Old 03-09-2016, 07:12 PM   #591
browncrown's Avatar
Rated Cap: 79 at Birth
Moving right along and looking good...nice windows!
BC
Old 03-10-2016, 02:01 AM   #592
Chassis: TC2000 RE
Engine: 8.3l Cummins
Oh Deer
I was thinking about a deer guard.
aaronsb is offline   Reply With Quote
Old 03-10-2016, 09:30 AM   #593
Looks good but it needs some spikes sticking out to hold the meat in place so it won't get ruined by going under the bus.
Old 03-10-2016, 11:28 AM   #594
Rated Cap: Your mom +1
Classic, total CLASSIC!
I thought about ordering a leg lamp of my own. They're even available in the "fragile" crate.
only one thing could pull me away from the soft glow of electric sex in the window...
Old 03-10-2016, 11:47 AM   #595
Robin97396's Avatar
Would that be a large hamburger?
Old 03-10-2016, 12:17 PM   #596
I will gladly pay you Tuesday............
Old 03-10-2016, 12:35 PM   #597
Chassis: TC2000 RE
Expanded steel mesh to support the slab of deer, maybe some sort of actuator rod and handle attached to the door opening air ram.
I'm sure I could rig up some fuel atomizers and igniters for extra diesel fuel spraying out the front. If it sticks out far enough I can just lean forward from the driver's seat to check how well it's cooked.
A little bit of barbecue sauce in the washer bottle and I'll keep one of the wiper motor access doors to slather on the sauce - I'm good to go.
Old 03-10-2016, 01:10 PM   #598
Rated Cap: 40 Prisoners
I figured you would want to balance the weight on the bus in a practical
manner like putting an oven back in the engine compartment to compensate
for the heavy front bumper. You could make an insulated enclosure for the
turbo and pipe some of the heat over to the oven with a thermostatically
controlled butterfly valve. This would allow you to set the temperature on
the oven and with proper planning have hot meat available when you arrive
without that nasty diesel after taste. Also an insulated Turbo boosts power
and fuel mileage as a side benefit.
Old 03-10-2016, 06:37 PM   #599
Chassis: TC2000 RE
Idunno, even as a kid I've been one to empty the entire bottle of lighter fluid onto the webber because I liked the smell of the napatha, and the 10 foot tall fwoosh.
But I like where you're going with this. Perhaps some bleed air from a holset HX60 can be used to drive both the rotissarie motor, as well as the jerkey dryer.
Old 03-10-2016, 07:05 PM   #600
Docsgsxr's Avatar
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
I like mine tenderized, maybe a roll under guard and a scoop up mid chassis???
