Old 11-11-2014, 03:29 AM   #251
Chassis: TC2000 RE
Engine: 8.3l Cummins
Re: The Broccoli Bus
Looks a little creepy in here with all the foil surfaces.
aaronsb is offline   Reply With Quote
Old 11-12-2014, 04:02 AM   #252
Chassis: TC2000 RE
The value of insulation is rapidly becoming apparent. It is currently 32 degrees f outside with 30 mph sustained winds. I haven't started insulating the floor or end caps yet. The walls and rear are getting close. With the small electric radiator I can maintain 65 degrees from the waist up. The first 10 inches off the floor are about 45 degrees. Air temp at the ceiling is about 75.
If I turn on the propane heater buddy it gets too hot to work in about 20 minutes.
I hope my choice of foam panels over spraying doesn't bite me in the ass later with condensation issues. As a test I pulled a panel back to the metal and it was really cold but dry. Within about a minute condensation started to form on the metal.
This was a skin panel that I originally plopped foam against without even bothering to wipe the condensation off originallly, so I was wondering if it would just get wetter or dry out.
Does anyone have long term experience with a foam panel insulates vehicle like this? How did it fare after a few years? I have three inches of polystyrene panel with foil to the outside and inside.
Old 11-17-2014, 01:27 PM   #253
Chassis: TC2000 RE
Floor support rails installed. They are cut down pressure treated 2x4's to 2" tall, to accommodate 2" foam insulation. The fasteners used are 1-3/4" self tapping hex head screws with a washer head. They are countersunk into the wood. I'll be applying some sealing primer to the untreated surfaces of the strips, as well as the underside of the plywood that will be laid on top.
Old 11-21-2014, 04:00 AM   #254
Chassis: TC2000 RE
Floor plywood almost installed. After it is all cut and fitted I'll lift it back up and paint the underside with some killz primer to seal it a bit.
Old 11-21-2014, 07:32 PM   #255
Docsgsxr's Avatar
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
Its looking great man. Keep up the good work!
My build thread - viewtopic.php?f=9&t=467197
Old 11-21-2014, 09:50 PM   #256
browncrown's Avatar
Rated Cap: 79 at Birth
Very nice work...all that silver reminds me of a space shuttle
Keep on with great build!
BC
Old 12-01-2014, 03:57 AM   #257
Chassis: TC2000 RE
Amazingly I can see the light at the end of the insulation tunnel. A couple more finish panels in the cockpit, the rear, and floor is all that is left.
I decided to take a little break from the polystyrene and fix the remote start in the engine bay. I was pretty sure the bus wasn’t going to start in the cold weather but at least it will be ready later. New starter switch and engine bay lamp switch. I cleaned the gauge up a bit too. Now I can fire it remotely which is cool.
Still needs the key switch in the on position though.
Oh OK, here are a few insulated bus shots too. I should draw future window frames on the walls.
I've started posting this on my blog first, and then copy-pasta to the forum. Whats the rules for posting links to content on other sites?
I stash my stuff here: http://www.bockelie.com
Old 12-01-2014, 03:58 AM   #258
Chassis: TC2000 RE
I think the first framing to go in will be the kid bunks, and partition wall for our bedroom. That sets the space for the toilet and shower, followed by the passenger seating/common area/dining room.
I should post a sketch of the layout.
Old 12-01-2014, 04:06 AM   #259
Chassis: TC2000 RE
We had some snow for the first time this season. I am pretty pleased with the results on the roof. As you can see the garage which is unheated, has most of the snow melted off it, probably due to the dark roof.
The bus next to it still has snow on it, and the interior is kept at about 68 Fahrenheit with an electric space heater. I'm happy to see that my effort is not in vain.
Old 12-01-2014, 11:10 AM   #260
What sort of entrance door are you going to make?
I assume you won't be using the outward opening 2-panel service door as your entrance door.
