2000 RE
public service announcement
Working on a bus is a lot easier when slightly drunk with loud music playing.
Old 11-08-2014, 02:06 AM   #250
Chassis: TC2000 RE
Cold bridge example
As a science experiment, I tried applying my sealing foil tape directly to the rib on the right, and on the left, the actual setup, which is 1/8" acrylic foam tape applied to the rib, followed by the same mylar tape.
As you can plainly see from the photo, there is significant condensation of moisture on the right, while the left is completely dry.
Some numbers:
time/date/location: 23:30, November 7 2014, Seattle, WA
outdoor relative humidity: 90%
indoor relative humidity: 60%
outside air temp: 41 F
inside air temp: 65 F
vehicle exterior surface temp: 41 F
surface temp of 2" foam, taken from center of panel: 64 F
surface temp of rib with acrylic foam covered by mylar tape: 59 F
surface temp of rib without acrylic foam covered by mlyar tape: 41 F
As you can see, the cold bridge just rolls on through the steel structure like it doesn't give a damn. Even 1/8" of cheap foam insulation tape makes a significant improvement.
If you are spraying foam directly over your ribs and structure, you're set. Unfortunately spraying 1000 square feet of surface area to a 3" depth was out of the cards for me, price-wise.
Instead, I'm laying down foam boards, and I'll need to seal all the gaps. Not ideal, but it shows how much thermal loss there is in a vehicle that retains the original structure inside without modifying it if you're planning on occupying for longer periods of time.
