Old 06-03-2016, 11:02 AM   #751
Very nice job on the pneumatic door!
You have no doubt thought of this, but I will mention it anyway. When I built the pneumatic door for my bus I added an air valve near the door which when turned releases the air pressure and allows the door to be opened simply by pushing it. Though I originally planned it to be an emergency release, I now find it very useful at a campsite for easy access to the bus without having to have the air compressor working all the time. I found a pic of the valve as it looked while I was building the door--it has the "things left to do" note pad hanging from it. Jack
Old 06-03-2016, 11:09 AM   #752
Chassis: TC2000 RE
Engine: 8.3l Cummins
Yep, you make a good point. Bluebird made it easy - they left an "emergency release" lever right above the door, very prominent. For now, the last one out just flips the lever, which turns the whole door into a manual access door, no air required.
I have assigned the task to my future self the job of adding a solenoid release for that same switch, so it can be remotely activated (like say with a wireless keyfob)
I haven't really figured out the comings and goings of the family and daily living in the vehicle yet, so I haven't gone further than the minimum. Tricky door maneuvers will come later.
aaronsb is offline   Reply With Quote
Old 06-03-2016, 11:24 AM   #753
I set mine up with a "hall way light" switching system. SPDT toggle on the inside and a SPDT keyed (fob) on the outside. I used a similar switch set up for turning the compressor on/off from either inside or outside the bus. Jack
Old 06-12-2016, 01:29 AM   #754
Chassis: TC2000 RE
Feels like every panel and finish piece is a struggle. It looks good enough so I'm happy with the result.
Carpet/ply panels in riding cabin area keep noise down. I have picked the hardest panels to complete first, naturally.
Stairwell entrance gets the same sorta thing.
Preview of the other areas. Birch with teak oil finish and aluminum trim over black painted steel frame.
Old 06-12-2016, 08:09 AM   #755
its lookin good!! what do you use to trim out your carpet on those panels? I like that look. !
I love those seats!!.. i want seats like that!!
Old 06-12-2016, 10:05 PM   #756
Chassis: TC2000 RE
A little more.
Looks kinda like
Old 06-12-2016, 10:14 PM   #757
Chassis: TC2000 RE
Just wrapping the carpet around the edge of the panel. Its an uncut thread so the carpet has a tendancy to snag when putting screws through it.
Angle aluminum channel. Seats from a parted out casino coach undergoing conversion to a camper. They are made by freedman seating.
Old 06-23-2016, 12:56 PM   #758
Chassis: Blue Bird
Engine: ISC 8.3
Originally Posted by aaronsb View Post
At some point I'm going to have to paint this beast for real. I was thinking of Sherwin williams shurthane 2k. Any thoughts? It'll be about 3 weeks of sanding prep I bet. Ugh.
How's the paint plan looking? I'm just about to drop a metric ton of coin on paint as well, and have been looking at the Sherwin-Williams automotive line. My local dealer is steering me toward the ATX (under "refinish") or Genesis (under "fleet" or "heavy truck/bus") products. An obvious difference in the two is that ATX is a base-clear system whereas Genesis G2 is single-stage. Cost for the ATX base and the G2 are about the same; the clear coat on top of the ATX adds about $1000. I really wanted to do a base-clear system because of a perception that it would have longer life, but the fleet users of Genesis seem to feel like the service life they get from that is fine.. Either way it seems I'm looking at a DTM epoxy primer (E2A933 in gray for example) to go over my new galvanized and galvanneal sheeting.
Initially I had been thinking industrial enamel (that's what ShurThane is, right?) but the information I could find seemed to indicate enamels might go chalky or otherwise not endure well sitting in the sun for more than a few years between re-coats.
Old 06-24-2016, 04:53 PM   #759
Chassis: TC2000 RE
You're following the same line of reasoning I have.
There's a Sherwin-Williams store south of where I'm at that sells the industrial automotive paints. ShurThane is on my mind, but I'm also considering a single stage polyureathane.
It's not completely off the table that I might get a metric-ass-ton of green water based carc and call it a day, since I need to re-paint my unimog too.
So, OD green - that would lend itself well to making the bus get turned away at every rv park, you think?
I am aiming for an ivory or off-white overall color, and a black skirt trim (from the lowest rub rail to the bottom)
I don't think there's a longevity difference with base/clear vs. single stage. When the surface starts to fail on a base/clear it's usually the clear that needs re-application. You have to be careful to only remove clear and as little color as possible. However, it lends itself well to color matching since the underlying coating is generally the same color.
When single stage starts to fade or loose luster, you can re-buff back but you have to basically buff the entire vehicle to match.
Old 06-25-2016, 07:04 PM   #760
Chassis: TC2000 RE
Lots of gluing plastic to ply backing going on. This stuff never ends it seems. The finished panels seem to take the temperature swing and durability test when done though.
