08-15-2014, 01:06 PM
#61
Re: The Broccoli Bus
Sweet.....mom...hotdogs and beer would be good
08-15-2014, 10:26 PM
#62
Chassis: TC2000 RE
Engine: 8.3l Cummins
Well, I'm no rocket surgeon.
Originally Posted by bansil
stop the scientific crap and just cut it loose
be safe, looks good!!!!!
08-15-2014, 10:29 PM
#63
Chassis: TC2000 RE
Blue tape lines are uh...sketched in. Middle spar is installed.
08-17-2014, 07:50 PM
#64
Chassis: TC2000 RE
Got the corners skinned. I think that is the hardest part of the sheet metal work. The rear should be comparatively easy, since its just an arch piece to fill the gap.
I am using 20 gauge on the roof, since that's what bluebird used too.
The center section is cut and fitted, just stopping for a little break.
08-17-2014, 08:01 PM
#65
Coachwork: Phantom
Chassis: Gillig
Engine: Series 50
I'm very impressed with the work on those corner caps. They look terrific!
08-17-2014, 11:56 PM
#66
Chassis: TC2000 RE
Sorry no outside pix with all the transition panels, it got dark.
It was a challenge to weld up that high. I ended up balancing the welder on a cooler on the dash, and running the lead out through one of the old upper flasher light holes.
08-17-2014, 11:58 PM
#67
Chassis: TC2000 RE
Thank you for the feedback. I wasn't sure at first how much deconstruction needed to happen before adding the caps. It turns out I removed that whole section of the roof except for a 2" strip to weld to. If someone was crazy enough to do so they could chisel all the rivets off and pull that whole transition cap. I tried to be faithful as possible with what I am capable of to the way the bus is constructed.
08-18-2014, 04:09 AM
#68
LOOKS GREAT!
08-18-2014, 10:49 PM
#69
Chassis: TC2000 RE
Got the bits seam sealed and riveted. Now I need to get the rear cap done. Pretty sure that's just a bunch of rivets, sheet metal, and sealer so we'll see.
08-20-2014, 11:20 AM
#70
Chassis: P-30
Engine: GM6.5
Rated Cap: 28
Nice work!!!! Sorry I didn't see your post about helpers sooner, were in Tacoma.... Holler if anything else comes up..
08-22-2014, 12:21 AM
#71
Rated Cap: 40 Prisoners
If you need holding tanks or toilets I have several spares, whats your address so I can
stop in and see it some time maybe give some hints or advice.
08-22-2014, 01:50 AM
#72
Chassis: TC2000 RE
I'll be working on it this weekend. I haven't had a lot of time this week to make progress. I think I've found the solution to the rear end cap and how to make it complete again - I've cut the strangely shaped arc corner pieces to mate up and form the corner.
It's also possible I may be picking up the sheet metal for the sides, not sure yet. I basically need approximately 70 linear feet of 20 gauge sheet metal, that's a lot of steel!
08-22-2014, 12:29 PM
#73
Rated Cap: 79 at Birth
Roof is looking GREAT!
08-23-2014, 03:27 PM
#74
Chassis: TC2000 RE
Sides will be installed...sooooon.
08-23-2014, 06:39 PM
#75
Chassis: TC/2000
Engine: Cummins 6CT8.3
Rated Cap: 76
That looks real. I'm envious! Roof is looking great!
08-23-2014, 09:09 PM
#76
Chassis: TC2000 RE
Ready to rivet the last cap panels in after dinner.
There is still a lot of trim work to make it all look proper, so don't worry!
08-23-2014, 10:19 PM
#77
Chassis: TC2000 RE
Lmk if you need something riveted!
08-24-2014, 12:04 AM
#78
Chassis: TC2000 RE
Making some endcaps. Very high tech, fence boards and vice grips.
08-24-2014, 10:46 PM
#79
Chassis: TC2000 RE
Here is the outside of the endcap as it is mostly done. It seems to take a long time, but really I have only worked on it a few hours here and there.
Left curved side is fixed with vhb tape and is ready for rivets right side is sort of flapping in the breeze before I pinned it into location.
Second photo shows what the interior looks like.
08-24-2014, 10:52 PM
#80
Year: 87
Chassis: International s1700
Engine: 6.9 internatiional
wow looking good there
